On the right of my 42in tv there is a black line about 4in in from the end, the line is about 2in wide and runs from top to bottom. inside the line the colur is dark blue at the bottom of the tv and varyingshades of bluse that flicker with the picture movement on the rest of the screen and the top third is white. Apart from the 'band' rest of tv is fine. Unit is approx 20 months old. please help!!!
  • 82 Answers
This is most likely a bad panel. If it is plasma, you might be able to fix it by checking the ribbon cables inside the TV:
Posted on Jul 25, 2009
My Gasfire goes out when my boiler kicks in
you need to up pipe diameter there is not enough volume able to come through shud b 15mm,..to fire and at least 3/4in... 22mm boiler also if u have a gas cooker needs to b all gas rated to obtain right pipe scize as a rule of thumb 3/4..in...22mm shud b ran right through and except boiler b 1/2in 15 mm tube running to every thing but the 1/2in 15mm pipes must not b longer than 6-7ft max
Oct 26, 2013 | Water Heaters
I have a black 6in wide bar on left side of the screen and a 2in bar on the right side that run from top to bottom. Only on certain channels and comercials.
Its not the set if only on certain channels, it cannot be. Got a box or something connected for signal?
It also should not do it if a DVD etc connected to a rear input is used.
Dec 23, 2012 | Hitachi Televison & Video
Black line about 5" wide
one of your buttom scanning bords is dead or it needs to be cleaned or simply reconnected properly , at the buttom of your plasma tv you have 2 to 4 small boards with flex connecters one of these flexible connecters will be adjacent to the black line ,replace entire board because it cannot be repaired
Sep 05, 2011 | Samsung HP-R4262 42 in. Plasma Television
Have black mark right hand side off screen from top to bottom about 1in wide also a black circle about 2in in cicrumfrance on my monitor which is 28in can you give me some advice on what is wrong also...
Almost sounds like the screen is broken if you have lines and a black circle which means somebody cracked it. Need to replace that monitor since the screen is not available for that model.
May 30, 2011 | Hannspree 28" Widescreen Flat-Panel LCD HD...
I have a 50 in samsung plasma tv and it sudenly had a 2in wide black and colourrd line from top to bottom appear ? any idears
try and bend the set slightly. IF line goes away suspect ribbon cable connector from x driver boards to panel. The connectors brake away from panel and thus a replacement panel must be installed.
Feb 18, 2011 | Samsung 50 in. Plasma TV
Mitsubithi tv part inside of unit when touched makes picture good or bad need to no what it is i can describe 3 in tall 2in wide 4in long finned rectangle 2 small screws in bottom side
This is probably a video sync module or Integrated Circuit for Video and picture and it has become loose at the solder joints at the Heat sink ( the finned rectangle).
Your TV needs to be serviced by a qualified tech to secure this device on the main board. The contacts or solder joints at the placement area are cracked or broken.
Feb 05, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I set cam and crank timing but no comp. No bent valves! Note, #1 piston no at tdc.at mark. Is one toth off.
I have run into this before . Volvo wants you to buy a special tool to properly set these cam's in time since the cam-drive pulleys are oil advanced . That's fine if you have up to $300.00 for the tool . I made 1 for under $20.00 . Here's How - Buy a 2in. by 7in. by 1/4in. piece of flat steel . 1 - Measure & mark 2in from each end (Length wise) . 2 - Measure & mark from the previous marks 3/4 in. towards center (Width Wise) . 3 - cut out space between marks (Finished product will look like a flat horse-shoe) . 4 - Put (flat horse-shoe) in a vise length wise (TABS UP) . 5 - bend each tab 1/8in.out from straight in line oposite directions (When done if you look straight down the lenght of the tool the tabs will make it apear the 1/4in piece of metal twice as thick)(1/2in.) 6 - Pull valve cover and look at the fire-wall side of the cam-shafts 1 side will be small half moon up(slots in cam will give the apearence of a small & large half moon) 1 small up and the other cam small half moon down . 7 - slightly turn the cams left or right to be able to fit tool in slots . 8 - With tool in place re-install cam-drive belt w/# 1 piston at TDC . 9 - adjust tensioner with very little tension against belt ( grab belt w/ tensioner tight above and below tensioner you should only be able to twist belt no more tha 1/2in. either way ) Bolt her down put her back together ( remove tool ) put valve cover back on & fire it up . GOOD LUCK!!! hope this helps you out .
Jan 15, 2010 | 1995 Volvo 850
42 in Panasonic Plasma TV - 4in wide vertical black band obscures image. What is wrong, how do I fix it, and what does it cost.
take it apart and reseat connectors on bottom buffer boards if not may need to replace buffer boards on bottom of tv
Jun 07, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
204 people viewed this question
Top Televison & Video Experts
Electro Med Services...
