Question about Boating
I have a 1997 SeaRay 330 sundancer and the exhaust will be at a regular noise level while i'm crusing and all of a sudden it will get louder. any ideas???
  • 4,483 Answers
Exhaust noise will change if the engine tune changes but in that case there would usually be a change in performance at the same time.
If there is no change in performance, the most likely cause of a fluctuating increased noise would be a change in the exhaust - it could be one of the boxes breaking up inside, assuming boats have some sort of silencer box. Boats are unusual territory for me.
Not only are boats unusual territory but power boats are quite alien - I know it is usual practice with cruisers to exit the exhaust at or below the water level and to use the exhaust as an exit for the engine cooling water. It would seem a sensible conclusion in that case to assume a change in exhaust note/volume would be a symptom of an engine cooling problem/blockage.
Posted on Apr 24, 2017
Chevy Blazer Service Engine Soon light is blinking and temperature is slowly rising. There is plenty of oil in the car, water level seemed low so added water, now all of a sudden there is a loud rattling...
engine soon flashing is a urgent code (P0300) it is multiple misfire and the result is converter catalyst could be red and create exhaust leak
I am concern about misfire it is very dangerous for converter and fire in the car or melted carpet
find out the code retrieve
Oct 03, 2013 | 1997 Chevrolet Blazer
1983 f150 with 351 windsor. Recent problem of bogging down when climbing moderate hills. Also sounds of ticking noise, lifters or manifolds leak? Any help much appreciated.
A leaking exhaust manifold could make a ticking noise. So could a lifter or valve. The exhaust noise would be louder under load.
If the carb is running too lean, or you have a vac leak, the lean fuel mixture could make the exhaust leak worse, and cause the loss of power.
Dec 19, 2012 | 1983 Ford F150
I have a 93 honda accord tuat is sputtering. It rarerly sputters on the interstate. Only in neighbor hood driving. I have replaced the valve cover gasket, sparkplugs/wires, fuel filter, air filter, and...
An exhaust on a vehicle is made up of several different sections that transport used combustion gasses from the vehicle's engine to the back or side of the vehicle. The pipes incorporate several silencers (mufflers) to reduce noise. If you notice a sudden increase in noise from your vehicle, especially when you rev the engine, you probably have a hole in your exhaust.
------------FGTech Galletto 2-Master EOBD2 V51
Nov 30, 2012 | Cars & Trucks
Have loud noise from engine,gets louder w/more rpms.it is an automatic,60k miles.no exhaust or muffler problem.
Serpentine belt tightener pulley bearing was bad, made a loud noise. I replaced the pulley (jobber part) and the noise level was reduced enough to notice the waterpump was also making a noise ... more revs = louder noise. I am now replacing the water pump. (approx 60k Miles too).
Nov 22, 2010 | 2004 Toyota Corolla
When accelerating the vehicle is louder than norrmal. Could it be intake ot exhaust mainfold problems. Under normal conditions it runs great. Under a load somewhat noisy. Lexus finds nothing wrong?
This may just be from a muffler starting to fail internally. However a broken exhaust gas recirculation tube is likely to blame for this. This tube will run from the catalytic converter to the engine smog pump or recirculation pump. If this tube has a hole or is broken you may only notice this noise when the EGR valve is open or the Emissions control pump is on.
Jul 30, 2010 | 2004 Lexus RX 330
Magnatron suddenly making more noise. Much louder
Often over the years the Transformer laminations can loosen, from the on/off rising and collapsing magnetic fields, and then they sorta hum louder. I suspect this is what is going on. Shouldn't be too much of a worry.. keep an eye on it tho.
Jan 20, 2010 | GE JVM2070 Microwave Oven
Dryer making a louder than normal noise when drying
Possibly the roller, I would have to hear it to be sure, but if it sounds like a clunking noise, it is probably a roller, if it is more of a high pitched whine, or a sound like a penny in a vaccum you probably have something stuck in your blower.
Dec 18, 2009 | LG DLE5932S Electric Dryer
Have a 'winding' noise that gets louder the faster
sounds like a wheel bearing they start to scrape and bind making loud noise while driving only. no noise while in park
Aug 24, 2009 | 1997 Ford F150 Regular Cab
I bought a 1997 Dawoo Esspero and the motor is very noisy.can any one tell me wot the problem could be.
the engine is loud as in the exhaust? maybe you are hearing lifters clatter? louder or more noticeable at idle or as you climb a hill? take a look at the oil level on the dipstick. if you have a low oil level and some engine noises then the noises go away when you add the correct amount of oil that would be normal. hope that helps
Jun 10, 2009 | 1999 Daewoo Lanos
07 ford mustang gt MAKING a whining like tire but louder noise from the rear when crusing just had the rear differential gear replaced and housing
Do you know if the correct fluid (plus the required friction modifier) and fluid level were used? I'd take it back to where you had the work done and have them take a look at it and confirm the above if you don't know. If the above is correct, I'd think there is still something wrong inside.
Jul 23, 2008 | Ford Mustang Cars & Trucks
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
