Question about Amana Dryers
On my amana gas dryer model ndg7800aww there is a set of wires blue gray and yellow that connect to the top inside door.I forgot how they go back. Can you tell me which order to reconnect
    Habit-Forming:
  • 21 Answers
Check this out and see if it helps:
http://www.searspartsdirect.com/model-number/ndg7800aww/1268/0151200.html
Posted on Apr 25, 2017
My Amana gas dryer Model NDG7800AWW heats initially and then stops.
Hi Mohit , you need a new set of valve coils . It's part # 5303931775 GOOD LUCK APPLIANCES R'EN
Jun 17, 2014 | Amana NDG7800AW Gas Dryer
Gray colored clothes after drying
Check the flue where the heat enters the dryer this the tube where the flame from the burner leads into the dryer you will have to take the back panel off and a few screws to remove tube forgot to ask is the inside of the tumbler drum stained
Mar 22, 2014 | Amana ALG331RAW Gas Dryer
How to remove dryer cover?
Instructions
    • Open the dryer door and locate the screws underneath the front lip of the dryer top. Unfasten the screws with a screwdriver and set them out of the way.
    • Flip the dryer top back so it is setting on the rear hinges. Locate the screws on the inside of the front panel near the top of the dryer.
    • Unfasten the screws on the inside of the front panel with a screwdriver and set them in a safe place. Lift the front panel up so it comes off the metal clips at the base of the dryer in the front.
    • Unplug the two-pronged electrical wiring connector from the back of the front panel by hand. Set the front panel of the Amana dryer cabinet out of the way.
Jul 02, 2012 | Amana ALE230RAW Electric Dryer
Amana ndg 7800 aww manual
The Amana NDG7800AWW dryer is sold at Sears. Thus Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/5976/AMANA-Residential-Dryer-L0503038 . The direct link is http://www.managemylife.com/mmh/lis_pdf/OWNM/L0503038.pdf . (The manual covers several dryer models.)
I hope this helps.
Jan 30, 2012 | Amana NDG7800AW Gas Dryer
The wires on the door switch of my Amana dryer disconnected when I was replacing the drum belt. There are three wires: red, gray, and black. I thought the order was red on top, gray in the middle, and...
MUST GIVE YOU MY DISCLAIMER - MAKE SURE THE APPLIANCE IS DISCONNECTED FROM ELECTRICAL POWER BEFORE DOING ANY SERVICE.
There - you got the drum belt around the idler pulley, well done! That's tricky to master!
The switch serves 2 purposes - turn on the light or tell the dryer the door is closed. Either the switch got damaged or the wires are in the wrong place. Usually the length and the way they bend is a clue as to where they go, but colors change. I don't think Whirlpool makes Amana (as they do everyone else) or the wires would be gray, yellow and brown. Does the light work? That's a clue, but the web site I use for information is down for maintenance until morning. Can you read a schematic? If so, up inside the control panel should be the information you need, taped in a plastic bag I would hope. If so, please put it back when you're done - technicians expect it to be there! Just message back "no luck" if you were not successful.
PS - I just thought of a "duh" check - make sure the switch clicks as you press the lever.
Jul 08, 2011 | Dryers
Which wire is connected to which spot on the door switch? help =(
The white is the common and the gray is for the light the yellow allows machine to start and run when the door is closed.. Just hook them up if the light is on with the door open it should be good to go... If the light is not on then switch the yellow and gray.
Apr 07, 2010 | Amana NDE7800AY Electric Dryer
Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will heat and does dry some but when it moves to the less dry the dial does not move and the dryer does not heat
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Oct 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have an Amana model #ndg7800aww gas dryer thats not heating. the glow bar glows the gas comes on for a few minutes then the glow bar just keeps cycling.
The problem is with the 2 little gas coils.
I change about 3 of those per week.
Parts will run you around $20 and it's fairly easy to replace.
Please feel free to email me if you need help installing. Thank you :)
Aug 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Wiring harness diagram
which wires popped of exactly ??? the wires from light/door switch?? grey, white, black, wires???if so thats the order top to bottom
Mar 17, 2008 | Dryers
Amana gas dryer
You have to take the front off on that model.. to get at the inside.. heres a diagram that may help ya out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1268&modelDesc=AMANA%20LAUNDRY&modelNumber=ALE331RAW&documentID=M0411885&documentTypeID=PLDM&documentClassCode=PV&titleType=DOOR%2C%20FRONT%2C%20ACCESS%20AND%20TOP%20PANELS&titleID=00002&
Oct 10, 2007 | Amana ALE331RAW Gas Dryer
Dryers Logo
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
