Question about La Pavoni Coffee Makers & Espresso Machines
How to replace the shaft on la pavoni pl16
Steamer leaks when making espresso
mirran
  • 515 Answers
SOURCE: service a pavoni hand espresso machine
Look at this site an see if you can find a place to repair it.
http://www.lapavoni.com/
Posted on Jul 15, 2008
SOURCE: Dualit espresso machine
lost my instructions for descaling my delonghi espresso machine
Posted on Mar 02, 2009
z34aga
  • 137 Answers
SOURCE: La Pavoni Duet replacement part
for water filter cartrige see this link:
http://www.espressoparts.com/results.cgis?catalog=&select=prod_desc&keywords=water+filter+cartridge&image.x=0&image.y=0
in the site mentioned above you can get other pavoni parts too. if you are not content i can give you another links too
Posted on Apr 03, 2009
LaPavoniBoy
  • 36 Answers
SOURCE: Leaking water from the group and steam spout
You will need to take the machine apart completely as there are more gaskets inside the group head. You can buy an old group service kit at www.theespressoshop.co.uk for about £20 and it comes with an exploded diagram so you can see what goes where. Don't worry there is no technical mechanical solenoid like the last comment stated. I repair these machines for a living and all it needs is a good service.
All the best
LaPavoniBoy
Posted on May 28, 2009
  • 39 Answers
SOURCE: When making espresso half way through the pump
Most likely you will see the problem when doing a single or double espressos and when just producing hot water. All these three functions work based on specific amounts of water. Most likely your flow meter is not working properly. I replaced my flow meter (< $20) and the unit now works fine.
Posted on Dec 29, 2009
Coil sealant
HI you shouldn't use sealant. if the silicon seals are broken they should be replace, they are available from sellers on ebay.
May 22, 2014 | La Pavoni Coffee Makers & Espresso...
Tip
La Pavoni Lever Machine Hissing?
If you have a La Pavoni lever model espresso machine and the safety assembley on the top right hisses while the machine is heating up, all you have to do is use something hard but preferably not metal or too large and tap the safety assembly quite firmly but not to hard and this should stop the hissing. This is because inside the assembly there is a bung on a spring and sometimes it becomes stuck and just needs a gentle tap to free it up. If it doesn't stop hissing then you can remove and stretch the spring or if needs be replace the spring and bung.
All the best
Mr La Pavoni
on Jun 02, 2010 | La Pavoni Europiccola EPC-8 Espresso...
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
My Pavoni Pro started leaking water from its base. It doesn't let steam escape, and it still makes espresso, but water leaks out slowly I guess from the base (like 1 cup per hour or so). Is it a gasket or...
You most likely need a boiler gasket
European Gift & Houseware
514 So. 5TH Ave. Mt. Vernon N. Y. 10550 Phone: (914) 664-3448 ext. 102, 106, 107 Toll-Free: (800) 927-0277 Fax: (914) 664-3257 E-mail: sales@europeangift.com
Feb 13, 2010 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni Napolitana: the grinder works however
Yes. Inside on the top after you loosen 2 scres the coffee warmer plate comes off there is a reset switch.
Apr 27, 2009 | La Pavoni Napolitana PA-1200 Espresso...
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
La pavoni professional
Make sure your filter is clean.
Jul 21, 2008 | La Pavoni PC-16 Espresso Machine
LA PAVONI PISA
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Jan 25, 2008 | La Pavoni Pisa PA-35 Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Pavoni Si - leak from above filter holder
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Oct 09, 2007 | La Pavoni Espresso Si PAB-16 Espresso...
Coffee Makers & Espresso Machines Logo
35 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
