Question about Amana Washing Machines
Amana washer starts to fill with water for like 7 seconds or so n just stops.
    Habit-Forming:
    New Friend:
  • 35 Answers
Hot or cold setting
bad pressure switch. Rare
model? Newer?
Posted on Apr 25, 2017
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Washer over flowing
you either have a bad valve, bad air switch, or a hole in the air tube leadinf to the switch. An easy way to check the valve is turn the washer on and while its filling unplug it. If the water stops immediately you valve is probobly ok. if it takes a few seconds to stop or doesnt stop at all your valve is bad
Mar 25, 2011 | Amana ALW480DA Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
Kenmore Elite washer will not stop filling
Dirt in your solenoids may be a problem. But other than that it could be bad solenoids in general. It could also very well be that the unit that senses the water level has a part broken. On the inside there is a tube that connects to the tub. When you add water it increases the pressure in the tube and signals the shutoff. Sometimes the connections on this tube go bad.. or the tube itself gets a hole.
Easy way to tell. Start the unit with the on/off switch. Wait a few seconds then turn it off again. If the water flow doesn't stop you're most likely looking at a solenoid problem. If the water flow stops when you turn the switch off then you're most likely looking at a problem with the water level sensor.
Jul 29, 2009 | Amana ALW880WH Top Load Washer
Amana Model NPW5400TQ0 Washer
REPLACE THE TIMER OR Power control BOARD
Jan 30, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Washing Machines Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
