Question about Garden
My DW735 runs but the blades don't turn, I there a belt some where I need to replace?
  • 14 Answers
SOURCE: I started the mower but the blades will not turn.
Most all riders have a safety seat switch now and they do malfuction alot. They are under the seat and are ez to replace most of the time. First look for a wire that is grounding due to rubbing a sharp object. That can be fixed with black tape
Good luck!!!
Posted on Jul 10, 2011
  • 640 Answers
SOURCE: The mower blades don't properly
This can happen when the engaging mechanism on the mower deck can not move properly. This could be because there is debris on the deck that is causing interference. It can also happen if you have some corrosion on the deck that is resisting proper operation. So, clean the deck, this is best done by removing the deck. It usually is not very hard to remove, just remember what you pulled off and how it goes to put it back together. There may be half a dozen pins to pull and then move the cable or linkage, raise the mechanism and the deck should slide out pretty easy. Inspect and clean the deck. Then manually manipulate the tensioning pulley, this may take some force to do, depends on the one you have but you should be able to do it by hand. Lubricate if necessary. While the deck is out inspect the belt for wear and replace if necessary. Reassemble and test.
Please rate if this was helpful.
Posted on Jul 11, 2011
  • 6468 Answers
SOURCE: ariens ezr 1742 blades stopped while mowing, belts is good, blades turn freely, motor runs and machine moves
are you getting power to the electric clutch?
Posted on May 21, 2012
  • 159 Answers
SOURCE: blades don't engage on model LT170 tractor
either your belt/s need to be replaced, or one of the tension pulleys either under your tractor, or on your deck is bad
Posted on May 30, 2012
  • 6468 Answers
SOURCE: I have a Wheel Horse garden tractor Model 417A. Engine runs, but blades (and belts) don't turn.
check for power going to the electric clutch if so look at the wires near the clutch thet break off there as well
Posted on Oct 02, 2012
My dewalt planer dw735 just made a loud pop sound. Then, a piece of metal launched out of the dust ejector, a few sparks flew. I tool the top od and found a hunk of wood that broke of the board jamming the...
have you checked you have not taken a chunk out your blade. also you have to make sure the blades are set spot on. other wise it will affect the balance. good kuck
Dec 20, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Replace v belt on dw735 planer
REMOVE COVER SO YOU CAN SEE THE BELT, PULL THE BELT AS YOU TURN IT AND IT SHOULD COME OFF
Nov 07, 2014 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Why burning belt on 48" Craftsman riding mower
Since you mentioned "48-inch riding mower" let's assume your question is about the mower deck and not the overall mower or its main drive belt (if manual shift-on-the-fly model). If the belt burns that means it is running but slipping against something; or that the drive sheave us turning against an impeded belt. In the first case the belt will be burned along its length; in the second the burning will be occuring in one location(s) along the belt. In any case of belt slippage, check first that all tensioners (springs) are properly in place and not broken or fatigued and in need of replacement. The only other thing would be resistance to belt running, such as:
blade blockage; blade rotor resistance from lack of grease or ruined bearing in need of replacment; grass clogging on deck underside or under blade drive pulley on deck top side; a pully sheave out of round; an obstacle between belt and sheave that is preventing free turn of sheave and belt run; misrouted belt; an overstretched belt that cannot be sufficiently tensioned. Inspect and correct or replace as needed.
Aug 19, 2014 | Craftsman Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Blades don't engage on model LT170 tractor
May 30, 2012 | Garden
I started the mower but the blades will not turn. I shut it off and was able to manually turn the blades by hand. I also was able to turn the belt wheel under the engine and have it turn the blades. ...
Good luck!!!
Jul 10, 2011 | Husqvarna 23 Hp 48" Deck Yard Tractor
We own a Dewalt DW735 13" planer. Have lost or misplaced the owner's manual. We need to reverse the knives for the first time, and do not know how to do it.
Unplug the machine then crank open the head up as far as it will go. Underneath, in the middle of the head you'll find two feed rollers and a cutter head with the blades on it. Even dull the blades are very sharp so work carefully. Each blade is held in place by a blade holder and eight allen screws. Remove all eight allen screws and the holder and blade will fall out. If they have excessive sawdust or tree goo on them they may need a bump from the plastic end of a screw driver to knock them loose. Keep track of how they come off so you can put them back on the same way only with the blade turned around. The top of the blade holder will fit into a channel in the blade so they'll all go back in lined up correctly. Turn the cutter head carefully to get at the other blade(s) to change them.
Nov 15, 2010 | Garden
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
