Question about Canon Office Equipment & Supplies
Have a new modem and can't connect to my canon mx459 printer? What can I do?
  • Brett Duxbury
    Brett Duxbury Apr 24, 2017
    Hi Steve Beasley, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    Does your new modem have a dhcp server ?
    does your canon mx459 connect via wireless , ethernet , ip address or usb ?
    Suspect your new modem has DHCP server and may be issuing different IP range than the printer had .
    What ip address is the computer . dos prompt then ipconfig and look up printer properties for port setting or figure out ip address of printer ?
How to connect my canon mx459 to my tablet
Via USB is the best way unless the printer has Bluetooth.
Jan 18, 2017 | Tablets & eReaders
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Cannon mx459 will not feed copies at ALL!!!!!. hAVE TO PLACE ALL COPIES ONE AT A TIME TO COPY. DO NOT HAVE TIME FOR THIS
Your ADF feed rollers are worn or dirty. Clean or Replace the rollers and it should pick up pages again.
Oct 13, 2014 | Canon Pixma Mx459 All-in-one Inkjet...
How to fax using canon mx459 all in one
Start by connecting it to your phone. Until you do that, it's not a fax.
Now put the document you want to fax in the document feed tray.
Push in buttons to dial phone, and away it goes. It's pretty easy.
Sep 11, 2014 | Canon Wireless Office All-In-One Printer...
Where is WPS button
canon mx459 printer instructions say hold down WPS button, can't find such button, where is it please?
Jan 11, 2014 | Arris SURFboard SBG900 Wireless Router...
How do I reset the language on my Canon MX459 printer?
You can change this from the printer setup by carefully timing the steps and counting your button presses.
First press Setup (at the top of the keypad) and wait about 5 seconds. Then press the Right arrow button once and press OK. Then press the Right button twice and press OK. Press the Right arrow repeatedly until you reach the end of the menu options. Press OK. Press the Left arrow once and press OK. Press the Left or Right button to select your printer's display language and press OK. Then press Stop to exit the setup menus.
I hope this helps.
Dec 27, 2013 | Cannon Office Equipment & Supplies
Canon Printer Printouts with Disappointing Results
First off...its new. Second...its under warranty and any time you mess with it, the warranty could be void. Contact the company for a replacement.
Jan 31, 2018 | Canon PIXMA Office Equipment & Supplies
32 people viewed this question
old marine
old marine
