Question about Garden
Hi, can i adjust the position of the tiller arm on my 6hp, its really uncomfortable at the moment forcing me to use my left hand, almost like it needs to be in a different position
    Top Expert:
  • Garden Master
  • 51,171 Answers
If you have the technical knowledge , you can adjust , bend , modify anything to make the operation suitable for you
if not take it to an engineering shop that can do the job
Posted on Apr 24, 2017
My 2stroke 6hp mariner s idle is way too fast
Adjust the tickover speed. There are lots of videos here. There is a screw stop on the linkage. If operate the linkage by hand you will see it. The Evinrude video shows this well.
http://www.bing.com/videos/search?q=6hp%20mariner%20adjust%20idle&qs=n&form=QBVRMH&pq=6hp%20mariner%20adjust%20idle&sc=0-13&sp=-1&sk=
Jun 27, 2016 | Boating
How to adjust governor on a Tecumseh hmsk80?
Static Governor Adjust.
With the engine stopped, loosen the screw holding the
governor clamp on the governor lever. Rotate the clamp in
a direction that will force the throttle shaft open and allow
the governor follower arm to rest on the governor spool.
Push the governor lever connected to the throttle to the
wide open throttle position. Hold the lever and clamp in
this position while tightening the screw.
Feb 27, 2015 | Tecumseh Garden
ADJUST FUEL GAUGE FLOATS 2003 SOFTAIL
Hi Anonymous, always check your instrument fuses first also you could have a faulty sending unit or guage, there could be a problem with your wiring. On models with the fuel gauge posing as a left hand fuel cap the gauge is a press fit do not try to unscrew it, simply ample force lift up in a rocking motion to remove gauge. Disconnect wires to the gauge and with a set of positive and negative jumpers from the battery connect the positive jumper and flash the negative, gauge should peg full, if not replace gauge. With a test light check for power to the sending unit, then remove the sending unit and manually operate the float arm slowly with the correct wiring hooked up to the fuel gauge and sending unit and the ignition on, the gauge should respond accordingly if not replace the float arm assembly. For a free wiring diagram please visit the website below. Good luck and have nice day.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 14, 2012 | 2003 Harley Davidson FLSTC Heritage...
When trying to pull start a briggs 6hp roto tiller motor, it fires then rips the pull cord out of my hand, seems like it want's to start in the opposite direction?
DID WE CHANGE THE MOTOR ? THE BLADE ON A LAWN MOWER ENGINE IS THE FLYWHEEL. IF NOT IT SOUNDS LIKE THE KEY IN THE FLYWHEEL IS SHEARED , THIS ALSO WILL CAUSE THIS PULL CORD ISSUE... .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Dayco Garden
Engine part for Tecumseh 6hp 195cc
The float and pin can be bought as a repair kit., and replaced.
Mar 24, 2010 | Mtd Products Yard Machines 158CC Tiller
Manual needed
karen,
do a web search to see if you have a sears appliance service center nearby.if so they should be able to order that manuel for you.....chris
May 12, 2009 | Garden
My rear tine tiller lurches out of control when I use it
Hi it sounds like you are trying too till the soil with the tiller in the fast position and probably too deep for your first pass. Really the fast position is for transporting the tiller from the field. Try putting the tiller in slow which would be the down position. Turn the throttle all the way foward, engage the tines and push your depth rod on the back down to where it is only going into the soil about four inches or even less depending on the hardnes of the soil. Even though a Troy is the best Tiller made it will try to run away with you when your trying to hog the soil all at once. Your depth setting is very important and people seem to forget the importance of adjusting it. Try these things, and remember to alway's start your tilling in the slow full throttle position. Lowering your depth a little at a time. Till you find the appropriete feed for your speed.
Jan 07, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Ice maker does not make ice. Shut off arm staysin up position. The manual specifies that this arm can not be forced by hand. How can I lower that arm?
hi thanks for the question all the ice makers i have seen you can move the arm by hand so i would move it thanks cause it wont make ice with arm in up position thanks the appliance doc
Sep 07, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
