Question about Home
Water always run out of shower to floor in our starcraft outback. How do we avoid this?
  • 2,045 Answers
Use shower curtains
Posted on Apr 25, 2017
  • Noreen Price
    Noreen Price Apr 25, 2017
    oh I forgot to say the shower has doors.
The water wont shut off. the shower is always running with water
You need a plumber. They will turn the water off and replace the cartridge that turns the water on and off.
Apr 14, 2016 | Moen & One Handle Tub & Shower Faucet
My shower drain was running slow during a shower, and when i stepped out i realized that the toilet was leaking from the bottom -screw under cap on left side. i am at a loss and do not even know where to...
Yes water can back up in a drain and flood out lowest opening, which would be a toilet flange at floor level.
If tub is draining fine, then clog is probably near the toilet, but below floor flange level, and therefore not inside the tank ... judging from your description.
If you are in a house, go outside and see if there is a vent stack on the roof directly above toilet. If so, you can run a snake down from there.
You can also run a snake down through "s" shaped toilet trap and enter the pipe that way.
Another option is to remove the toilet and run snake directly down hole, and then reattach toilet.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 24, 2011 | Kohler - Toilet - Two-piece - Highline -...
When our toilet is flushed there is a lapse of a few seconds before the pump kicks in and during this time some water comes back up the shower drain. It does not seem to be waste from the toilet but we'd...
The plumbing under the slab floor has been roughed in wrong and without breaking up the floor and replaceing you cann adjust the floats in the pump pitr to come on earlier to avoid pit filling up as fast causing the waste to back up in the tub/ shower area.
Oct 26, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
When I open shower door after I have finished shower. Water from inside door goes on the floor, is there a catch all for the water
If the doors where installed correctly... the lip should be on the outside so that the water cannot run out onto the floor but runs into the shower instead...
heatman101
Apr 22, 2010 | Maax Shower Drain 10000041-105
I have a thermostat mixer shower but hot water has become minimal recently, even when water is piping hot from the taps? The shower is fed from cylinder tank on 1st floor, and cold water tank is in the...
The thermostatic mixing spool cartridge may be worn out. The low water pressure may indicate sediment in the cartridge as well. This can be easily removed by hand tools
Feb 17, 2010 | Grohe Integrated 1/2'' Shower Thermostatic...
I have a large whirlpool tub in MB on 1st floor. When letting water out of tub it is coming up in a large walk-in shower. The shower is draining fine...need answer! thanks
sounds like there may be some blockage in pipes. try to run a long snake through both drains or run all fixtures in bathroom and try plunging vigorously in tub and shower while running water. if nothing still, it may be possible that your underground plumbing is back graded or incorrect fittings and plumbing installation.
Jun 27, 2009 | Brasstech ''P'' Trap Kit - 3013
Water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Jun 14, 2009 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Dec 17, 2008 | Grohe Home
Rinnai R53 Natural Gas Tankless Water Heaters
It sounds like the Rinnai units are working correctly but you've got some plumbing problems.  Any tankless heater has a minimum water flow required to keep the burners going.  If the burners were going with very little water flowing through them to carry the heat away, the heat exchanger could overheat and fail.  The solution is generally to the electronic controls to set the desired temperature and then just use hot water.  Once you start mixing cold water in, you actually reduce the flow of hot water and the burners turn off.  If you are right near the cut off point, the burners will cycle on and off resulting in those very annoying hot-cold-hot-cold showers.
The fact that you've got those very loud noises indicates some other sort of plumbing problem.  Hooking up two tankless units in series is much more complicated. In heavy draw situations, the second unit is asked to finish heating the water up to temperature when the first unit couldn't quite get it there. Now you're putting hot water into a heater and heating it more.  You have a lot more issues with fluctuating temperatures and pressures within the pipes which could conceivable cause these horrible noises.  Everything's got to be set up right to for things to function properly and it's easy to get something wrong.
From your description, it sounds like a better solution would have been to mount the two heaters in different places. e.g. One in the basement to serve basement and first floor faucets.  The other on the second or third floor to serve those two floors.  Since these units are direct vent (don't use inside air), they can even be mounted in a closed closet as long as the vent can get to the outside.  With this setup you avoid the complexities of a series installation and you also have a much shorter wait time (and therefore less waste) for the fixtures on the upper floors.
Mar 26, 2008 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Home Logo
44 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
