Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Same problem, backlight on all the time
Just had BGE (local power company) install the UtilityPro thermostat that allows them to cycle the compressor off during peak electricity usage in exchange for some monthly savings on the bill. This thermostat replaced a Honeywell VisionPro thermostat which looks identical. The VisionPro backlight automatically turned off after the screen was not touched for a few seconds. This UtilityPro model just goes slightly dimmer instead of off. Not really fond of the green glow on the wall all the time. Nothing in the manual on how to change the backlight setting. There is a USB port on the side. I'd like to find some software that can recognize and reprogram these hidden functions. Plugging the USB port into my laptop just results in it loading an "unrecognized device" A search of the Honeywell website so far has not turned up any programming software.
  • 86 Answers
Http://www.ntsupply.com/files/products/VP8000TechData.pdf
check out this website
if this is the touch screen tstat you have to enter installer setup
touch the SYSTEM button once
hold down what is usually the HOLD and SCREEN keys touch both keys at the same time
(hold the two blank keys on either side of the center key at the bottom)
this will bring you into the setup
BE VERY CAREFUL WHAT YOU CHANGE THIS COULD EASILY SCREW UP YOUR SETTINGS
change where the numboer is 0120 to 0280 and change 1 to 0 then hit done this should fix it:)
Posted on Jul 26, 2009
DOMETIC DUOTHERM KICKS THE BREAKER MAY RUN FOR A DAY OR MAY RUN FOR 8 HOURS BEFORE IT DOES IT IN MILD OR HOT WEATHER. ALREADY REPLACED BREAKER AND MADE SURE WIRES ARE TIGHTNED. HELP PLEASE.
If all appears OK, no noise, good cooling suggest check thermostat. If the thermostat is allowing the compressor to short cycle, restart under load the breaker would be expected to blow do to overloading the compressor.
There is usually a 5 minute time delay in the thermostat that prevents this.
Jun 20, 2017 | Dometic Heating & Cooling
Serial # 20245743CD
the compressor is supposed to cycle as it is controlled by a thermostat
if the cycle times are too short then check the following
door seals in good condition --cracked or broken seals let the cold air out
thermostat setting too cold -- doesn't allow for a long period to warm up
door being opened too often motor stops then has to restart from the door open
problem thermostat
Jan 31, 2016 | Refrigerators
Intertherm Air Conditioner S3BA-042KA compressor and fan not working (has power)
It sounds like that unit is connected to a "power saving load controller" device from the power company. The power company can turn your unit on & off with a radio signal. If you manually activated contactor and unit ran. I would bet that the power company's device or the wiring connecting it is where the problem lies. Call the power company and have them check their device. If they tell you that the device has been tested remotely and is working fine. Explain to them that you can activate your unit manually and it works fine. They should not charge you to come out. Those "load controller devices" have a pretty good longevity record.
Jul 11, 2012 | Intertherm Heating & Cooling
My wife insists on screwing with our Honeywell UtilityPro Series thermostat and this time I suspect that she has changed something in the ADVANCED FUNCTIONS settings. Not the ADVANCED FUNCTIONS menu...
Not trying to be a smart alec or anything like that but have you ever considerd in a thermostst with a lock-out key pad. We use them at the day cares and have no problems with the stats anymore.
Jan 30, 2011 | Heating & Cooling
Compressor for air will not cycle on.
Check and see if you have a common wire on the thermostat. If you do not, then you will need to replace batteries if applicable.
If you do have a common wire, then batteries are not necessary for thermostat operation.
Even though the thermostat wires are secured properly and the thermostat worked fine in the heat mode, it doesn't mean it will work for the AC mode.
If you want to check the thermostat in an easy manner, you will need to jump out the Red and Yellow terminals at the thermostat. Be sure to turn off power first to the furnace. After jumping out, restore power to furnace. If the unit comes on, then your thermostat is bad. If the unit fails to come on, you have another issue. You can repeat this process at the outdoor unit with the low voltage lines if you feel capable. If unit comes on, your problem lies between thermostat and outdoor unit. If your unit fails to start, your problem lies within the outdoor unit.
Be sure to check any drain pans, float switches, or cut-out safeties installed that may cause this. Many contractors will wire in drain safeties to the outdoor unit to shut down the compressor in the event a drain line has clogged and backed up into the emergency pan. Of a condensate pump has failed.
If you do not feel you are capable of this, you may need to contact a local professional to come diagnose the situation. But those are a few simple tasks that you can complete yourself to narrow down a problem.
May 26, 2010 | Heating & Cooling
Honeywell T2060 UtilityPro Demand Control Thermostat
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 16, 2010 | Honeywell Electronic Programmable...
Honeywell UtilityPRO thermostat backlight won't go off
After posting that I was having the same problem, I found a solution.
I used these instructions http://www.hydro-temp.com/help/drawings/honeywell%2069-1894ES.pdf and followed the Installer Setup on pages 6 through 10. Basically you just need to enter the setup mode following the instructions, scroll to setting# 280 and change the setting from "1" to "0" then the backlight will turn off after 8 seconds. Don't change any other settings if you don't know what you are doing.
Jul 18, 2009 | Honeywell Electronic Programmable...
Air condition problem
What type of thermostat do you have? If the fan is not coming on and neither is the compressor, then is more than likely a problem with the thermostat of control units of the Air Conditioners. The fan will come whether the compressor does or not if the thermostat and control unit are working correctly. Check for twelve volt at the control unit of the air conditioner ceiling unit. (Red Wire, should be labeled)
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Outside Unit blowing air but not cooling and slight buzzing sound
The compressor is not coming on and some part of that unit has failed. Do you hear any clicking sounds along with the buzzing sound? Recommend that you shut the unit down (remove power from it) until a service tech can listen to it try to start up.
The power company-installed load management system is probably a red hearing. That system will either fully turn off the unit or allow it to turn on/start up.
May 08, 2009 | Heating & Cooling
Compressor short cycling
If the compressor is run off of a relay then you could install a delay timer to prevent short cycling.
http://www.climatedoctors.com/items/item.aspx?itemid=429504
Jun 04, 2008 | Dometic Heating & Cooling
Heating & Cooling Logo
691 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
