GPS Logo
J
Jarrod Posted on Apr 24, 2017
My new Lowrance Hook-5 GPS isn't working, I'm a noob, how do I get this function working?
5 Related Answers
Anonymous
  • Posted on Aug 07, 2008
SOURCE: Lowrance LCX-16ci - screen's gone out
I have a working unit with a bad antenna. Interested?
[email protected]
Anonymous
  • Posted on Oct 28, 2008
SOURCE: lowrance 330c gps unit
A "soft reset" can be accomplished by pressing and hold "Pages" key and press and hold "PWR" key till USA map comes on , then release both. A "hard reset" requires press and hold both "Z in" and "Z out" buttons and press and hold "PWR" button releasing all three when USA map appears.
Anonymous
  • Posted on Jun 06, 2009
SOURCE: Transducer for LOwrance HDS-5
is the HST-DFSBL lowrence transduser combatible whith HDS-5 unit?
dacdiver
  • 9 Answers
  • Posted on Jun 24, 2009
SOURCE: lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Anonymous
  • Posted on Oct 21, 2010
SOURCE: Need a fully working Lowrance 250C GPS Sd card
I have had a similar problem and founf this site where you can get a new card that will work for your GPS. Info, pasted below:
The Nextar GPS-MAP09SDC SD card with updated navigational maps and information has a MSRP of $69.99. Please visitwww.nextar.com to purchase the map upgrades and for more information on upgrading your maps.
2answers
Lowrance hds-5 will not power up. lowrance will not work on if out of warranty. does anyone?
most the time its a bad key pad when unit wont power on and what it cost to repair you can buy another one check the pins in the power cord see if there not broke or bent yes they break take a 12 volt test light see if you have power going to power in the plug that connects to back of unit if you have power . . .bad key pad
The GPS component of my Lowrance Elite-5 Gold is malfunctioning about 50% of the time.
Hey Les, Since you have replace both the unit and transducer, you have eliminated/diagnosed most of your problem.. Its in the wiring... sometime when I am in full GPS mode I get erroneous depth readings..?? Have you tried a different GPS module (the "puck")?
https://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5-7_HDI_OM_EN_988-10647-001_w.pdf
2answers
Lms 520c 5" Screen Color External Gps And 200 Khz Sonar System: I have a Lowrance LMS 520C on my boat. The GPS wi...
I have the same problem on my 520C.
I have no solution but I hope you have find some?
Best regards
Dan
1helpful
Every time i turn on my lowrance 520c it says gps module not resp
I had the same problem. Sent my entire unit back to Lowrance, but they said it was fine. One year later, I find out that I did not receive or have the correct parts to hook up the GPS unit. I needed the NMEA 2000 T connector and terminator plugs. Look at your manual and hook it up the way the manual says. It will require a NMEA 2000 T and at least one 60 ohm terminator plug. Seems the GPS module sends back some kind of signal that if not absorbed by this thing will mess up your unit. Mine works since I got it hooked up correctly. HD
25helpful
Installing the Lowrance HDS 5
You do not need the data cable connected unles you are hooking it up to other electronics, ie computer, second GPS sounder ect. You only need to conect the red to the positive on the battery and the black to the negative.
2helpful
2answers
Lowrance HDS-5 won't load Navionics
You may just need to update the softwear on the GPS, you can download it directly from Lowrance.com along with instructions on how to install it.
2helpful
Loosing position on GPS
I hate to be the bearer of bad news, but it sounds like your internal module is on the fritz. I am pretty sure you can buy a external puck and a harness and it will work perfect. I did that with my hummingbird 997.
Keeps blowing fuses
It has a short in the wiring which is "not user fixable". I think the wires are crossed. Take it back, they need to repair or replace it. I suggest you replace it. Take the GPS with you show you can show them the problem. If you bought this on line call Lowrance and find the nearest repair center. Repair it yourself and you loose the warentee.
Top Lowrance GPS Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
ADMIN Eric
ADMIN Eric
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
