Question about The Computers & Internet
Don't have any volume, checked settings and turn it up on the side, either process worked.
No sound tabletl
Turn up the volume on the sides. Try the settings key and look for sounds. Double check it is not on silent mode.
Jun 29, 2013 | Craig Tablets & eReaders
Tip
How to make your volume icon show up on your toolbar for Windows Vista
If your volume icon on the bottom right side of your screen is missing for some reason and you can't seem to get it to re-appear then this tutorial will help you get it back!<br /><br />This tip is for Windows Vista-<br /><br />1) Open your start menu and search for Regedit.<br />2) Open the Registry Editor<br />3) On the left side scroll up to the top<br />4) Open the folder HKEY_CURRENT_USER &gt; Software &gt; Classes &gt; Local Settings &gt; Software &gt; Microsoft &gt; Windows &gt; Current Version <br />5) Now if there is already a folder in Current Version you should right click and delete it. Now right click the folder Current Version and choose to make a new folder. Name the folder "TrayNotify" (The text is case sensitive so make sure to enter it exactly how I typed it.<br />6) Now exit out of the registry editor and press CTRL+ALT+DELETE<br />7) Open your task manager and go to the processes.<br />8) Find explorer.exe and right click and end the process.<br />9) Parts of your screen will disappear, if they don't re-appear then choose File and Run.<br />10) In run type in explorer.exe<br />11) Now your volume icon should be back!<br /><br />I hope this helped!<br /><br />
on May 17, 2011 | Microsoft Windows Vista Home Basic for PC
Volume increase on HTC Chacha smartphone
try this it might work, use another phone to call your phone and in the process of it ringing increase the volume by the volume side key and also do it for in-call volume
Jun 26, 2017 | HTC Chacha Smartphone
How do I turn the ringtone volume up? i set the ring setting to "vibrate and ring" and when I get a call from someone I sometimes feel the vibration but I don't usually hear my ringtone...how...
Hello patty,
Depending on the brand and model of your phone, there usually is a volume control on the side of your cellphone. If it doesn't have one, please reply here and indicate the brand and model of your phone.
Oct 16, 2011 | Cell Phones
I was unplug my main batter after i plugged back now my audio is not working .how do i resat my audio setup i don't have any system CD with me
Hello there,
First check to be sure that it is not the volume that is turned off. Try to increase the volume to see if it will speak out. Then you go to the menu, select the settings, then you select the voice, then you select the voice of choice, then you increase the volume. That should get the voice turned on for you.
Hope this helps. Goodluck Elect_Comp
Sep 02, 2011 | GPS
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
Cannot reduce water volume setting in program mode
I`m sorry, but there is no Reset function on this model. But you can try anyway; Turn off your machine to standby. Push and hold the P-key. If it works you get OK in the display.
If it don`t, you either just live with the problem (you can always stop any process by pressing a key) or you have to go to your nearest servicecenter and get the touchdisplay changed. This however, is rather expensive.
Jul 20, 2009 | Jura Capresso Impressa F9 Espresso Machine
How is the volume incresed on my tom tom one?
The usual process is as follows;
With the unit turned on and displaying the map, tap the bottom left side of the screen.
A sliding bar will appear at the bottom of the screen. You can now adjust the volume to your desired level.
The volume menu is also available by tapping and entering 'Preferences menu'. You can also set the volume from here if you wish.
Thanks for using FixYa.
Jul 08, 2009 | Tomtom One XL GPS Receiver
No volume
this is a simple fix, just go on to languge in settings and select a different voice let it process and you'll hear the new voice.
Then all you do is go back to the original voice and select that it will re-process and work.
Jun 13, 2009 | Garmin StreetPilot i3 GPS Receiver
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
