Question about Power Computers & Internet
I just bought a sls qg-500avr and it will not power on the stand by button is lit up ANF when you push it it powers on for a few seconds and shuts off
  • Jimmy Taylor Apr 24, 2017
    Its a surround sound system iys electric
    Problem Solver:
  • 17 Answers
Sounds like a battery issue. If it uses rechargeables, it's possible that they either need charging, or if they're old, replacing.
Posted on Apr 24, 2017
PyroMan6x9x9
  • 150 Answers
SOURCE: No power on light
That's interesting.. After researching that model I can tell you that it has an intergrated internal power supply(transformer) which does contain a fuse. It is located where your power cord plugs into, inside the unit, start with that. Was it plugged into a surge protector? When you had the power failure the second time was there a fluctuation of power, ie your lights in your house flickering on or off or increasing, decreasing in brightness? This will help me determine if it's something else. Also be sure to check your power cord, look for any kinks, breaks, chips in insulation. Anyway Good Luck
Posted on Sep 30, 2007
SOURCE: Mitsubishi WS-55809 55 won't power up
Where is the reset button?
Posted on Jan 12, 2008
  • 236 Answers
SOURCE: Shuts off
Brian, you have a system failure in your audio amp section. this is a multiple channel amplifier and you have to get it checked only by service personnel. your power outputs transistor probably busted and your unit wont stay because that is your protection circuit working. it protects your unit from further damage.
and for the other comment, your unit will shutoff after long epriod of time at 70%, you need more ventillation to your unit. i would suggest that you use a small fan or blower and place on top of the unit. this will provide more air circulation to your amplifier. The units is tripping already at high temperature and 70% is already a long way to go at more than an hour with all channels working. adwditional ventillation only will help you. dont let it happen though always or it will damage you amp and end up like the later unit that turns off after few seconds. busted output stage already.
Posted on May 14, 2008
SOURCE: power on, few seconds off
Took it to the landfill today. Thanks for the reply!!!
Posted on Jan 26, 2009
SOURCE: Powers on a few seconds and shuts off.
check inside the battery compartment. mine did the same thing i check and the middle battery contact had fallen out
Posted on Nov 06, 2009
Runs when start button pushed for several seconds then shuts down. Starts with button, but when button released, shuts down right away.
Odds are that the ignition switch or wires are giving you the grief.
Thee unit will probably be getting spark power through the starter solenoid (look for a wire there) but when the solenoid is not activated, there will be no ignition power.
Take your time and trace it down.
You'll get it.
Cheerfuls!
Aug 17, 2015 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Starts runs for a minutes quits but if you keep pushing the start button it keeps running
Check rotor slip rings for cleanliness, brushes, stator resistance, rotor resistance. Then replace control board if they check out.
Feb 15, 2013 | Onan Cummins 4.0 KY-FA/26100 RV QG 4000...
Onan 5500 RV generator starting issue
Sound like a dead battery, or poor battery volatge getting to the unit. The clicking is fuel pump and or solenoid trying to pull in.
Sep 12, 2012 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
Press the "Resume" button four times once the green flashing has finished.
Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Push power button on, stays for few seconds, shuts down
The most comon cause is a faulty mode switch.
Mar 16, 2009 | Televison & Video
Computers & Internet Logo
37 people viewed this question
Top Power Computers & Internet Experts
john smith
vince
Sattech
Level 1 Expert
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
