Question about Cell Phones
The picture is fuzzy.I turn off the power wait 30 seconds eventually it raises up to 3 bars and stops.
SOURCE: Don't know how to light GE Glow-Bar oven
Perhaps the oven ignitor (glow bar) is defective. To test, check the voltage going to the ignitor when you turn on the oven to bake. If you have 110 volts testing with a voltage meter, replace the ignitor. If you do not have voltage, trougleshoot backwards to see where you have voltage in but not out.
If I can help further, I am here.
Eric Campion
Posted on Mar 04, 2009
localwonder
  • 6784 Answers
SOURCE: Power Bar has a red light, xbox wont turn on
OK, this is a power supply issue here. you will need to replace the power supply board asap/ it is malfunctioning.
Contact Microsoft for this repair.
Posted on Jun 22, 2009
  • 14 Answers
SOURCE: Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Posted on Oct 10, 2009
  • 19 Answers
SOURCE: Vizio VO420E 42 in. LCD TV
the problem its the main board of the tv not the power supply board.the main one controls all your imputs tv av component etc the cheapest place to find it its at www.shopjimmy.com cheaper than the manufacturer and those dudes that you find online that charge an arm and a leg just to come and just repair your old main board mine as well buy a new one at this site for less ok and you are welcome
Posted on Apr 13, 2010
  • 336 Answers
SOURCE: No Picture but still has sound
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is 915P049010. you can find it here: http://www.discount-merchant.com/Mitsubishi-915P049010-Lamp-Replacement-p/mitsubishi-915p049010-lamp.htmHave a blessed one!
Posted on May 03, 2010
Samsung Fuzzy Logic Washing Machine will not rinse and is showing an OE sign . What is problem and how do i fix it
The OE code indicates an Overflow Error. Too much powder or liquid detergent may have been added. If you turn off power, wait 30 seconds, and turn on power, the pump should turn on to drain the machine. If this routine doesn't work it may be necessary to call for service.
Nov 27, 2016 | Samsung Washing Machines
Samsung fuzzy logic machine is showing 0E error sign and will not rinse
The OE code is an overflow error that occurs when too much detergent has been added. Samsung recommends turning off power, waiting for 30 seconds and turning power on again. You should hear the pump drain the machine.
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
The phone will not stop turning on and off it wont Evan load up
Hello my dear Friend:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 31, 2012 | Kyocera Cell Phones
My LG pdp42x3 plasma doesnt turn on.
5.Wait 10 seconds.
Step
Thanks
Oct 02, 2012 | Cell Phones
My hp ipaq 614 wif is not turning on
5.Wait 10 seconds.
Step
Thanks
Aug 23, 2012 | HP iPAQ 614 Business Navigator 2.8-tft...
Pls let mr know Error number 5200 for printer Canon Ip 2700
I have found a solution for your problem. (1) With the printer turned on, unplug it (2)Open the top and bring the ink cartridge holder to the middle (3)Raise the gray bar and remove the print head assembly with the cartridges in it (4) Lower the gray bar with the head missing and close the top with the head out (5) Restore the power,wait til the printer wakes up (6) It will tell you to put in the cartridges (7) Restore the print head, close the top and the printer should resume working..... ;)
bhupi
May 03, 2011 | Canon Office Equipment & Supplies
Fuzzy camera picture for a polycom 7000 camera. Will not focus unless zoomed all the way out
Try reseting the camera, power it down, wait 30 seconds then power it back up again.
Jun 10, 2010 | Polycom VSX 7000 Video Conference
Oct 10, 2009 | 1994 Dodge Ram
Scanner issues
driver problem reinsatll software drivers
Oct 03, 2006 | Dell 922 All-In-One InkJet Printer
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
