Question about Fisher Washing Machines
My GWL11 Fisher &Peykal washer stops at rinse light light. Return water flow is very slow compared to what it was full flow.
Opened the vale no blockage at all - still stops at rinse light and stops again ... also see soap suds in the tub - recirculation water is very slow, after coup of try the rinse cycle finishes
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 35 Answers
Diverter valve bad or most likely partially plugged, restricted, held part way open by debris if water also comes out the drain at the same time this is the problem could also be bad control board but likely just plugged valve. Chean out debris and start checking your pockets better these machines will take up to dime sized debris and this is the result
Posted on Apr 25, 2017
Testimonial: "Thank you very much. I will try this weekend."
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
My GWL11 fills water continuously. Checked drain hose for siphoning and everything seems okay; lowers into drain pipe only 2 to 3". The water continuously flows even when advancing to the rinse cycle and...
the valve is getting stuck in the on position. a new valve should rectify this problem. if not, then the motor controller water valve circuit is faulty and you should replace the motor controller.
Sep 22, 2013 | Fisher and Paykel GWL11 Top Load Washer
560uf, 250wv capacitor leak on GWL11 fisher peykal washer controller
I have never seen these capacitors leak.
Is it a clear substance over the hot & cold circuitry,
It's to water proof the mosfet's from moisture.
Check the fuse near the AC input jack on the board (top left)
Jun 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher & Paykel GW608U water flowes for a short time then stops then starts again and stops this is repeated untill the following lights show the first and sixth lights come on (Long wash and...
Hi just read your posting.Now the error code you have is error code 132,this means you have a single current trip error.This means the wiring to the motor and rotor position senor are faulty or one of the 3 phases on the motor is open circuit, or your motor controller is faulty. Do you have, or can borrow an electrical test meter ?To find the exact cause I can guide you throe the steps to test the machine if you have a test meter.Please reply for further help.
Jun 16, 2010 | Fisher and Paykel GWL11 Top Load Washer
Stops before rinse cycle... won't drain or spin.
The REGULAR CYCLE button turns the drain pump on or off. The REGULAR LED will turn
on when the pump is on. This feature can be used to drain the tub. You could get a bucket and lay the hose on the fllor. Gravity will drain it down.
Sep 07, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel GWL11 Cold Water Not Flowing
you can swap the hot and cold valves over and see if this fixes the problem as it sound like your cold valve is faulty but not the hot valve.
Cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washer
Sounds like you could need a new out of balance switch or bracket, also try to make the clothes evenly spread in washing machine on rinse if they clump up on one side of the bowl they will cause out of balance :)
Sep 07, 2008 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
