How do you take the to cover off a bottom loading unit
  • Washing Mach... Master
  • 3,094 Answers
Hello Rolf Golzlin,
Not-with-standing your belief we are all psychics...
awaiting your question...
"OYVAF1"
You need to disclose the make & model.
Your question
I went to all the trouble to look up your history... to see if you had submitted a series of interrogatives... tho...
Yet... just the one
In the immortal words of dubya... "bring it on"...
That being a CLUE AS TO WHAT IN THIS tiny world...
you might be referring... MAKE & MODEL.
(lose te notion we can read your mind).
Seriously...??
Carnac the Magnificent
Posted on Apr 25, 2017
How do I open bottom to unplug drain pipe?
There are three or four screws, on the very bottom lip of the lower cover under the door. They are a pain to get to and when I work on these, I usually have to lift the front of the unit to be able to access these screws. Remove the screws and lift the bottom of the cover towards you and remove the panel.
Jun 28, 2015 | Kenmore HE2 Plus Front Load Washer
MY WASHER KEEPS FLASHING F AND THEN A 2
well without a lot to go on ,
i'd guess your drain is plugged ,
unplug unit
remove the bottom cover ,
3 spline screws on bottom front,
open the large handled plastic cover in center an git a light an look in it , clean it out .
May 14, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Wcvh6800j1ww leaking under soap dispenser
Three screws at the back of cover, three screws at the front, push the cover back and you can remove it. 1 screw at the front of the soap drawer and two more on the dispenser and you can lift the whole unit up.
Sep 24, 2012 | GE WCVH6260F Front Load Washer
How to replace ink cartridge
1 Make sure the All-In-One is on. 2 Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy. 3 Grasp the tabs on the cartridge lids, and then lift the lids. 4 Remove the old cartridges. Store them in an air-tight container or dispose of them. 5 If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6 Insert the new cartridges. Make sure the black print cartridge is secure in the right carrier and the color cartridge is secure in the left carrier, and then snap the lids closed. 7 Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to power source.
Dec 02, 2010 | Lexmark X1270 All-In-One InkJet Printer
Wash load stops with a few minutes left and unit alarms f02, don't see any visable drain problems
Hi, pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F02 error code
The reason for F02 error is due to something stuck inside. Pop off the front cover (3 Torx screws on the bottom lip) After removing the cover you will see a white plastic unit with a screw on cover on the front. Unscrew the cover (no tools needed). Pull the cover off then remove the strainer. It will have gray gook on it plus God knows what else. Clean the strainer in the sink replace screw the cover back on and your in business
Thanks for contacting Fixya.
Nov 03, 2009 | Kenmore Elite 45986 Front Load Washer
My Maytag top loader leaks at the bottom of the bucket. I took off the front cover and should see that the wahser at the top of the shaft is leaking. Is this an easy fix?
not easy, unit must be stripped to allow access to bottom seals and bearing/s. Special tools needed and a goog knowlege of the wiring.
Sep 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water is leaking out of bottom....
youll need to get behind unit nad removeth back cover, from there run a load to determine where the water is coming from.. i guess ou cna start by checking the rubber boot just inside the door, run your hand around it lookin for holes/tears
Jan 26, 2009 | Frigidaire ATF6000ES Front Load Washer
CDP 265 5-disc player
If the disc is actually loading but won't read, try cleaning the laser lens with a cotton swab. Unplug the unit and remove the cover to access the laser. Spray a small amount of glass cleaner on the swab and gently wipe the lens of the laser assembly. Use the other end to dry it and remove excess dust. The only way you can tell if the disc is loading is to remove the top cover and observe if the disc at least loads and spins. If it does, try that procedure.
If the disc doesn't come up to the loaded position and spin (spin the disc by hand to confirm this), your gears may be out of alignment. Take the disc out, and use a screwdriver to manually turn the gear from the bottom of the unit. The gear should be visible through a small hole in the bottom toward the front of the unit. Take a slotted screwdriver and turn it until you see the laser assembly come up to the clamp that holds the disc in place. You may have to force it slightly if the gear has skipped a notch, it might "pop" as it goes past the tooth. Make sure you are turning it in the same direction as it moves when loading a disc! Once you do that, the laser should come up completely and be able to clamp the disc and read it.
Dec 06, 2008 | Sony CDP-CE275 5-Disc CD Changer
Noisy spin dryer
make sure the washer is level.there's locking nut for each legs sometimes thy become loose and the unit becomes unlevelled after a while. Level the unit side to side and front to back and relock the nuts by tightning it against the bottom frame. If thats not the problem,run it on spin only with no load and see if it would do the same if it does'nt then your problem could just be improper loading. make sure you have enough load to cover the drum when it spins.Other wise you may have shock/spring problem but very unlikely
Jul 22, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
