Question about Philips Computers & Internet
I have a philips model#52pfl3603d/29 will it work with wi fi for netflix? thnx
Silverblade
  • 173 Answers
SOURCE: Wi-Fi problem Toshiba A15-S157 laptop
If your laptop has a di-fi switch/button chances are you have one integrated on the main board of the laptop, check if the wi-fi adapter is installed properly by going to the Device Manager and check Network Adapters normally a wi-fi adapter will show up if not check if you have any devices listed under network devices(Network Controller, Ethernet Controller). Now if the wi-fi card is installed and the status on the Device Manager say's that it's working properly, you may now check your laptop for a 3rd pary wi-fi utility/application that manages your connection look for it on the System Tray on the lower right hand side near the clock or go to all programs and look for any WLAN utility, when you open the utility make sure the wi-fi radio is turned on or enabled.
Posted on Nov 05, 2008
  • 6 Answers
SOURCE: Unable to connect to wi-fi
I think it is saying that the wifi "card" is set so that it is not being configured by windows.
In XP
Control panel > Network connections
Under LAN or High-speed internet you will see an icon labelled wireless network connection. Right click on this and then click properties. You will see three tabs at the top
General - Wireless Networks - Advanced
Click on wireless networks
There should be a tick-box saying Use windows to configure my wireless network settings. I expect that, in your case, the box is unticked which means that the software supplied by the vendor of the wifi card is configuring the settings. I find that it is usually more reliable to let windows do it.
So tick the box and click OK. You may then have to reboot.
Posted on Jan 05, 2009
Jack_Dawson
  • 287 Answers
SOURCE: DRIVER PCI MODEM & WI-FI FOR NOTEBOOK A*NOTE MODEL CL51-14
search it with ur model no. on Google Serach !
Posted on Jan 07, 2009
  • 6 Answers
SOURCE: I can't get our Samsung Blu-ray player(Model
I am not an expert a "tinkerer"at best but I do have the 3600 like you and I have no problems connecting. Make sure there aren't any spaces or special characters in you router name. Follow your instruction manual and get the 3600 connected first then try netflix: Menu, setup, network, set your settings and it will tell you available networks, choose yours, enter your security code then do a connection test. If its not connecting at what step are you having a problem?
Posted on Jan 10, 2010
I bought a Samsung mod h5003 tv how do i set it up to watch streaming movies from netflix
Unfortunately your model Samsung is not a "smart TV" or WI-FI. Your only option to view Netflix is by connecting a laptop or PC by HDMI with internet/browser access. Or, you can purchase a DVD/Blue ray player which has WI-FI and Netflix built in App among several other services. I recommend the later. Hope this helps.
Nov 13, 2016 | Samsung Computers & Internet
Why can't we connect to Netflix?
Your tv is not on the internet. Sure your wi fi is working. But if the tv set's wi fi is not connected then you will never connect with net flix.
Get your tv connected and then .....................
Sep 15, 2015 | Motorola Mobility Smart Controller -...
Will the above model support Netflix?
Yes, the TV itself does have a Netflix app built-in. Is the TV currently connected to the internet? If not you might have to hardwire it using an ethernet cable or hook up a wireless bridge. See page 13: https://docs.sony.com/release/KDL40Z5100.pdf
One trick is to use a wi-fi range extender/wi-fi booster with ethernet port.
Aug 18, 2015 | Sony KDL-52Z5100 LCD TV
HOW DO I CONNECT TO WIRELESS INTERNET
If you do not understand how Wi-Fi works, it would be best if you hire someone or ask a friend.
May 06, 2015 | Philips 55PFL4909/F7 55-Inch 60Hz LED TV
How do I get Netflix on my Philips blue ray
Have a Wi-Fi connection available that the player can talk to then punch the menu button for Netflix.
Dec 04, 2014 | Philips Televison & Video
My router type is WRT54GR and does not connect my Philips TV
1. Make sure your WRT54GR router is operating in wireless mode.
2. (a) if your Philips TV has Wi-Fi built-in, go to Step 3.
(b) if your Philips TV does not have Wi-Fi built-in, check to see if it has one (or more - unlikely) USB port. If it does, check with Philips technical support if that port will accept a USB-based universal Wi-Fi adapter. If they say yes, go buy one and plug it into the USB port on your TV and go to Step 3.. I bought a universal Wi-Fi adapter for my Sony Bravia TV at Walmart a few years ago for $50. You can also ask Philips support if they can recommend one certifified for your TV model.
3. Use the Menu or Settings button on your TV's remote to set up a network connection. Follow the on-screen instructions or use the TV's manual.
If the suggestions in 2(a) and 2(b) do not apply to your situation, there may be a third solution: using a powerline networking kit, but this is more complicated, costlier and requires that your TV be equipped with an Ethernet jack.
Hope this helps.
Oct 19, 2014 | Computers & Internet
I have a subscription to netflix at home lhave wi fi at work how do I change my settings on samsung tab with affecting my home account
As long as you have the Netflix icon on your tablet you should be able to sign in without changing anything. It doesn't matter what wi-fi that you're using as long as you work wi-fi doesn't block access to Netflix.
Sep 11, 2014 | Samsung Tab Tablets & eReaders
My netflix wi-fi is not working going to my tv
Your network setup may be wrong or incomplete.
It's also possible that this particular model of dvd player
does not have network capability.
Nov 21, 2013 | Computers & Internet
Not really a problem...yet...I have Verizon and have 6100F Westell Modem/Router. I would like to purchase a blue ray player and get Netflix...I know I need a blue ray player that works with Netflix...what...
If your object is to get Netflix on your TV, and not knowing what brand or model TV you have nor whether or not you have an existing wi-fi system, that question is a little difficult to answer. For example, I have Suddenlink cable, wi-fi, and can access Netflix and other similar providers through either my TV or TiVo, although I always go through TiVo. You may need to update your TV.
Sep 18, 2017 | Westell Wirespeed ProLine 6100 Router...
What year was toshiba satellite 2410-S203 pc notebook first launched?was it equiped by WIFI?
My sources indicate 2003.
It has > Optional
http://www.csd.toshiba.com/content/pr/html/Satellite%201410%20and%202410%20Press%20Release%20%289-24-02%29.html
The Wireless Antenna On-Off switch is on the Right side. The Wireless Antenna LED is to the left of the On-Off switch. It glows when the wireless antenna is in use.
It has to have an > optional
Turn the laptop over, Front facing you.
The Battery Compartment is on the Front Right corner.
The Wi-Fi Compartment Cover is on the Back Left corner.
Remove the single screw in the right middle of the cover. (Philips head)
See if a Wi-Fi PCI Mini Card is installed.
No?
You'll have to obtain a Wi-Fi PCI Mini Card for your Toshiba.
From a quick search just now, (Not advertising for this website),
http://www.impactcomputers.com/p000339520.html
(Remember to remove ALL power to the laptop Before installing. AC adapter {Charger} and Battery.
Also remember to observe Anti-Static Precautions before handling the Wi-Fi card, and when installing)
Here is the Toshiba Satellite 2410-S203 Notebook PC User Manual, also,
http://www.fixya.com/support/p265858-toshiba_satellite_2410_s203_pc_notebook/manual-14885
Nov 16, 2010 | Toshiba Satellite 2410-S203 Notebook
Computers & Internet Logo
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
