Question about Binks Air Tools & Compressors
Hello, this is Dave. I have three Binks BBR Automatic Spray Guns. I am looking for a manual and parts list? Can you help me?
5 Suggested Answers
digritz
  • 530 Answers
SOURCE: binks bbr converting from pressure to siphon
Worked in paint repair shop for 18+ years. Every time we had that issue it was the wrong air cap. The particular model we always had trouble with was a Devilbiss JGA going from a pressurized system to a 1 quart cup. But the Devilbiss and Binks are quite similar.
The air cap from the pressurized system would actually cause a reverse pressure in the cup.
Both air caps were for this gun. Also the Devilbiss
rep said they should be interchangeable.
They weren't. Try a different air cap.
I'm kind of curious so please let me know if this works for your Binks.
Posted on Aug 12, 2009
  • 760 Answers
SOURCE: No suction
This model comes in either suction feed or pressure feed. For example a 6211-4307-9 is a suction model. There are different air caps and needles depending on feed style. I assume your'e using either a 82-545 or a 82-555 suction cup attached to the gun. Make sure the tubing is tight, and that the vent hole in top of the cup isn't clogged. See Binks.com for detailed tip combinations.
Posted on Jun 30, 2010
  • 176 Answers
SOURCE: looking for an owner manual/ parts list for the 8 c superfast pot
Hi Go to email callahanronald@att.net, I have 2 left
Posted on Jul 27, 2010
  • 14 Answers
SOURCE: I have photo copy of binks bbr spray gun with feed
To my understanding there is no "BBR" gun with cup (only pressure/suction feed). And there are two versions: on the older one there is only written "BBR" on the gun, the newer one states "BBR" and "HVLP". Both are predecessors of the Mach1. What are you exactly looking for?
Michael
info@sprayfinishingstore.com
Posted on Jun 02, 2011
How do i fix spray pattern from being heavy on both ends on a binks m1g
I simply stumbled upon this article about spray patterns. Also, the tip, seat and spray cap MAY simply need a good cleaning.
I usually soak all related parts in lacquer thinner overnight to help loosen any build up, then wipe with a good, lint free cloth.
The article: Spray pattern problems solutions
Hope this helps.
Jun 27, 2014 | Binks M1G HVLP Gravity Feed Paint Spray...
I bought a binks bbr with a tip of 97p . don't know what the 97p stands for. wanted to know if you guys knew this answer. I'am thinking it could be the needle size? your answer will be greatly...
The 97P stands for the Air Cap. For the BINKS BBR (or Mach1A) are more than ten different air caps available which differ in air flow capacity and pattern width. The 97P has an air volume of 21 SCFM (@10 PSI) and a pattern width of 16" (if sprayed from 10" distance).
Michael
Jun 14, 2011 | Binks Spray Gun Bbr Auto Hvlp Auto Recirc
I have photo copy of binks bbr spray gun with feed cup but i can't find it on your site. I don't know model no. please give me suggesion
The "BBR" gun was the predecessor of the MACH1 gun. And there are basically two versions of it. The older BBR version states on the gun "BBR" only and the newer version "BBR" and "HVLP". Most spares are the same. As I know they just called it "BBR" and there is no Model Number. I have both spare part lists (hard copy at the moment only). What are you exactly looking for?
Michael
email info@bsc-teknik.com ' www.bsc-teknik.com
Jun 01, 2011 | Air Tools & Compressors
My binks 18 spray gun squarts paint from the hole in the part that holds the cup on when i release the trigger
spray gun is cloged (clean it!) also check gaskets in gun and vent hole in cup lid ( could be cloged)
Jan 11, 2011 | Binks MACH 1 HVLP Pressure Feed Spray...
Squirts paint even after releasing trigger
needle valve is not seating,possibly needs cleaning or is damaged an needs replacing
Dec 28, 2010 | Binks Spray Gun Bbr Auto Hvlp Auto Recirc
I am trying to find a manual for a binks 2001 spray gun i am having trouble figuring out where the o ring number 7 goes
I looked up same gun. I think I googled "binks model 2001 spray gun" and I got a pdf with all info and diagrams. On the available websites, I looked for the one that looked like official Binks site.
The PDF # I got is 77-2316R-14.pdf. It shows that #7 o ring
Nov 05, 2010 | Binks Paint Spray Gun Repair/rebuild Kit...
No suction
Jun 30, 2010 | Binks Model 7 Conventional Suction Feed...
I need a users manual for a binks model 15 spray gun
Here you can find a manual: http://www.tpub.com/content/automotiveaccessories/TM-9-4940-507-14-P/TM-9-4940-507-14-P0006.htm
Michael
Jun 14, 2010 | Binks SPRAY GUNS & OUTFITS
Spares for binks 630 spray gun
You can find spares for Binks 630 here: http://sprayfinishingstore.com/products/spray_gun/classics-gun/binks-630-gravity-spray-gun/
Michael
www.sprayfinishingstore.com ' info@sprayfinishingstore.com
Sep 29, 2009 | Binks Air Tools & Compressors
Binks bbr converting from pressure to siphon
Jul 31, 2009 | Binks MACH 1 HVLP Pressure Feed Spray...
Air Tools & Compressors Logo
164 people viewed this question
Top Binks Air Tools & Compressors Experts
JOHN LAPIER
john h
russ davis
Are you a Binks Air Tool and Compressor Expert? Answer questions, earn points and help others
