Question about La Pavoni Coffee Makers & Espresso Machines
Howto replace the shaft on la pavoni pl16
Steamer plpe It leaks water when making the espresso
mirran
  • 515 Answers
SOURCE: service a pavoni hand espresso machine
Look at this site an see if you can find a place to repair it.
http://www.lapavoni.com/
Posted on Jul 15, 2008
SOURCE: Dualit espresso machine
lost my instructions for descaling my delonghi espresso machine
Posted on Mar 02, 2009
  • 39 Answers
SOURCE: When making espresso half way through the pump
Most likely you will see the problem when doing a single or double espressos and when just producing hot water. All these three functions work based on specific amounts of water. Most likely your flow meter is not working properly. I replaced my flow meter (< $20) and the unit now works fine.
Posted on Dec 29, 2009
  • 8 Answers
SOURCE: My espresso quit working and the steamer wont work
how doomed it is depends on how handy you are...
First check if the unit has an illuminated power switch or indicator of any kind. If so check if it is lit. If it is not lit, it may be as simple as a power cord problem which can be checked by a voltmeter.
Otherwise, several things can go wrong:
1- a loose internal connection. This will require redoing the connection in a similar manner to the original.
2- a bad heater. This will require a replacement parts
3- the thermal protection is blown. This can be purchased from an electronic component store for a dollar or two and will require soldering or crimping.
All of the above requires basic electrical knowledge and a voltmeter.
If you are not handy and the unit is worth more than a 100$ then a local repair shop may be able to fix it for 40$ to 60$ (mostly labour as parts will never exceed 10$)
Posted on Mar 15, 2010
Testimonial: "Thank you so much however the vinager cleasing worked! I will keep this on hand in case of future use. Thanks again (:"
SOURCE: Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Posted on Jul 24, 2010
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
Our machine (now nearly 3 yrs. old) has been leeking out the bottom and from the steamer until all the water is completely gone for the past month. I fill it with enough water to make 2 capps. in the...
sealing between heating element and boiler-body leaks the water - and it has probably shortcut the electricity by now: disconnect the powerplug immediately - and exchange the sealing
Aug 24, 2011 | La Pavoni "PROFESSIONAL Chrome" 16Cup
My Pavoni Pro started leaking water from its base. It doesn't let steam escape, and it still makes espresso, but water leaks out slowly I guess from the base (like 1 cup per hour or so). Is it a gasket or...
You most likely need a boiler gasket
European Gift & Houseware
514 So. 5TH Ave. Mt. Vernon N. Y. 10550 Phone: (914) 664-3448 ext. 102, 106, 107 Toll-Free: (800) 927-0277 Fax: (914) 664-3257 E-mail: sales@europeangift.com
Feb 13, 2010 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni Napolitana: the grinder works however
Yes. Inside on the top after you loosen 2 scres the coffee warmer plate comes off there is a reset switch.
Apr 27, 2009 | La Pavoni Napolitana PA-1200 Espresso...
Water leaking from the group
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Feb 18, 2009 | La Pavoni PC-16 Espresso Machine
La Pavoni Duet replacement part
for water filter cartrige see this link:
http://www.espressoparts.com/results.cgis?catalog=&select=prod_desc&keywords=water+filter+cartridge&image.x=0&image.y=0
in the site mentioned above you can get other pavoni parts too. if you are not content i can give you another links too
Oct 31, 2008 | La Pavoni Club Combo Duet PA-1315 Espresso...
La Pavoni Losso Espresso machine not working.
Fill the tank with a strong De scale soulition , sounds like its blocked with limescale. REMEMBER to rinse thru clean water several times after the process...
Feb 08, 2008 | La Pavoni Lusso PL-16 Espresso Machine
LA PAVONI PISA
Ah ha! I just fixed the problem.
The black steam knob is bonded to the shaft. The shaft/knob assembly is removed by rotating the spring keeper on the brass housing the shaft fits into by 90 degrees to allow the shaft to be pulled out once the knob is rotated enough to disengage its thread from the brass housing.
Once the cover over the boiler is removed you will see three thermostats mounted on top of the boiler.
The middle one has the reset button located between the two power connectors. Push it down and you will hear a metallic snap as it resets.
I now have a working La Pavoni Pisa Espresso Machine again and it was free to fix it!
Wooo Hooo!!!
Jan 25, 2008 | La Pavoni Pisa PA-35 Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
Pavoni Si - leak from above filter holder
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Oct 09, 2007 | La Pavoni Espresso Si PAB-16 Espresso...
Coffee Makers & Espresso Machines Logo
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
