Question about Dryers
My dryer quit singing at start and stop - Dryers
Whirlpool dryer runs, hums, then quits
Sounds like the motor is on it's last legs. Replace it. But, before paying huge money for a motor and the labor to install it, I suggest that you price a new dryer and compare it to the repair costs. It may still be a little more for a new dryer, but....IT'S NEW!
Mar 20, 2017 | Whirlpool Dryers
Dryer won't start..light clicking noises
There is a switch inside the unit that stops it when the belt breaks or comes loose. Check that.
Mar 15, 2017 | LG Home Applaince LG DLE2101W 7.3 Cu. Ft....
Burnt factory-placed fabric/foam inside Kenmore Dryer
Why it'd appears to be scorched I have no idea. The purpose of that fabric is to support the front of your drum and allow a non abrasive surface for the weight of drum and cloathing to slide on during use. The cloth you have in yours has been changed to silicone or other types of teflon type surfaces. John T.
Mar 02, 2013 | Dryers
Dryer won't start
Either one or 2 things happened. The move cause the lint to shift around inside the dryer and it overheated blowing the fuse. OR the new apartment's vent is blocked and caused the dryer to overheat. All maytag dryers are not the same but they all have a non resetable fuse mounted on the blower housing. When the temp exceeds 350f it melts and kills power to the motor. If the motor is not running the heat does not get power. The motor must be turning to make the cent switch power up the heater. Dryer manuals
Dryer videos
Sep 03, 2012 | Maytag Dryers
Maytag dryer stated when i push start button, then stop aft 10 mi
Hi, OK let me help. Do you hear any noise coming from the timer?
Whe it quit the first time, did it start right away or did you have to wait for a bit to restart it?
Vic
May 30, 2009 | Whirlpool LER4634J Electric Dryer
Car turns over but wont start
if you have spark after you turn the key off the module is bad in the distributer replace it and you will fix the problem thank for your ansewr.
Feb 04, 2009 | 1992 Honda Accord
Dryer starts and then quits
You have a faulty heat safety switch. This switch prevents the dryer from overheating and causing fire. Some dryers have as many of 4 of these switches (seems redundant but it prevents fire) Depending on how confident you are with repairs the back of the dryer can be removed and the switches can be replaced. Most of them are circular and are found along the dryer exhaust area. I do recommend that this repair be done by a professional if you do not have allot of experience yourself because of the safety factors involved. Good Luck!!!
Nov 07, 2008 | Kenmore 63932 Electric Dryer
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
Dryer stops after 5 minutes
dryer moter is covered with lint and over heating.if the moter is not completely burned out `you mite clean it with air pressure .if it still does it `replace it.
Feb 21, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
19 people viewed this question
Top Dryers Experts
