Question about Hoover Vacuums
I have a Hoover Dual Power Pro Shampooer. When you shut it off it leaks alot of dirty water. What is wrong with it? do I need to buy a new one
  • 2,045 Answers
Check the hosing tightens
Posted on Apr 25, 2017
My Hoover Dual Power Pro carpet cleaner leaks continually from the front. I've cleaned and checked all connections.
Sounds like a missing or damaged seal/gasket/oring. Check carefully at source of leak.. maybe a seal or rubber gasket has shifted out of place.
May 03, 2017 | Hoover Vacuums
HOOVER MAX EXTRACT DUAL V LEAKING SOAP INTO THE FRESH WATER TANK
that is purely normal to have cleaning material in the fresh water tank as the vac picks up the dirt from the floor it should really go into the dirty pickup tank purely normal nothing to worry about
Apr 22, 2017 | Hoover Vacuums
How do I cycle the valves on the bottom with the eraser end of a pencil on my hoover dual vac shampooer
The center part of the valve (stem) pushes up (spring loaded) to release liquid. If it leaks it can (and should) be replaced. Also, check the black valve seal (conical shaped ring around the outside) for cracks or splits as this can contribute to leaks. The entire valve assembly (similar to photo) should be replaced to solve both issues.
Oct 09, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hoover max extract V clean water leaking
get a new clean water tank or a seal to put on it from hoover.com/vacuumparts
Mar 16, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My Hoover steam vac dual v clean water and detergent tank leaks water before attached to the vac and during cleaning
This is a common problem with the earlier models which had a separate soap tank glued to the clean water tank. The plastic was too thin beneath the valve on the clean water side and would develop cracks. You most likely will need a new one piece tank. ( Part # 42272104)
May 21, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
Suggest that you do the following.
Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
Power the machine on.
On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
Is all of that happening?
Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Solution for "hoover steam cleaner keeps
Hoover Carpet Shampooer
You might just need a new gasket. THey are inexpensive and fairly straight forward to replace with the right tools.
Sep 10, 2009 | Hoover F7431-900 SteamVac Vacuum
Dirty water is leaking back out
After shut off all steamvacs will leak dirty water that was sucked up back out. There is always some left in the nozzle. If it is a large amount there is clogged filter that isnt allowing the proper suction. Refer to your manual or go to hoover.com to download one for cleaning directions.
Jan 03, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirty Water drops behind shampooer
You are over sudsing your recovery tank. The machine is made to shut off the air flow if water starts to be pulled into the motor, but bubbles want trigger that. So if there are a lot of bubbles in your recovery tank, the get sucked into the motor (Which will destroy it eventually) and then the moisture gets exhausted onto the floor from the motor.
Solutions
1. Use less soap (Read the directions, you may be using too much)
2. Use a different kind of soap (The concentration might not be right for your machine)
3. Use a defoamer (Rug Doctor has a defoamer)
Nov 14, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
My shampooer leaks
you need a new tank old tanks cracked at the seal hoover came out wih a replacenent tank old tank will have a crack in it by the seal
Nov 09, 2008 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
