Question about Garden
Ha been mowing stopped for awhile will not engage the starter now, battery ok
    Problem Solver:
  • 17 Answers
There may have been condensation in your gas tank, especially if the mower had not been used over the winter. If that's a possibility, I would recommend that you dispose of the gas currently in the tank and try some fresh gas.
Posted on Apr 24, 2017
My Snapper NXT2346 just stopped while mowing checked battery is ok, no power to starter or safety switch, changed fuse, seat switch check seemed to be ok - any suggestions?
Those tractors have a few safety switches and they all have to be engaged in a closed position for you to have ignition and have unit operate. Did you check the obvious ? - ignition switch?
If it just stopped dead while you were mowing then the ignition had to have been interrupted. That switch powers both the starter and ignition circuits.
Sep 11, 2016 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
Starter will not engage
check all 3 safety switches,seat,clutch deck
Jul 05, 2015 | Garden
Bought a Toro Timecutter SS 4235 about a month ago. Mowed the lawn about 5 times. When I turned it off after the last mow it made a funny sound. When I went to start it today I got nothing. Checked the...
Could be your battery shorted install known good battery, make sure key off. Install positive cable then slap negative cable to negative post if no spark then install. Sit on tractor and try to start as usual if you have problems starter circuit probably starter bad. If not try engaging blades if problem, pto wire grounded or clutch winding bad. If everything OK then shorted battery.
Sep 22, 2017 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When I engage the PTO clutch, the amp light comes on my 1641 cub cadet. I have new battery, pto clutch and stator. I can mow for awhile, but when I turn the PTO clutch off, I can't engage it again because...
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Nov 07, 2009 | Garden
Mower blades engages but when I stop to empty grass they will not
yes it is there is one under the seat & under the dash & there is also one connected to the clutch/ brake peddle which is more than likely the one giving you problems is the clutch/brake peddle switch
Jun 22, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
It seems I have a Battery problem,when I turn key to start all I get is a clicking sound.Put new battery in same thing, after trying several times it starts and runs find.If I stop after mowing to put gas...
first check all wires mainly starter cable connections both ends ground cable both ends and make good and sure they are getting good clean conection also check all your safty switchs for blade ,seat and clutch brake and any others that may be o n your machine if this dont cure it consider replacing the starter relay its the little do dad in between the starter and the battery the positive battery cable hooks to it.... hope these tips cure your problem sounds most like a bad ground or a short in your secondary wiring to me good luck keep me posted if these tips dont solve the problem we will go from there mrdmburns@cableone.net
May 01, 2009 | Garden
Cranks fine, won't "catch"
From what u describe, I believe u have a starter and possibly a flywheel problem. When u turn the key to start the car, the starter gear engages w/ the flywheel, turning the flywheel, which turns the engine over. It sounds like the teeth of the flywheel and starter are worn, (they should mesh together smoothly) which would make the grinding noise u describe. If this is the case, the flywheel and starter would need to be replaced, and its a labor intensive job, as engine and trans. have to be separated to remove/install the flywheel. The rrrrrrr sound could be the starter gear spinning but not engaging. The starter gear extends on a shaft, then engages the flywheel. It is possible the gear isn't moving forward on the shaft, just spinning w/out engaging, making the rrr sound. So, I would recommend u remove the starter and have it tested (many parts stores will do this for free) and check the teeth on the gear to see if they are worn or broken. U will also be able to see a portion of the flywheel after the starter is removed, and u should check the teeth on it also. Let me know what u find, hopefully it's just a starter problem, and the flywheel is ok.
Dec 30, 2008 | 1991 Buick Skylark
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
