Question about Stihl Garden
Stihl 170 does not start with brake engaged, but will start easily with brake off. Unable to pull rope with brake engaged.
    Top Expert:
  • Stihl Master
  • 12,744 Answers
Not suppose to start with brake on --the brake is a safety shut off it stops the clutch drum
Posted on Apr 24, 2017
Testimonial: "recommended by sthil to always engage the chain brake prior to starting chainsaw"
How do I cure kickback when starting a Stihl 044 chain saw , as soon as you pull the starter cord it snatches it out of your hand it really hurts.
pull rope just pass compression piston top dead center release rope let it rewind fully .then pull rope quick and firm.
Oct 10, 2017 | Stihl Garden
Sometimes when I try to pull start my Stihl FS 36 weedeater it just free wheels and other times it will start. What could be causing this?
The mechanism is beginning to wear out. When you pull on the rope, the turning action pushes pins out from the center of the rope pulley that engage to turn the engine. These pins wear out and will eventually fail, not engaging at all. These pins may or may not be available for purchase at the small engine parts store near you, but the entire pulley assembly with new pins usually is.
Jul 04, 2017 | Cars & Trucks
Stihl saw problems it won't start and flood fuel in to the air filter why is this ?
There are several conditions and situations that this can occur, but let's try the most common. This is also for any STIHL saw that was manufactured before 2014, after that, the M-Tronic saws have a different starting method.
Normally this happens when the engine fired and it was not audible, and the rope has continued to be pulled with the choke on.
This method is approved, but EXTREME caution should be used, and the CHAIN BRAKE must be used.
CAUTION: Do NOT use the drop start method, this is not an approved starting method under any circumstance!
1) Place the saw on the ground that is clear of debris.
2) Set the Chain Brake
b) place the toe of your right shoe thru the rear handle,
c) support the saw top handle with your left hand,
d) pull the recoil with your right hand.
3) Make sure the choke is NOT applied, place the master control lever in the start position (one notch above the choke position)
NOTE: at this point, it helps if a second person can hold the throttle at the full or wide open position.
4) Make 6 rapid pulls (a few more may be required), you should hear the saw start to sputter, keep the throttle open until enough rpm is obtained that YOU the Operator can gain control of the throttle (the other person stands aside now in a safe position) and remove the chain brake. Keep the throttle open until the saw starts to run properly.
*NOTE 2: The chain brake is designed to not only stop the chain in case of 'kick back', but also is to be used in starting the saw until you have time to gain full operational control of the saw. However, extended rpms above clutch engagement can damage the brake band, overheat the drum bearing, damage the clutch shoes and clutch drum.
Feb 25, 2017 | Stihl Garden
Rope hard to pull 025 c Stihl chainsaw
Can you give a little more detail, ie.
1) the last time it ran, was it running properly
2) what was the last time it was fueled
3) how old was the gasoline/fuel mix used
4) what is the condition of the air filter, spark plug
5) will the rope pull easier when the chain brake is applied, then if it is not applied
6) will the rope pull easier if the bar and chain is removed
Feb 12, 2017 | Stihl Garden
My stihl 038av wont engage the flywheel when I pull the start rope it just pulls free
Starting assembly probably needs new spring and/or reattachment.
Jan 02, 2016 | Stihl Garden
Stihl fs 86
I am a Stihl mechanic. We tell all our customers that the proper starting procedure for a Stihl is as follows. Turn on the switch. Set the choke lever to full choke. Prime the primer bulb three times(if it has one) and pull the pull rope NO MORE THAN THREE TIMES with the choke on. If the unit has not tried to start after the third pull, open the choke lever and pull till it starts. Sthil carburetors are notorious for flooding after pulling the rope more than three times on choke.
Oct 08, 2013 | Garden
Stihl trimmer FS85 broken pull start rope can this be replaced easily?
Somewhat, but if you have NEVER done one successfully before, and have been show basically how to do it, including the most common knot to use and how to tie it, you should really find someone who knows for sure how to repair it before attempting it yourself and firing the recoil spring into your eyes or something.
Aug 13, 2013 | Stihl Fs80 Line Trimmer Hardware
With the plug removed the starter should pull very easily. When trying start did the cutter head try to spin? If yes clutch springs may need replacement
Jul 24, 2013 | Garden
Petrol stihl
Stihl machines have a plastic pawl in the rope pulley, a small r clip retains the pulley and creates some friction on the pawl, as the pulley turns the clip tries to stay still due to the tention this in turn drags the pawl out and into the flywheel drom, so you either do not have enough tention on the r clip, or the small plastic dog has broken.
Feb 09, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
