Can tubing come out right or left on indoor unit as pic shows coming out right side and my connectors are on the left
  • Heating & Co... Master
  • 1,711 Answers
On a wall hung unit the pipes can come out either side.
Posted on Apr 24, 2017
How do I remove the Main PCB from an LG ArtCool C12AWR or disconnect air sensor of indoor unit ?
Disassembly - Indoor Unit
Disconnect the unit from power supply before making any checks.
Be sure the power switch is set to "OFF".
To remove the Grille from the Chassis.
• Set the up-and-down air discharge louver to open
position (horizontally) by finger pressure.
• Remove the securing screws.
• To remove the Grille, pull the lower left and right
side of the grille toward you (slightly tilted) and lift it
straight upward.
1. Before removing the control box, be sure to
take out the wire screwed at the other end.
2. To remove the Control Box.
• Remove securing screws.
• Pull the control box out from the chassis
carefully.
3. To remove the Discharge Grille.
• Unhook the discharge grille and pull the
discharge grille out from the chassis carefully.
4. To remove the Evaporator.
• Remove 3 screws securing the evaporator(at the
left 2EA in the Eva Holder, at the right 1EA).
• When repair, do not damage the Caution label.
• Unhook the tab on the right inside of the chassis
at the same time, slightly pull the evaporator
toward you until the tab is clear of the slot.
5. To remove the Motor Cover
• Remove 2 securing screw.
• Pull the motor cover out from the chassis
carefully.
6. To remove the Cross-Flow Fan
• Loosen the screw securing the cross-flow fan to
the fan motor (do not remove).
• Lift up the right side of the cross-flow fan and the
fan motor, separate the fan motor from the
cross-flow fan.
Sep 07, 2015 | LG Art Cool LA121HNP Split System Air...
Can not blowing as hard as it should. Compressor kicking on but freezing up easily. Any ideas?
Check your filters and make sure that there is adequate airflow, also make sure that any drain tubes are not plugged.
Jul 03, 2015 | Heating & Cooling
How to chang heater cor inP/T croser
It is pretty involved requiring discharging/disconnecting the AC, Dash board and other components. If you are up to it I found these step by step on the Autozone web site.
As seen on autozone's web site (/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8075b324)
Instructions -
Before servicing the vehicle, refer to the Precautions Section.
Remove the A/C refrigerant using the approved equipment.
Drain the cooling system.
Disconnect the negative battery cable.
Remove the instrument panel by removing or disconnecting the following:
The left and right A pillar trim moldings using a trim stick
The front power window switch
The center bezel retaining screw
The Heating, Ventilation, and Air Conditioning (HVAC) control knobs
The center bezel using a trim stick
The top cover retaining screws and pull it rearward to remove
The HVAC control unit from the instrument panel
The retaining screws from the upper and lower steering column shrouds
The left lower instrument panel bezel
The steering column wire connectors
The steering column
The brake pedal support bracket
The left side instrument panel end cap from the wiring connectors
The rear power window switch from the console and pull the parking handle all the way up
The auxiliary power outlet wire connector
The center console
The glove box assembly
The right side instrument panel end cap
The 5 right side instrument panel wire connectors
The instrument panel from the vehicle, with the help of an assistant
Remove or disconnect the following:
The heater hoses from the heater core
Reposition the vehicle speed control servo, if equipped
The suction and liquid lines from the evaporator
The drain tube
The A/C vacuum harness connector
The defroster duct from the heater A/C unit housing
The heater A/C unit housing from the vehicle
The heater core from the housing
To install:
Install or connect the following:
The heater core to the housing
The heater A/C unit housing to the vehicle
The defroster duct to the housing
The drain tube
The suction and liquid lines to the evaporator
The reposition the vehicle speed control servo, if equipped
The heater hoses to the heater core
Install the instrument panel by installing or connecting the following:
The right side instrument panel wire connectors
The center console
The left side wire connectors
The steering column with a new pinch bolt
The center bezel
The negative battery cable
Fill the cooling system.
Recharge the A/C system.
Start the vehicle and verify proper system operations.
Road test the vehicle and check for any rattles or leaks, repair if necessary.
Nov 16, 2014 | 2001 Chrysler PT Cruiser
I need to know how to remove the torque converter in the transmission of a 2005 Mercury Mariner
The torque convertor is the part between the engine and the transmission. It is bolted to the "flex plate", or flywheel. You have to remove the engine or the transmission to gain access to it.
Battery cables Battery and tray Breather tube Mass Air Flow (MAF) sensor Intake tube and air cleaner cover Air cleaner assembly Transmission Range (TR) sensor Heated Oxygen (H0 2 S) sensors Transmission harness connector and bracket Wire harness bracket spacer and move the bracket aside Shift cable Shift cable bracket and move the bracket aside Starter electrical connectors Starter Electrical connectors from the valve cover and install an engine support bar Upper transmission retaining bolts Left side upper transmission mounting plate Rear transmission mount Right side engine mount bolt and slightly raise the engine Both front wheels and splash shields Right side halfshaft and intermediate shaft assembly after matchmarking them Cross brace Center exhaust pipe and rubber hanger Front exhaust pipe and flange Rear exhaust pipe flange Driveshaft PTU vent tube Lower transmission bracket Access cover Flexplate nuts Output Shaft Speed (OSS) sensor Turbine Shaft Speed (TSS) sensor Fluid cooler tube and move it aside Fluid cooler line and install a transmission jack Bolts from the PTU unit Transmission with the PTU unit attached
Jun 10, 2011 | Mercury Mariner Cars & Trucks
My water dispenser is not woking on my electrolux refrig.
