Caption turn off to on
Remote fxfj
Fxfj programming sanyo tv remote conrol
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
Sep 07, 2014 | Sanyo Televison & Video
Sanyo fxfj remote control
What were you programming into the remote? How is it behaving now?
Jan 23, 2008 | RCA Universal Remote Control
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
Aug 23, 2011 | Televison & Video
Lost remote, somehow child turned on closed caption without remote,how do I disable closed caption without remote?
Find a button on the tv manual control said Menu,press it. Goto tv menu find and turn off all CC1,2,3 and text 1,2,3.U should have no more closed caption.
Sep 12, 2010 | Philips Magnavox 20MS233S 20" TV
How to remove closed captioning on tv screen
Press the Caption button on the remote control to cycle through the caption options until OFF appears. If there is no Caption button on the remote, go to the system menu and turn captions off in the caption submenu.
Jan 08, 2010 | Philips Magnavox 20MT133S 20" TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
Mar 28, 2009 | One For All URC-4330 Remote Control
Closed caption for durabrand
if you have the menu button on the tv itsself then you can go from there to remove th closed caption
May 10, 2008 | Durabrand DWT1905 TV
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
String test
Possibly the closed caption feature on this set has been turned on. There is a button on the remote control that says Caption. Press it until you turn the caption off. This will not be on a universal remote, only the original remote. You can also turn this off through the caption section on your on-screen menu.
Jan 22, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
