Question about Grilling
Replacing the control valve on a model 1204. I can't get the old valve off of the grill front. There is a cover that I cannot remove blocking the acces.
SOURCE: CONTROL PANEL REMOVAL
noavatar_s.png Navycpowif
Rank:nonexpert_s.gif Apprentice
Rating: 100%, 1 votes
This is NavyCPOwif- As you read above I have a crazy Maytag H20 as well!
I am a research person so looked around a little last night and found a site. for DIY folks. Every one is halving the same problem. I suggest a civil action suit !!! But in the mean time I am going to have my Navy Avionics Technition husband tackle it rather then deal with Maytag right now. " cost almost as much as a military fighter jet, so he should be able to do it!" BUt I wanted to pass this information along to other DIY folks out there. We have not done it yet since ours just went crazy Friday night. So we disconected the door /water connection. But everything else seems to be working fine at this point. Serious about the class action suite!!! these should be recalled we bought ours in GA June 2006 so it seems that the ones made in the 2006 time frame are the ones with the issues- I assuem that the folks that are having problems with in the 7 8 month time frame have the same lot due to ours is 18 months old but we paid $2600 were some have paid $1500.00. So not sure but something needs to be done becouse the list of other issues with this fridge seems pretty long and very expensive.... Good luck!
Site to fix panel issue: for $3 to $20- DIY:
I have just fix my maytag M#MFI2568AEB at a cost of $3.00 Believe or not. You need to go to website hhttp://68.195.103.87:8083/liny/maytagice2o.htm Everything you need is on the site. (yes gets Maytag off the hook, but gets your fridge going quicker)
DIY site for those interested:
http://forums.partselect.com/refrigerator-freezer-repair/maytag-ice2o-digital-board-going-crazy-3189.html
Comment by Navycpowif, posted on Jan 17, 2008 We fixed our ourself with the information I posted above- cost was $5. no problems.... no new panel just 2 circuits.
Posted on Jan 24, 2008
SOURCE: JVM1750SMSS CHARCOAL FILTER INSTALL
I just installed a JVM 1540 with the same grille. I removed the two top phillips screws before mounting the oven as I cannot access these screw heads once the oven is installed. It took me about 20 minutes of fiddling with the grille to figure out (no thanks to the manual) that the grille needs to slide to the left to release so you can change the light bulb/charcoal filter.
Posted on Oct 28, 2008
SOURCE: Cannot remove the front grill of GE Micro to replace filter
I have a new ge 1540 and needed to remove the grill to install the charcoal filter.
After removing the two screws on top, you need to slide the grill about 1/2" to the left. Then the grill will wiggle loose and can be removed.
Posted on Dec 11, 2008
  • 27 Answers
SOURCE: replace valve cover gaskets on subaru svx
the truth about thse engines is they are hard to work on. if the valve covers are unbolted and still ****, try getting a rectangular peice of wood and putting it on the side of the cover neer the gasget, tap on the other end with a hammmer from all angles to try to break the seal.
this is a common problem with valve covers that havent ever been removed and they heat up, and cool down so many times they practically bake onto the head
Posted on Nov 18, 2009
  • 3 Answers
SOURCE: need to replace steam valve on delonghi magnifica coffee machine
the steam valve will pop off it comes straight out
Posted on Dec 05, 2009
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
One of three burner tubes is completely yellow, the other two blue. why?
Te one that is yellow probably has a spider's nest blocking the Venturi Valve on that burner. The Venturi Valve acts as an air intake valve, for mixing the right ratio of air to gas, when the burner is burning.
Remove that burner and you will see the Venturi Valve on the open end of the burner that faces the control panel. It may have 2 slots or on each side of the burner tube, covered by a screen. Brush the screen with and old tooth brush to clear them. Also, check all the burner ports for clogs and clear those with a sewing needle. But, do not enlarge the holes. While you're at it, it would be a good idea to remove and clean all the burners, as required Annual Maintenance.
To assist you in properly removing the burners, I have included a link the the Owner's Manual for your model grill, in case you have misplaced yours. You can download & print the manual for future reference.
http://help.weber.com/manuals/pdf_files_2011/Gas/Genesis%20SilverGoldPlatinum/OwnersGuides/Genesis_LP_OwnersGuide_Plus_55826_103005.pdf
I hope that all the information I have provided will help you troubleshoot and solve the problem
Happy Grilling and thanks for choosing FixYa.
Aug 23, 2011 | Weber Genesis Silver B Grill
I have a sony model kdf-e42a10 and I'm trying to replace my screen. However, I have removed all the screws for the top to the bottom, but can't find the bottom screws. Help please.
Remove front speaker grille block assembly as shown in below image then remove screws under that cover to take off front screen as rear screws have already been removed.
Hope this info will help you.
Jul 11, 2010 | Sony Televison & Video
Need help re: replacing igniter of Gas Grill
If it is like mine, you have to remove the front control panel on the side burner and the front of the side shelf. Remove four screws behind the fronts below the shelf/burner and then you will have access to the screws to remove the main control panel. Be careful with all the hoses and gas piping. If the electronic ignitor is melted like mine(i am on #3), you have more problems than the igniter. I had to replace the burners and the gas valves to stop the flame from "backing up" into this area. Hope this helps.
Jul 10, 2010 | Jenn-Air Grilling
Sony 1292 - the red tube seems to always run at full output. There is a most distinct red cast to everything. When the projector is idling, with no input present, the blue and green tubes barely glow,...
remove front bottom panel and turn RED screen drive down it will be on your Focus/screen drve control block 3 controls on top for focus R/G/B and 3 below for screen drive to tubes R/G/B
Dec 07, 2009 | Televison & Video
Oil return blocked?
Oil around plug boot on that car is due to leaking valve cover seals.If you remove the valve cover,you will see big O rings that go around each of the plug holes,Just replace valve cover gasket set and problem should be solved.While you have it off,tou can look at the return for obstructions.
Jan 09, 2009 | 1997 Dodge Intrepid
01 s40 idle air control valve- hard to replace?
your IAC valve, idle air control valve is under the black plastic cover on the front right corner on the engine, remove cover undo valve, renew gasket and re install. ade 13 years volvo tech
Nov 10, 2008 | 2001 Volvo S40
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Gas coming out near burner knobs
The issue is with the valve that is connected to the knob. it is poorly designed. To fix it take off the lid assembly and remove the front black cover that covers the knobs. remove the almost diamond shaped metal piece that the knob shaft runs through. put on your gas tank and adjust the valve to a position where no gas comes through.. might be lucky or you will have to replace that valve.
Oct 14, 2007 | Coleman Roadtrip Grill LXE 9949-750
Grilling Logo
79 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
