Question about Refrigerators
Mechine will not drop ice cubes - Refrigerators
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Move the lever up and down that tells your ice machine that it is full. Try reseting it with a button usually on the front.
Posted on Apr 25, 2017
SOURCE: Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Posted on Aug 10, 2008
Sea Breeze
  • 4655 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
  • 358 Answers
SOURCE: ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Posted on Aug 17, 2009
  • 884 Answers
SOURCE: samsung refrigerator rf26v ice maker
Check the condenser is clean and clear. Remove all fluff, dust or dirt from under and behind the unit
Posted on Apr 23, 2012
machinetech7
  • 1344 Answers
SOURCE: emerson ice maker not freezing ice, making small cubes and they are soft and mushy.. seems to not freeze ice solid and takes forever to drop ice
When was the last time you cleaned it by running ice machine cleaner through it. After a period of time algea, or slime will form on the chill plate where the ice is made. Sometimes its invisible to the eye, but it doesn't mean its not there. When this happens the machine will freezse the water, and when the ice tries to slide forward to the cutting grid, it catches on the chill plate. There are no sensors in the machine to tell it that this is happening and so the machine moves forward and starts running more water across the plate, which in turn runs across the ice caught on the chill plate melting it and using it as a ramp to fall into the bin melting the ice there as well. So, try cleaning it before taking any further steps, then if the problem persist feel free to get in touch.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Posted on May 15, 2012
Kenmore icemaker tray leaking water (model 795.51022.012)
Do the old 'KISS" thing first (keep it simple ......thing). Chances are that there are tiny calcium deposits in the ice tray which makes an ice cube stick in the tray. If one ice cube sticks, the water will overflow as it needs all the trays empty for the filling. The water will drip down into the freezer area causing chunky ice and stalagmites. The calcium deposits are very teeny in size but will hang up an ice cube from dropping. If more than one ice cube (basically all the ice cubes) didn't drop then the heater in that unit that initially gets the ice cubes to drop could be bad.
I've taken the ice cube assembly out and used vinegar with baking soda to dissolve the calcium and that worked. I left it in for a couple of days. "Do NOT" use anything like a knife or whatever to scrape the bottom of the tray as it will destroy the finish and keep the ice cubes sticking.
When I had the warranty service come out, the technician explained what happened to the tray (calcium). He replaced the tray but the next time it happened I used the vinegar and baking soda. I eventually bought a new tray for 1/2 the price on the internet when the problem happened later on in life.
Jun 13, 2014 | Kenmore Side by Side Refrigerator
WHY DOES MY ICE MAKER ONLY MAKES ICE SOMETIME
Are the cubes normal - the right size, not hollow? Once frozen and the harvest cycle begins, does it take longer than a couple minutes for the cubes to drop? After the ice drops does it fill with water each time?
If everything checks OK the last thing is very important. The rate at which an ice maker produces cubes depends on the temperature of the freezer - the colder it is the quicker the cycle. Try nudging the controls up a bit and wait 24 hours.
May 31, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Not making ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice maker dripping water fusing ice cubes
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mod. GS6NBEXRS01 not dumping ice. there is ice in the ice-maker. the dispenser for the water working ok.
take the bin out and check for a jammed ice cube in the ice cube making mechanism. Many times they have a rotating finger that gets stuck on a cube that does not drop entirely. Hope this helps
Jul 13, 2009 | Kenmore 74252 / 74254 / 74259 Top Freezer...
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Ice Cubes won't drop out
The thickness probe should be approximatly 1/4 inch off of the evaporator.Sounds like you might have loose grids on the evaporator.turn the unit off and remove the curtain.use a flash light and inspect the grids.There should not be space in between the joints,if there is the ice will freeze behind the grids and not properly release when in harvest. Also gently pull at the grids,if they pull towards you or wiggle then they are separating. I have removed one of the grids and had the unit continue to run for sometime until the evaporator could be replaced.The plating being spotty causes release issues as well.Finally check the level of the machine,front to back and side to side.Not being level will also cause release problems
Feb 18, 2009 | Freezers
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker
check the ice dispenser is there ice in it and if not check water supply to it.
Jul 20, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Loud sound
Very common to get a peice of plastic from the cube guide stuck in the impellar of the pump. Pull hoses off, look inside white housing on the pump, you may find a peice of plastic in there. Or is ou have broken slates in the cube guide from time to time smaller peices of ice will get in there. then the sound comes and goes. Of course it could actually just be the pump. :)
Jun 05, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
