How does detergent drawer for cleaning - Washing Machines
2 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: Can I remove the detergent drawer in a hotpoint hvl241?
There should be a release tab in the dispenser, push down, pull out
if NOT
Remove the screws along the rear top of the washer,lift the top, remove.
Posted on Nov 08, 2009
Testimonial: "Many thanks for the quick reply "
I am not able to remove my I desist detergent drawer. I have followed the instructions in the manual and video but it does not come off. I am not able to clean it.
1. Open the detergent drawer.
2. Press the release lever (A) on the inside of the detergent drawer and pull the detergent drawer out at the same time.
Jul 10, 2017 | Washing Machines
Detergent doesn't dispense from the drawer
Remove the drawer and clean it thoroughly, also clean the drawer area of any detergent residue. Check that there is water flow into the drawer from the inlet nozzles above it.
Make sure you are putting the detergent in the correct drawer compartment. If it still persists further investigation of the feed in and out pipes will be required..
Apr 17, 2017 | Washing Machines
Liquid detergent won't dispense properly.
Pull out the dispenser drawer as much as you freely can. There is a tab that you can depress to pull the drawer out completely. You can then rinse it completely with hot water to ensure it is not clogged.
Mar 06, 2015 | Washing Machines
Detergent drawer
Just take out the detergent drawer and clean it, this used to be because it`s jammed, full of detergent
Jan 03, 2013 | Washing Machines
No insttuctions to open detergent draw it is now smelly
detergent drawers can be completly removed from your machine and cleaned usually a slide or latch type mechanism on the drawer itself push the tab in the back of the drawer downward to remove the drawer
May 18, 2010 | Washing Machines
Soap drawer is filled with water
Our 2 year old washer just started seeing this problem. After removing the detergent dispenser drawer from the washer, cleaning it and cleaning the slot it came from we stopped seeing water retention.
May 09, 2010 | LG WM-2277HW Front Load Washer
Water is pouring out of the detergent dispensing drawer from my 1 year old Samsung clothes washer model WF328AAW. When I opened the drawer, it was full of water. Something must be plugged. Is there...
Pull the drawer out you will find detergent has built up in side the dispenser probably from from way too much detergent, modern front loaders work best with a small amount of detergent and liquid detergent normally will wash better.
Apr 17, 2010 | Samsung WF203ANW Front Load Washer
Have a Miele W320, during the rinse part of wash cycle, water pours from underneath the detergent drawer. What can I do to stop this happening?
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
Feb 18, 2010 | Miele W320 Front Load Washer
Front load washer leaks from the detergent drawer in the front
try taking the drawer out and clean it thoroughly, including the underside of the drawer, then clean the inside of the machine where the drawer fits into. Sometimes a build up of dertergent can casue this problem
Dec 28, 2008 | Kenmore 46462 Front Load Washer
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
