Why has my smart tv not got all4 instald?
When i got the telly thats why i got it as it shows in the pictur that it has all 4 on the telly
2 Suggested Answers
  • 38 Answers
SOURCE: x box stays on and telly blurryy but showing the picture?
It sounds like bad soldering, your tv doesn't freeze it's your xbox video/audio output that does. Did you use the towel trick, that is one possible way to have gotten it. You should send it to Microsoft for repair.
Posted on Mar 15, 2009
I have had my sanyo flat screen tv for 1 year. The picture on 4 different stations is "snowy", the rest of the channels are fine. On my Sony DVD player I get audio but no picture. It is also 1...
These units are close enough to the warranty end period that I would suggest that you contact Sanyo and Sony requesting warranty service. Talk to a supervisor and be persistant. It may take a few calls.
Keep us posted.
Dan
Apr 18, 2008 | Televison & Video
How do I access advanced menu options so I can adjust overscan settings?
get to the on screen tv menu and look for aspect ratio change that ,save and exit
May 18, 2015 | Toshiba 32ZH46P
Have ps3 that was working fine, unhooked it from one tv to another and proceeded with holding the power button 5 seconds til it beeped twice and still have blank screen
hi, if the ps3 was working fine on the other tv and you have not dropped it or anything like that then this would point towards their being a fault with the lead of the connection in the back of the telly.
what you should do is unplug it all again and refit all the leads in the back of the ps3 making sure they are pushed in far enough then plug the lead into the back of the telly making sure you push it in far enough, then switch the telly on and then switch the ps3 on if the telly dont change to the correct channel as soon as the ps3 comes on then you need to get the telly control and put the tv on the correct channel.
now depending on how many inputs the telly has would depend on how many times you press the button on the control, the button you need to press is going to be on of the following its either av, input,source,ext,aux, or a picture of a rectangle with an arrow running from left to right, now once you have found this button make sure your ps3 is on with a game in then press the button on the tv remote then wait couple of seconds it may say something like av1 on the telly if this dont show the ps3 then press it again it should then go to av2 and keep going until you see the game on the ps3 you need to keep going until your telly is on the right input channel.
once you have done this your ps3 should be working again.
let me know how you get on or if you need further assistance ok
May 25, 2010 | Sony Playstation 3 (PS3) Console
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Convert normal tv to hd tv
HELLO
If the set you are trying to convert to HD is just your everyday standard VHF/UHF analogue TV - basically forget it! I am given to understand you cannot make your standard telly show HD pictures.
Sorry! That is, of course, anyone else knows different.
Sep 20, 2009 | Televison & Video
X box stays on and telly blurryy but showing the picture?
Mar 14, 2009 | Microsoft Xbox 360 Console
Cleaning rear projection screen
I read in the manual for the Sony KDF 50E3000 that you should use warm soapy water on a clean cloth if you aren't able to remove it with a dry cloth. I find that the microfiber cloths work best.
Feb 11, 2008 | Televison & Video
5 BLINKS
My first guess is IC 702 in the crt drive circuit. You could open the back and unplug the "C" board from the back of the crt and then power it on. If the set comes up and you have good audio that will isolate the problem.
If IC 702 is the problem you'll have a couple of other things to check, R533 .47ohm 1/4 watt fusible resistor and C541 22uf 100v both on the "A" board because they tend to stress when IC 702 begins to leak. Replacing IC 702 and not the resistor and cap could cause 702 to fail again.
If IC 702 is not the problem then it could be the flyback.
Hope this helps!
Bill
Nov 05, 2007 | Sony KV-28FX60 28" TV
White line horizontially through middle of picture
A repair like this is in the vertical drive/output section of the TV set. It could be a simple capacitor causeing this problem or a combination of the capacitor and the output IC. A repair like this should not exceed 120 to 150 US. Is it worth that to you? How much can you replace it for? Good Luck PS please dont forget to rate this thread.
Oct 25, 2006 | Bush 5693D 24" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
