Question about Viking Kitchen Ranges
My Viking DEDO 201SS is stuck in "clean" mode. I had a tech come look at it and said I need to replace the latch and circuit board... for $1300! Is there some other way to fix these latches?
SOURCE: Hoover performa 1300 door latch
my hover performa 1100 door latch will not open can anyone help
Posted on Sep 16, 2008
  • 42 Answers
SOURCE: my viking electric oven does not have accurate temperature
how bad is the temp off?
Posted on Dec 21, 2008
SOURCE: HP Pavilion dv2120us Notebook PC battery release latch
My battery latch got stuck in the open position after replacing the battery on HP's DV 6300 series. The battery was thus stuck. I used the 'screwdriver' technique but with a rounded end kitchen knife not an actual screwdriver to remove the battery. It is important to push the knife down a little into the groove at the outer long edge of the battery and pry that outer edge up. AFTER DOING THIS THEN GOING TO REPLACE THE BATTERY I REALIZED THE LATCH PROBLEM OCCURRED BECAUSE I HAD PUSHED THE BATTERY LATCH TO THE OPEN POSITION TO REPLACE THE BATTERY. THIS IS WHAT JAMS IT. TO REPLACE THE BATTERY 'DON'T TOUCH THE LATCH AT ALL'. LEAVE THE LATCH IN THE CLOSED POSITION AND REPLACING THE BATTERY WILL SET THE LATCH IN THE CORRECT CLOSED POSITION, READY TO BE SLID TO OPEN POSITION ONLY TO DO THE ACTUAL BATTERY REMOVAL.
Posted on Mar 21, 2009
SOURCE: stuck hood on 2000 ford 250, latch release won't work
2000 FORD SUPER DUTY 5.4 HOOD STICKS.YOU CAN HAVE AN ASSISTANT PULL THE HOOD CABLE AND EASILY OPEN THE HOOD BUT THE HOOD WILL NOT POP UP ON ITS OWN..ANY ADVISE?
Posted on Nov 05, 2009
SOURCE: Trunk latch is stuck in a position that prevents
spray some WD 40 on the latch. should do the trick. i had that problem with my sunfire in the winter time
Posted on Feb 12, 2010
I have a whirlpool accubake self cleaning oven.. when trying to use the self clean option it now states e1 f5 in the digital screen what do i do know?
Most commonly that is a runaway temperature error which usually means the temperature probe is bad and needs to be replaced. If you need more detailed instruction or help making this repair visit the link below:
Appliance Repair Help With Live Chat
Mar 26, 2017 | Whirlpool Ovens
Viking model #vdsc365-6bss door will not open
I guess it would be stuck in self clean mode...a latch above the oven door handle...does this on have a self clean..should have asked that first...
May 26, 2014 | Kitchen Ranges
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Wold double oven is giving me an F 1 display
HI. This is possible defective door latch mechanism. Check the wiring that links the door latch mechanism to the actual control board. If the wiring is ok, and the rear of the control board is not discolored, or showing signs of short circuiting, replace the door latch assembly. This will correct the issue.
Now, if the wiring is worn, or burned at the control, and the rear of the control board is discolored, and is showing signs of circuit failure, you will need to replace the main control board and wiring harness.
Oct 18, 2009 | Ovens
Viking Self Cleaning Latch Stuck
You have to basically split the stove apart to replace the self clean latch assembly. Not easy I don't think. I would get service. But tell the techs not to overdo it on the price and try to get the part yourself from Viking. Good luck.
Apr 02, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Good Morning: The self cleaning mode engages, locks the oven on the bottom, but does not clean. On the top, the latch does not engage at all on the self cleaning mode. What to do?
A safety feature on the oven door latch is preventing it from going on to clean. Find the reason the door wont latch on top section and it should clean then.
We know your controls are working asking the clean cycle to start because your lower door latches.
SO
Some things to check :
1. Bent or worn out door latch or striker or catch assembly
2. No power to motor to move latch assemble
3. Board for self cleaning may have fuse out or be bad entirely.
4. Motor assembly that moves the latch could be bound up or worn out
If this helps you understand your problem please rate me as high as you can and thank you for using fix ya. Good Luck and God Bless.
Mar 27, 2009 | Viking DEDO205 Stainless Steel Electric...
F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
VDSC365-6B
a part of your latch assembly is malfunctioning.check this along with your oven sensor.
Jun 18, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
