Question about LG Washing Machines
Have a LG Turbo Drum WF-T857 the agitator won't agitate while washing but still spins clothes dry
4 Suggested Answers
  • 59 Answers
SOURCE: will not agitate to wash clothes but will spin fine
call a repair man. you cant fix this yourself
Posted on Apr 26, 2009
ftw1952
  • 10319 Answers
SOURCE: LG WF-T552C The drum does not spin at all during
the timer you set when initially doing the wash is at fault if the other cycles spins as they should
Posted on Jun 19, 2011
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
Lg fuzzy logic 7.kg turbo drum top loader model wf-t7051td does not agitate or spin properly
I would call the washing machine engineer for a quote as there are to many things that can go wrong eric
Jan 11, 2018 | LG Washing Machines
How to remove the agitator in order to clean the bowl?
To remove agitators on these models, this fastening bolt must first be removed. To access the bolt, remove the cap at the top of the agitator - this can usually be done either by hand or by prying with a screwdriver. Take care if the cap is glued down
Jan 05, 2017 | Washing Machines
WE have an LG WF - T857 and the spin cycle isn't going. The machine doen't stop and beep, just stays on the cycle and makes a humming sound. Any ideas?
No spin, try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven.
Jun 09, 2014 | LG WFT1071TP Top Load Washer
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
Will not agitate to wash clothes but will spin fine
Apr 26, 2009 | Washing Machines
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
Washing Machines Logo
74 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
