Question about Ricoh Office Equipment & Supplies
Is there a way to delete all stored data/memory on a Ricoh 4420L Fax Machine?
    New Friend:
  • 13 Answers
Error 0548H Ricoh fax 4420L
Fuser Error. Check fuser thermistor. reset fuser error. Go to Service Mode press 1 0 7 , clear/stop , 1 copy, 5 mode, ok, 810, ok, change to 1, press half tone and ok simultaneously. fax will rebook automatically and fuser error is reset.
Jun 20, 2015 | Ricoh Office Equipment & Supplies
Mx 320 fax showed me memory full, How can I delete the memory? I need to send a fax but I can't.
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will automatically store it in its memory.Ink has run out while receiving a fax.Paper has run out while receiving a fax.
  • Paper other than A4, Letter, or Legal-sized papers are loaded.
  • OFF is selected for Auto Print in User Settings.
  • You pressed the Stop button to cancel printing of a fax.
1. Make sure that the plain paper is loaded in the Rear Tray.
2. Display the Memory reference screen.
(1) Press the FAX button, and press the Menu button.
(2) Use the left.gif(-) or (+) right.gif button to select Memory reference, and press the OK button.
3. Print all the received documents in the memory.
(1) Use the left.gif(-) or (+) right.gif button to select Print all RX docs.
  • To print the list of documents in the memory, select Print memory list.
  • To print a specified document, select Print specified doc..
  • To delete a specified document, select Delete specified doc..
  • To delete all documents in the memory at the same time, select Delete all documents.
(2) Press the OK button.
(3) Use the left.gif(-) or (+) right.gif button to select Yes, and press the OK button.
The machine starts printing documents in the memory one by one.
(4) Use the left.gif(-) or (+) right.gif button to select Yes
To keep the document in the memory, select No.
(5) Press the OK button.
  • The deletion confirmation screen will appear each time after one document is printed. Repeat the same procedure until all documents are printed.
Sep 21, 2011 | Canon Office Equipment & Supplies
How do I delete stored faxed numbers (speed keys)of the fax machine? How do you change a speed key title?(let say I fax documents to this fax number everyday: I stored the fax number under the name "Team...
From Ricoh Aficio MP2550 manual:
Delete destinations registered in the LAN-Fax Address Book:
numb01.gifOn the [Start] menu, point to [All Programs], [LAN-Fax Utilities], and then click [Address Book].
The [Address Book] dialog box appears.
If LAN-Fax Driver has already started up, click [Edit Address Book...].
numb02.gifClick [New/Browse...], and then select the CSV file containing the address list to be edited.
numb03.gifSelect the destination you want to delete so it is highlighted in the list.
numb04.gifClick [Delete].
numb05.gifClick [Yes].
numb06.gifClick [Close].
numb07.gifIf you made changes to a destination, a confirmation message appears. To save the changes, click [Yes].
If you do not want to save the changes and want to quit editing, click [No].
To return to the editing display, click [Cancel].
The confirmation dialog box does not appear when you have not made any changes after starting Address Book.
You can download the manual (HTML or PDF/ZIP versions) from here:
Jul 29, 2009 | Ricoh Aficio GX5050 GelSprinter InkJet
Ricoh 4420L fax machine
Go to
Click "Downloads"
Click "Download Ricoh manuals"
Under "Facsimile", click the drop down
box, highlight 3310LE, click "Go".
Download both manuals.
In the Advanced manual, page 84, shows the
settings to turn off or on memory or immediate
transmission result reports.
Jul 13, 2009 | Ricoh 4420L Printer
Ricoh 4420L ink isn't fusing to paper
If you are using regular fax paper, the paper is fed in up side down-real fax paper does not use ink-it uses impressions and the paper needs to be flipped upside down.
Mar 16, 2009 | Ricoh Office Equipment & Supplies
On Ricoh Aficio 2027 say error SC 873, the machine print by her self
Needs to delete e-mail data in the hard drive sp5-832-008 Enter service mode and run this sp mode
Oct 07, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Printing same page
try this make sure that receive reduction is switched on. You could load the paper tray up and just let it print as may have been a communication problem from RTI memory. Being Richo machine you should be able to reset the memory but this will get rid of all your stored numbers. But it will reset the machine so if you have a corrupted memory issue this will get rid of it.
Hope this helps you
Thanks J
Sep 11, 2007 | Ricoh 3310LE Plain Paper Laser Fax
54 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
