Screen on ps4 is to "big" i can not see the upper part. It is OK when i watch TV. I have checked the settings, and I have also tried to reset the whole thing. Could it be a setting on the receiver?
  • 323 Answers
On the PS4 go to settings, then sound and screen, and then display area settings. This will allow you to enlarge or shrink the screen.
Posted on Apr 24, 2017
SOURCE: how to erase parental control code
I finally found out how to reset the V-chip password on this princess DT1350-P Tv. All you have to do is turn the TV on and turn to a channel that doesn't prompt the V-chip password (even if it's snowy) and hold down the volume (down -) button on the main unit while holding down the number "0" on the remote control. It might take a few tries, and you might need to change the TV channel for some reason but if done correctly, either the TV will turn off, or the menu screen will pop up and ask if you want to set the vchip password, either way you should be able to watch your TV now! :)
Posted on Nov 28, 2007
  • 927 Answers
SOURCE: mitsubishi WS-55311 flashing screen
First suggestion is to unplug your unit for 24 hours, if does not correct your concerns, you may have fluid leakage from the tubes onto the pc boards. Make sure you have proper air venting around the tv. If problem persist call factory authorized dealer in your area. good luck
Posted on Apr 02, 2008
SOURCE: How do I determine which Fossil Model I have.
This may sound obvious, but if you haven't tried it, look for markings on the back of the watch.
Posted on Apr 03, 2008
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
Posted on Aug 12, 2008
SOURCE: Kenneth Cole Reaction Watch Model KC1450 digital settings
hold down mode until the time settings come up. the alarm settings show first, then press mode once more to set the actual time.
bing took me like 2 hours lol.
Posted on Oct 27, 2008
Trying to hook up a PS4 2A Oli flat screen TV help please
its a ps4 so it comes with a hdmi cable. Place the hdmi cable into the back of the ps4 and put the other end into a hdmi input
on the TV . Don't know the TV but usually there are a number of HDMI input ports on most modern tv's.
Then switch tv source to HDMI .
Happy gaming Phillip
you will have to plug the usb cable into the controller and into the front of the PS4 and then charge the controller by pressing the power button on ps4. The controller has to be paired to the ps4. The manual that came with the ps4 should go into it in more detail.
Dec 25, 2016 | Televison & Video
Got it on my computer not on ps4 and my tv
Don't really understand you question. Does the PS4 show up on the computer monitor not the TV. If so you need to reset the picture settings by holding the power button down until you hear beeps.
Aug 18, 2015 | PS4 Video Game Consoles & Games
How I have a 26 inch slyvania LCD TV that I'm having trouble connected it to my ps4
Are you using an HDMI cable? Make sure it's a an HDMI 1.4 model cable which will allow for maximum 1080p resolution and bandwidth. Older cable can't handle the throughput. Are you using the one supplied with the PS4 or another one you had lying around? Try a different cable first before anything else.
Is you tv set to 1080p resolution or automatic? Try checking that, as well. If your PS4 is set to pump out 1080p and your tv is set to receive 720p it will cause issues.
Jan 01, 2015 | Televison & Video
Can't get ps4 to work on alba 49"TV PS works on other TV
Might have to do a video reset depending on how you have it hooked up. If you go from HDMI to a different type of connection it won't work. Make sure you have your TV input on the correct HDMI setting as well. here is the link to how to reset the video on a ps4: Change PS4 Video Settings
Aug 05, 2014 | Televison & Video
No Sound on TV when PS4 is on
Check the sound is enabled on the HDMI or usb port that you are using.
Jul 18, 2014 | Philips Televison & Video
I cant change the screen position on my acer v203w the icon on the menu cant be selected
Did you reset the monitor back to factory settings?
Auto adjust?
Try change the ps4 screen settings if possible
Apr 15, 2014 | ASUS LCD Monitor
Picture is too big for the screen
go to page 37 of the manual and read through to RESET TO FACTORY SETTINGS
Thanks for using FIXYA
May 30, 2009 | Syntax Olevia 532H 32 in. LCD HDTV
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
TV out problem when wanting to watch video
i went to settings and pushed reset settings and now it works
May 18, 2009 | Memorex Mi8000BLK iFlip 8.4" Portable...
Can't change the time setting on my sports watch
Your Fossil Watches has four push button and one for winding button. the first button has mark of LIGHT , the below button is MODE ,,upper right START/STOP,,, lower is LAP/RESET. the center button is what they called it a CROWN to set crown is just pull it and you can set the hour and minute. the LIGHT button is the set button also, just press it for 15 seconds if dial flashes, then go to MODE button and choose what going to set, the START/STOP -- LAP/RESET is the scroll button you going up and down the number or on /off ,some model of chronograph the set is in the MODE button just press it long and if flashes it ok. and follow procedure what i said before. setting cannot damage the watch...
Jul 24, 2008 | Watches
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
