My carbon monoxide is beeping without any power or propane hooked up
  • 2,913 Answers
It is possibly reaching the end of life or has detected an internal fault or the internal battery is low.
If the CO detector is 10 years old it could be telling you it needs replacing. I suggest you refer to the original instructions.
Some CO detectors are sealed for life and not intended or designed to have a replaceable battery so a low battery alarm would be the same as the end of life alarm.
Posted on Apr 24, 2017
  • Heating & Co... Master
  • 2,458 Answers
Battery needs changing ? some only last a few years then you have to exchange it . Try blowing it out maybe dust inside it .
Carbon monoxide detector
There is a good chance that the detector is being set off by fumes. This could be from hairspray, cleaning solutions, air fresheners, etc... Most aerosols use propane as a propellant and this will absolutely (and should) set the alarm off.
Nov 20, 2013 | KZ 2013 Sportsmen Classic 200
How can I shut off the beeping when my carbon monoxide monitor is accidentally pulled out of the wall?
Unfortuanely, you can't. The loud beep is in place to alert you to the issue so that you don't get carbon monoxide poisoning.
Jan 10, 2013 | Home
My carbon monoxide detector just has one sold beep and is not plugged in.
I assume you mean your carbon monoxide detector has one solid beep, and it is probably an AC unit. It may be safe to assume that it has battery backup if it is beeping without being plugged in.
First, you may replace the battery with a new one, plug it in and hit the reset button. If that doesn't work, you could bring it in to your local fire department to have it tested.
Check the expiry date on the Carbon Monoxide Detector. It should be replaced if it is more than 5 to 7 years old, check manufacturer recommendations.
A replacement carbon monoxide detector will give you the protection you need and peace of mind. Your safety depends on how fast you deal with this issue.
Jul 07, 2010 | Kidde Nighthawk Combo Gas/co Detector
How can I shut off my Kidde carbon monoxide detector when beeping
Here is the link to the manual for your Kidde model KN-COB-LCB-A
Carbon Monoxide Detector. This may help you solve your issue.
You may find more related information on my website. If you need a replacement or you need to add additional Carbon Monoxide Detectors in other levels of your house, you can purchase them here.
This issue should be solved immediately, Carbon Monoxide Poisoning can only be avoided by making sure you have good working CO Detectors in your house, camp or recreational vehicle.
Jul 24, 2010 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk Kidde carbon monoxide detector keeps beeping every 25-30 seconds. Do I need to buy a new one?
Some models of Carbon Monoxide Detectors will give an audible beep every 25-30 seconds after it has sounded an alert alarm. This may have happened when there was noone home to hear it. A periodic beeping sound may also indicate it is time to change the battery.
Solution: Install a new battery and check your manual for instructions on how to reset the system. Check the expiry date on your unit, it needs to be replaced after 5 to 7 years, according to the manufacturer specifications.
If you are in doubt that your Carbon Monoxide Detector is not working effectively, REPLACE IT. Your safety and your peace of mind is worth it.
View most Brands and Models of Carbon Monoxide Detectors online.
Jun 27, 2010 | Kidde Nighthawk Combo Gas/co Detector
My carbon monoxide detector keeps beeping in spite of replacing thebattery and gives an error code of E09. Also it keeps flashing an err on the led redout. I placed it outside and it is still doing it...
Hopefully you have found a solution for your Carbon Monoxide Detector issue of October 4, 2009. The best solution for a questionable CO dectector is a replacement.
A Carbon Monoxide Detector is the only thing that will read, detect and sound an alert when reads dangerous levels of CO levels in your house. A defective carbon monoxide detector will give you and your family a false sense of security and will give you no protection.
Whenever in doubt, always err on the safe side and replace Carbon Monoxide Dectectors, your life depends on it.
View my website for related information and compare brands and models of Carbon Monoxide Detectors available for sale online.
Oct 04, 2009 | Kidde Nighthawk Combo Gas/co Detector
Burning eyes and sore throat when heater is on
This heater should only be used in a very well ventilated area, the sore throat and burning eyes are from carbon monoxide.
Carbon monoxide is potentially fatal.  I cannot express how dangerous this is if used in a house or garage without the doors open
Please be careful and let me know if I can provide furthur assistance.
Lone99star
Mar 02, 2009 | Reddy Portable Forced Air Propane Heater...
Does it produce any dangerous gas....?
all gas heaters produce obnoxious fumes. some more than others. natural gas produces carbon monoxide, carbon dioxide, hydrogen sulphide etc. propane produces carbon monoxide, carbon dioxide and water vapor. incomplete combustion produces high concentrations of carbon monoxide. check your air-gas mixture for better combustion.
Dec 22, 2007 | Honeywell HZ-3220BW Compact Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
