Question about Home
I have a Howard Miller clock model number 613-180 stop runnning but when I move hands will chime. It has been wind all the all 3 winding holes.
3 Suggested Answers
  • 12 Answers
SOURCE: What ports wind what?
On mine, the center one (@the 6 position) is the one that keeps the pendulum swinging. It is the one that lengthens the most during the week and if I forget to wind it, that pendulum is all the way down when the clock stops.
Posted on May 02, 2009
micromatikal
  • 2777 Answers
SOURCE: Howard Miller GF clock -
How long has the clock been running for since it stopped? Sometimes it takes a few cycles before they sync back up... How long was it "stopped" for?
Thanks
Tim
Posted on Sep 10, 2010
Howard Miller grandfather clock keeps good time but chimes are off and five hours late
If you need to ask how to fix it, it probably means you shouldn't be tinkering with it.
You have something that represents a fair chunk of money and it would be wise to consult an experienced horologist about your problem or perhaps consult the manufacturer.
The cure might be as simple as removing the hands and putting them back to coincide with the chimes but it is presumably a fault that developed over time. I doubt the hands moved their relative positions by themselves but rather something inside happened.
Owning a mechanical pendulum clock is a hobby that requires some basic knowledge about how it works and how to care for it. The hands should never be turned backwards, for instance. Changing the time for daylight saving means either stopping the pendulum for an hour or advancing it by an hour and pausing at each quarter to allow the chimes to sound fully. Any mistakes will mean winding on many hours or stopping the clock and waiting.
Dec 26, 2017 | Howard Miller Office Equipment & Supplies
I need parts for my seth thomas westminister ave marie clock I need the swinging mechanism the clock is a mantel clock, the bar and head is missing a parts list would help
Howard Miller Clock Parts ' eBay
www.ebay.com/bhp/howard-miller-clock-parts
eBayHermle 2115 Ave Maria Westminster 2 Chime Quartz Clock Movement ... hermle hamilton ridgeway howard miller seth thomas, clock winding key #7/4.00. $9.99.
Clock Repair & Replacement Parts - Movements, Motors ...
timesavers.com/c-325738.3-clock-repair-replacement-parts-movements-...
Items 121 - 180 of 249 - Front Plate - Seth Thomas #2, #77 Movement ... of #2, 77 movement parts that have been in storage since the 1970s. ... Hermle #2115Westminster/Ava Maria Quartz Movement ..... My Account; Login/Register · My Cart.
Jan 27, 2016 | Westminister Time Warp Shelf Clock
My Howard Miller wall clock Westminster chimes is one hour off. ie: It chimes twice at 1:00 Any suggestions? I have it for at least 25 years and never had this problem before. Thanks! Stacy
Gently move the hour hand to the 2 O'clock position, then using the minute hand cycle the time forward until it is at the correct time.
Tim
Main Page
Jan 06, 2016 | Home
I have an electronic Howard Miller wall clock that chimes but is two hours behind the time showing
Move the hour hand counterclockwise two hours back and then just move the minute hand clockwise until the correct time is set.
UsedClockParts.com
May 28, 2015 | Home
How to reset a chime clock
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
Jul 10, 2014 | Home
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
How to operate howard miller clock 645-342
Make sure all winding springs are wound well- but not overly tightened and set pendulum in motion. The clock needs to level across the face and front to back to work correctly. Time can be adjusted by moving the hands of the clock via the minute hand- allow it to strike once at each strike interval to keep strikes synched to clock time, and fast or slow can be adjusted by either the adjustment onthe pundulum arm or on the mechanism where you see an arc with "F" and "S" on either end.
Depending on model, it will need winding at least as often as the name of the clock type- in other words, a seven day clock should only need to be wound every 7 days.
Sep 17, 2012 | Welding Tools
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
Nov 06, 2011 | Seiko Mantel Clock
Chime strike on middle of 1&2, 4&5, 7&8 and 10&11 instead of 3,6,9 and 12.
We understand your question:
The hand has a center bushing with the square hole in it.Remove the hand and use a pair of pliers on the bushing in the minute hand then re-clock or rotate the bushing back on the quarter hour then replaced it back on the clock.
Hope this tip provides some workable ideas for this repair.
R/
David
Orlando
May 19, 2009 | Miller 645-586 Clock Radio
May 02, 2009 | Watches
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
