Question about The Kitchen Appliances - Others
What product will remove baked on food and juice marks from outside of roasting pan
When food has been roasted or baked, a residue sometime overflows from the pan to the outside of the pan, and becomes baked onto the pan,]. What product will remove it?
  • The Master
  • 3,150 Answers
CLR. do a range to do the job ,
Posted on Apr 24, 2017
How long do I bake an 8lb shoulder pork roast?
hi Dianna.
Roast in a preheated 500 degree (F) oven for 20 minutes. Reduce heat to 300 degrees and roast for an additional 30 minutes per pound. Total cooking time for an 8lb roast should be about 4hrs and 20 minutes. Remove the pork roast from the oven and let rest for 30 minutes
How long do bake an 8lb shoulder pork roast Google Search
Dec 14, 2017 | Grilling
I am cooking my pork tenderloin with the marinate, can I serve the marinate as a sauce after!
You should not serve the marinade that you had the raw meat in unless you boil it for several minutes first, which is not a bad idea since it cooks it down to thicken it and concentrate the flavors. You can also add any meat juices in the bottom of the roasting pan to it. If you roast any onions in the pan with your roast, you can also add them and then blend them into the juices.
May 23, 2017 | Grilling
Should I put water in the lower roaster pan that is underneath the removable pan?
Yes, a little water helps to keep your roast from drying out. You can also chop up some root vegetables into large dice as well and put them under there. Carrots, parsnips onions celery are all good. The roast juices fall on to them, make a fantastic gravy and also delicious on the plate. I do this often and the results are great.
Feb 07, 2016 | Nesco 18 qt Nonstick Roaster Oven
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
Should I cover my roasting pan or not?
when using a roasting pan, it depends on the type of meat and the recipe if you should cover the pan or not.
meat with a high fat content eg duck doesnt need to be covered.
lean cuts should be covered when roasted for a long time to keep the juices and soften the meat.
May 06, 2013 | Home
What is the difference between roasting pans and broilers?
Roasting pants are for big peicesof meat becuase they are big, deep pans so the meat will cook and be flavoured from its juice.
A broiler has shallow sides so the meat cooks faster. It also has a slotted bottom so the pan drains.
Jan 14, 2013 | Home
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    Nov 26, 2009 | Viking Ovens
    Am I supposed to take out the large insert before roasting a turkey?
    No, no, that is the cook pan, roasting pan or "cookwell". That is where the food goes!
    If you have never run the roaster you MUST burn it in first (tonight!) 1 hour or longer at 400, outside on the porch or in the garage; it burns off really smelly factory leftovers that smell really bad and will contaminate your food and atmosphere.
    Nov 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
    Oven door shot open
    wine fumes ignited i would not recommend putting alchol in a closed space with 450 degrees of heat
    Jan 14, 2008 | Frigidaire FEF366 Electric Kitchen Range
    Kitchen Appliances - Others Logo
    Top Kitchen Appliances - Others Experts
    Level 1 Expert
    Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
