Question about Palm TX Handheld
My Palm TX resets when I try to turn on the WiFi. It use to work. I had to change the screen and since then it doesn't work. Tried Hard Reset no help. Thanks in advance for any help.
  • waynesel Jul 24, 2009
    Did that, doesn't fix problem.
Hi there
This is a very common problem with this device. A hard reset usually does fix the issue but you will lose all your data and settings on it, so be sure to backup any files first.
To do the hard reset, turn off the device, hold power, soft reset, release power when first splash screen disappears, confirm deletion of all data.
It will then restart to factory default and Wi-Fi should work now.
Posted on Jul 24, 2009
Have to reset Palm TX to power on sometimes
I have a palm TX and it usually just sits for a minute or two when I use blazer. I have also found out that the pda will always reset itself and it only freezes when it has a lot going on. It stays frozen for a while, but eventually unfreezes. As for the home button, it's probably worn down. My power button and my up button have almost completely stopped working.
Sep 09, 2009 | Palm TX Handheld
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
My Palm TX device is not initializing. it says "palm powered" then a loading bar starts at the bottom of the screen, then it turns off...and it repeats the same thing over and over again.
Have you tried a hard reset? In case you need to know how...Hold Power button on Top of Palm down, then press reset button, then release reset button and continue to hold power button down until second Palm logo comes on screen and progress bar at the bottom of screen completes. If you release the power button and it asks which language you want to use you have done this correctly.
Jan 21, 2009 | Palm TX Handheld
WiFi Icon on Palm Tx not showing on taskbar
You should try reloading the software back into the TX. In order to do it, you will have to erase your TX memory. Make sure you back up your files first.
To erase the memory press the reset button until the reboot screen appears. Hold down on the power button until the erase memory screen appears. Select yes. Reload software from Palm CD.
Jun 05, 2008 | Palm TX Handheld
Palm TX erratic touchscreen
Change the screen. You can have the part here, as well as directions on how to change it:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ObjectPath=/Shops/demo132390
Apr 16, 2008 | Palm TX Handheld
The palm powered icon
To do a hard reset, hold down the power button, press the little reset button, release it, then release the power button.
Make sure you back up your TX first.
Jan 29, 2008 | Palm TX Handheld
Palm TX handheld turns automatically on and off.
If you tried a hard reset, and it is still happening... then it may be a hardware problem. Is it still under warranty? You may want to exchange it for a new unit.
Dec 16, 2007 | Palm TX Handheld
Wifi
Its probably conflicting with some app. My palm has gone into infinite reset loops till I did a hard reset. Back up your data, and do a hard reset. (THIS WILL DELETE ALL DATA, AND RESTORE FACTORY SETTINGS)
(hold the power button, and press the reset button, release the reset button (keep holding the power), wait till you see the ORANGE screen (after the loading bar), and release the power. )
Oct 10, 2007 | Palm TX Handheld
Palm Tungsten t5 WiFi
I suspect that you're in fact holding a Palm TX and not a T5 as the T5 does not have WiFi. If you're using the Palm SD WiFi adaptor, do a hard reset without the card.
(hold down the ON/OFF button whilst using the reset pin to press the reset button. You'll be asked if you are sure you wish to reset. You'll then be prompted to choose the language caliberate the screen etc..)
After that. Go and download all the updates and drivers from Palm Web site.
Oct 04, 2007 | Palm Tungsten T5 Handheld
Palm TX Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
