Question about Cub Cadet Garden
I have a cub cadet riding mower that the coilpack needs replaced but according to the manual book it has two coil packs so how do I know which one is bad
  • 253 Answers
Test the Resistance on Each Coil Unplug the coil pack's electrical connector and use a wrench to remove the coil pack from the engine. Set the ohmmeter to the 20,000 ohms range and turn it on. With the meter leads, touch the spark plug wire terminal on each coil. This measures the secondary resistance, which should be between 5,000 ohms and 15,000 ohms. Next, check the primary resistance for each coil. Set the ohmmeter to the 10 ohms range. Touch one of the meter leads to the center prong on the electrical connector of the coil pack. Touch the other lead to the corresponding prong on the electrical connector. The reading should be between 0.3 and 1.0 ohms. Repeat the process for each coil.
Posted on Apr 24, 2017
How do i replace v belt on ltx 1040 cub cadet.
Nolan, Check the attached links,instruction and guides for belt replacement on Cub Cadet. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change the Deck Belt on Cub Cadet Riding Lawn Mower Using Model...
How To Install or Replace Drive Belt on Lawn Mower Cub Cadet
How to Change the PTO Belt on Cub Cadet Riding Lawn Mower
cub cadet belt replacement diagram Google Search
Jun 30, 2016 | Garden
I need a picture showing the placement of the 2 springs on the mowing deck of a 2011 Cub Cadet Ltx 1040.
Cub Cadet LTX 1040 and LTX1045 Riding Mowers - YouTube
? 2:24
Jun 10, 2013 - Uploaded by CubCadetCA Cub Cadet LTX 1040 and LTX1045 Riding Mowers. CubCadetCA ... How to Change the Deck Belt on a Cub Cadet Riding LawnMower: Using ...
Jul 25, 2015 | Cub Cadet Garden
I got a 50in cub cadet ZT came with a Briggs on it . I'm putting a 22 hp Kohler command motor on it. I need the specs for all the wiring from the Kolher command motor to the Cub Cadet
Look at the wiring color codes and their purpose in the Briggs manual, Compare to the wiring color codes and purpose for the Kohler engine in manual, connect accordingly.
Jun 15, 2015 | Cub Cadet Garden
Why is my Series 1000 LT1024 Hydrostatic Drive Cub Cadet not pulling?
In most cases the hydrostatic drives are not made by the company tractor or lawnmower.
This is in the owners manual.
Hydrostatic Transmission
The hydrostatic transmission is sealed at the factory
and is maintenance free. The fluid level cannot be
checked nor can the oil be changed. Always keep the
area around the transmission cooling fan free of grass
and debris at all times
Cub Cadet LT1024 Operator Manual
How to Change the Hydrostatic Fluid in Cub Cadet Lawn Mower
I hope that this can help. Tom
Aug 22, 2014 | Cub Cadet Garden
Manuals for cub cadet lawn tractors
Try running a google search for the model # you're inquiring about. Something should pop up giving you multiple choices on where to buy a manual.
Jun 21, 2014 | Cub Cadet Garden
No spark cub cadet 933E changed plug still no spark motor cranks fine
you may want to check the coil. under the coil there is a wire (kill wire) unplug it. try to start it, if it starts you have a bad wire somewhere. if it don't the coil is bad and needs to be replaced.
Nov 06, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I need an owners manual for a cub cadet riding mower. series 1000. model 1042 Lt. serial # 3430203833. thank you
Go to following site Then type in model LT1042 and check your serial no. again as I could not get it to come u.
Mar 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
32 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
