Question about Bose Audio Players & Recorders
I cant get my blue tooth remote speaker to have any volume on my Bose system
  • 11 Answers
SOURCE: Problem connecting Onkyo Amplifier to Bose Accoustimass speaker system
This is probably correct as modern equipment uses electronic volume controls rather than potential dividers the range is normally biased towards the bottom end so there is lots of the range that is quiet and a smaller part that is loud.
Unless you find that at the top of the volume range the system does not seem to be loud then it is probably correct. It is not uncommon for modern equipment to clip at 80 / 90% of the volume range. Where as old style equipment with volume pots used to clip at arround 30% of the volume range as it gave the apperance there was loads of extra volume available. In fact all that happened if you turned it up louder was it clipped more and more.
Regards,
Andrew
Posted on Sep 17, 2008
  • 514 Answers
SOURCE: Using dish network remote to control volume on Bose 123 system
go here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" to find your remote, then look at the literature to see if Bose is listed or for the code scanning for your remote. good luck!
Posted on Feb 22, 2009
Monster80
  • 463 Answers
SOURCE: Bose 321 system - volume is stuck at 30
You'll need to go into the main menu and there is where you can change your on volume, minimum volume, and maximum.
Posted on Apr 02, 2009
  • 4234 Answers
SOURCE: LG 47 External Audio Control
The issue is not the receiver, it is the TV. The output from the LG is a FIXED output not a variable one. There may be a menu option to change that in the TV, but I'm not sure. Many people turn off the TV speakers when using a stereo for sound. If the TV output was dependent upon the volume control of the TV, there would be no way to shut off the TV speakers.
Double check the rear of the set for a set of outputs labeled VARIABLE. Connecting the receiver to those would do as you wish.
Dan
Posted on Sep 21, 2009
SOURCE: Code for sky + remote to operate bose cinemate volume via the sky remote ?
1356 something like that ;)
Posted on Sep 25, 2009
Can I connect bose speaker to Sony blue ray via blue tooth
Is your Bose speaker a Bluetooth speaker ? Does your Sony blue ray player have Bluetooth ? You can connect the two only if Both are Bluetooth devices.
Feb 15, 2015 | Sony Televison & Video
Have an old Bose Cinemate that the new Direct TV remote won't/can't control volume?
Some remotes are programmable. In order to do this, you may need a code to do that. Check your manual in your Bose sound system for a code. if you don't find it there, check your DirectTV remote setup guide. It should list it there. It may be under Bose, sound systems, or other. Once your remote is set up and configured for your sound system, you'll be able to control sound with your remote.
May 09, 2014 | Bose Cinemate Digital Home Theater System...
No volume cinemate gs seris ii
OK, so your Bose remote is set up for your TV. That's good. You still have to connect some kind of audio output from the TV and connect it to one of the inputs on the Bose. Then you must select the input button on the Bose remote that you connected the TV to. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 10, 2013 | Bose CineMate GS Series II Speaker System
Trying to program charter remote with bose cinemate home theatre speaker system. Does any one know the codes?
Using Universal Electronics Charter Remote OCAP 4 Device, I was able to get the volume control to work using the final code in the code listing, 31933
Aug 22, 2013 | Bose Cinemate Digital Home Theater System...
Control speakers with tv universal remote
I just got the Bose Solo, but I cannot program my Verizon Remote to control the Solo's volume. I have an RC1445301 Verizon Remote. How do I program it to control the Bose Solo's volume???
Feb 19, 2013 | Bose Solo TV sound system - Black
How to control volume of bose cinemate with directv remote
The code for the Direct TV remote is 31933. It doesn't work with the new RC71 remote (Direct TV limitation with that remote), but it does with the remotes that have AV1 and AV2 options.
Mar 15, 2012 | Bose CineMate GS Series II Speaker System
My Bose remote turns on and off withthe comcast remote but the volume does not work unless I hitthe AUX button first. Does not work with the all button pushed.
Since multiple devices have volume controls you must inform the remote which device's volume you are changing. Just like the Power button. You wouldn't want everything in the room reacting to a generic command.
Aug 09, 2011 | Bose Cinemate Digital Home Theater System...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
41 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
