Question about Dewalt Saws
My DeWalt 735 runs but the blades dom't turn.What is wrong?
    Habit-Forming:
    New Friend:
  • 35 Answers
Stripped gear or spline
Posted on Apr 25, 2017
Testimonial: "I found the problem by accident. The nut had come off the shaft that holds the blades whitch caused the belt to come off."
My Dewalt 735 planer won't turn on. I blew the house fuse a few times, it would start after I came out. Now it won't start at all and it's been a couple days
The 735 draws 15 amps, which is the rating of typical lighting circuits in homes. The receptical in the wall is sometimes 15 amps although those circuits usually have 20 amp breakers. Since you said "fuse", it might be a bad fuse or even the wiring between the two. Circuit breakers go bad also. If you can confirm the receptical supplies voltage, it is time to check the 735.
Unknown if the device has a termal switch inside. I doubt it would go bad, but you implied a resting period allowed it to run several more times after the fuse in the basement was replaced. If it reset once, it should do it again. If you can find a diagram, there might be a fuse inside, but someone would have to take it apart to check.
A motor can get so hot that a solder joint inside can let loose and it will never run again. Sometimes the coil (windings of the motor) can short out (melt together) and this will increase how much current goes through it and also generate more heat and melt more windings together. Besides producing a smell, your house fuse would burn out real quick.
I had a chuckle over your 2nd sentence but I dare not say why. If it started after you came out (of the house), why did you not run it for a longer time?
A motor requires more power at the instant of turn on. 15 amps of running current will require 20 amps or more when starting. "slow blow" fuses (vs quick action) and circuit breakers can deal with the short period over current requirements.
Nov 23, 2015 | Dewalt Planer (DW734)
Dewalt 735 planer trips overload a lot. New blades, thin cut no difference. Run it, without wood, it trips. Overload switch? Checked everthing. Turns free with chains off. Bluespook
id check the feed roller drive or feed rollers them selfs I find due to pressure there under most times they get flat spots in them from sitting makes for a hard start to planer
its best to back off tension rollers when storing these and keep them bearings lubed up well
and yes it happens to sealed bearings too
Apr 28, 2015 | Garden
Dewalt miter saw
The bearing may be getting ready to fail. The blade should not be difficult to turn.
Dec 18, 2013 | Saws
Dewalt 735 screws holding knives in place get stuck and won't come out
My problem exactly. Very hard to change blades. I've used wd40, heat, drilled out center of screw, but more of them get stripped all the time.
Dec 13, 2012 | Dewalt DW735R Reconditioned Heavy Duty 13"...
The drive belt on a dewalt 735 planer dosnot track
The pully which quides the belt must be perfectly level in both the horizontal and vertical positions. Use a metal square to check alignement and adjust using adjustment screws.
Apr 25, 2011 | Dewalt 13 in Planer
I need instruction manual book of DeWalt DW 735 planer to replace the blades
Hi mmh9894,
You may view the manual. Click the link below.
http://lib.store.yahoo.net/lib/tylertool/DW735m.pdf
Hope I help you.
Have a nice day!
Thanks for using Fixya.
Feb 24, 2011 | Dewalt DW735R Reconditioned Heavy Duty 13"...
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
http://servicenet.dewalt.com/
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
When running thru an 11" wide board thru my Dewalt 735, the board always tracks off to one side. Why?
the knives may not be completely square on the cutter head, which may cause wider boards to track due to uneven depth of planing. if the rollers are worn or perhaps crooked somehow, this can also cause tracking of boards. same thing for the base, if it is worn, bent, or otherwise not setting properly it can also cause the boards to move like that.
Dec 05, 2009 | Dewalt Tools & Hardware - Others
Husqvana saw
Looks like you need a better explanation of what's going on here.
Dec 11, 2007 | Dewalt DW746X 10" woodworker's table saw...
Saws Logo
78 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
ken skalski
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
