Question about Garden
I have a Green thumb broadcast spreader. I've lost the cotter pin and rectangular flat piece under it. where can I buy these?
    Top Expert:
  • Garden Master
  • 80,407 Answers
Any hardware store like OSH can supply the parts.
Posted on Apr 24, 2017
Testimonial: "thank you"
My scotts rotory spreader will not spin
The design is quite simple with one wheel driving a bevel gear in a gear box. If the wheel turns the axle shaft and the center pin in the spreader with the retainer/cotter pin does not turn it is likely something has failed in the gear box.
If both wheel spins and the axle does not turn than the drive wheel has disengaged the axle shaft and the cotter pin in the drive wheel needs to be replaced.
The compounds used in the spreaders are corrosive. Usually the gears and axle become bound due to corrosion. By oiling the bearings and wiggling the wheels they will free up,
Hope this helps?.
Apr 19, 2013 | Scotts Company 589384 Scotts 5000 SQFT...
I buy Scotts fertilizer and use an earthway broadcast spreader.
add 10 - Scotts Turfbuilder spread at # 4 on a Scotts spreader should be on setting # 14 on an Earthway spreader.
Mar 28, 2010 | Earthway "Earthway" Medium Duty Commercial...
How do you replace a burner on a ducane gas grill
Hello : Here are two solutions , just look which one of them is the most helpful .
  1. Turn off the gas supply and bleed the lines leading to the grill. Remove the gas tank if possible.
  2. Open the grill and remove the grates. In some cases you will need to
    detach the hoses from under the grill using simple hand tools. Other grills may have simple "float in" style of burner. These styles look as if the tubes from the burner leading to the gas supply lines simply "float" into each other. Look for clamps of holders that may need to be removed.
  3. Remove the damaged burner and remove from grill. Take a moment to inspect the other burners and any other hoses in case you need to replace more than one piece. Place the burner in a plastic bag and take it to the home store so you can get the exact parts you need. This removes all guess work.
  4. Before replacing the burner/burners etc, take a moment to clean any material, grease etc from the bottom of the grill. Replace the burners and hoses as needed. Check the connections before reconnecting the gas supply. Turn the gas on and start to flow of gas to the burners without lighting the grill. Make sure the flow is working. Be sure to turn the gas off, let the fuel dissipate before lighting.
  5. With everything working, fire up the grill and enjoy.
Or try these help here :
  1. Turn off the gas supply valve on the tank. Remove the fuel line from the fuel tank by turning the connection nut counter-clockwise with your hand.
  2. Open the Char-Broil gas grill and remove the main cooking grate. You do not need to remove the upper warming racks to change the burners.
  3. Remove the lava rocks from the grill and pull the rock grate out. Unhook the flame spreader from each end where the spreader attaches to the inside body of the grill. The spreader is the angled piece that sits over the burner.
  4. Locate the cotter pin that secures the front of the burner to the grill body. Remove the cotter pin with a pair of needle nose pliers. Lift the burner up and pull the burner venturi tubes out of the gas valve.
  5. Set the new burner inside the grill with the venturi tubes inside the gas valve opening. Install the cotter pin to secure the burner to the grill body. Place the flame spreader back inside the grill and hook the ends to the grill body.
  6. Place the rock grate, lava rocks and cooking grate back inside the grill. Reattach the fuel line to the fuel tank.
Here you need Needle nose pliers.
Please report me which one helped the most .
good luck .
and rate if useful please !
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Feb 20, 2010 | Ducane 30400040 Stainless Steel Grill
Wheel and axle broke
If the unit will not broadcast when pushed, try drilling a small hole through the inside of the wheel where the axle enters the wheel and insert a small cotter pin. This worked on mine.
Oct 09, 2009 | Earthway Ev - N - Spread Estate Grade...
How do i calibrate my scotts speedy green 3000 broadcast spreader?
From the OEM Scotts SpeedyGreen 3000 Broadcast Spreader Owners Manual: Calibration Your SpeedyGreen 3000 spreader was calibrated at the factory. You may check the calibration as follows: 1.) Adjust the micrometer setting to 2. 2.) Squeeze the trigger against the handle. 3.) The Calibration line engraved in the Green casing above the top of the shut-off plate should be flush with the back edge of the hopper opening. 4.) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel.
Sep 25, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Lost agitater for my Scotts Spreader
I replaced mine with a clip-in cotter key, the kind they use for farm implements to keep a pin in place. I bought a stainless steel one at Lowe's for ~$1. Works at least as good as what I had.
Best regards, --W/D--
Aug 08, 2009 | Scotts Lawn 73740 SPDY GREEN 3000 B/C S 3...
Fix the distribution propeller on a broadcast lawn spreader
back yard fix
use the right size nail
use the right size split pin
use the right size bolt
Sep 10, 2017 | Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