You can check to see if it's the line or just the dispenser by checking at the valve underneath the door. There is a plasic face that pops off and you will see where there is a white connector with blue seals on either side (it's small, the connector is just an inch long). You can take the water line tube off of that connector by compressing the blue sleeve into the connector and pulling the tube out at the same time. I usually disconnect from the right side, as the water comes from that side. Afterwards, get something to catch the water by placing the ends of the tubing into a bowl (they don't like to sit there, so you'll need to hold them in place) and pressing the water dispense lever. If water comes out of the left side, then the line is frozen somewhere after that connector. The tube runs up the outside wall of the freezer door. The easiest way that I've found to thaw it is to set a space heater/radiator next to that edge of the door. It should heat up the door enough to thaw the line inside of it inside of an hour or so. It is a total PITA, but is effective. Set your freezer temp to 2 degrees instead of the factory 0. That helps too. I feel your pain. I expected more from this model.
Feb 04, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
How to replace fuser unit
Hello,go to back side of printer & open the flap u will found two serews open them push the tray & open the two locks at right & left bottom then back pannel will come out.pullout the white strip where the power connector inserted you will find fuser connector (black,white wires)open 4 screws on which fuser wire attached detach two connectors situated right side wall of printer& you will find a teeth lock on the bottom side of fuser press the two leavers & pull outwardly & also pull out the unit outwardly & do as viseversa for fixing the unit.
Oct 08, 2010 | HP LaserJet P3005n Printer
HOW TO RECHARGE SPLIT TYPE AIR CONDITIONER WITH USING r22
check cooling coil(in door unit)if there ice buil up then feel air vent if no air mean your fin block aready need to clean / air vent ok meant there have a leak .you need r22 test gauge and hose,reamer,tube cutter and flaring kit. 1)check suction pressure(big tube at out door unit) remove 2 way cap and 3 way cap valve then connect blue hose at service port 3 way valve (port locate at left or right depent on manufacturer) you will get pressure about 40-45 psi(air cond is running) then use a allen key(hexagonal wrench) to close 2 way valve(small tube or gas discharge side) wait 1-2 minute then close 3 way valve (suction tube or big tube) IMMEDIATELY SHUT OFF AIRCOND AND PLUG OUT POWER CORD (you need 2 person one at in door unit and the other at out door unit). this method is to keep remaining gas inside the compresser.Then leak check ,open 2 way valve about 90 degree hold it for 10 minute then close it .MEASURE THE PRESSURE keeep it for 5-10 minute. If the pressure indicate not same during the first time measured it meant there have a leakage, for air cond 1- 5 year the leakage will happen at the copper tubing connection and improper flaring .Then U need to clean in door and out door unit ,used a spanner or wrench to losen the copper FLARE NUT at out door unit and in door unit( inside insulation) then use pvc tape to cover all copper pipe/tube hole to prevent dirt go inside tube/pipe. Then lift up out door unit and used coil cleanner ditergent wait 5 minute then flush with water. Remove indoor front panel then disconnect out door unit cable at front panel in door unit then lift up indoor unit to disangage the hook and pull out the indoor unit, then clean the cooling coil ,cover electrical part with plastic .last step u need to cut (used cooper cutter)the copper pipe/tube FLARE NUT connection low side(big tube) and high side(small tube) in door connection and out door connection .Then u need to remove the burr from cut edge using reamer make sure metal powder not goes in Then make a flare after inserting FLARE NUT onto the copper pipes Then U can install back the unit check the low side pressure if the pressure 55-67 psi no need to charge
Jul 03, 2009 | Heating & Cooling
Airforce 12000BTU Air Conditioner wiring problem
The outdoor unit should have 2 small wires connected to the contactor coil. This delivers the 24v "Signal" to energize the coil. The wire from the t'stat for cooling are usually yellow, in almost every case. When you put the t'stat in the cooling mode and set the temp lower than the room temp, the indoor and outdoor unit should come on. Check for voltage on the terminal block for 24 volts accross the yellow and common wire. Common could be ground on some handlers. If you have the 24 volts, then check for 24v on the 2 small wires (usually 18 to 22 gage wire) on the contactor coil. If no voltage, trace the 2 wires back to the indoor unit and see where they go. If they are the ones that are not attached, put one on the yellow wire terminal and the other on the common terminal. This will send power to the indoor unit and then piggyback to the outdoor unit. Do not remove the yellow and common from the terminal block. Don't be too concerned about the colors from the outdoor coil wires. Just make sure they are hooked up right. Good Luck and hope this gets it going.
May 14, 2009 | Heating & Cooling
2430 dl paper alot of paper stuck
Hello
best way to check FU is take it out from printer,
first remove backside and left side cover, in backside there is a 4 small wires with 2 pin connectors you have to unplug connector, in left side there is a bigger withe and black wires, you have to unplug connectors. then open cover and remove *PC drum, also remove transferbelt, first remove 2 screws, 1 screw at each side, then unplug connector upper right and lift and remove transfer belt.
BE VERY CEARFUL WHEN OPERATING WITH TRANSFERBELT. DO NOT DAMAGE THE BELT.
then you cand remove 2 screws at each side of fusing unit, when moving the whole FU to right /maybe left, dont remember/ you can bull out the fusing unit. its a little tricky to take it out.
when you got the FU in your hands, you can inspect it, remove any paper, stuck. AGAIN, BE VERY CEARFUL, DO NOT DAMAGE THE RED ROLLER AND DO NOT USE ANY SHARP THINGS.
when needed you can also remove a few screws at the fusing unit and then you can take the fu a part to see whats wrong.
good luck.
Jun 27, 2008 | Konica Minolta magicolor 2400 Laser...
HOW TO DISARM THE CARRIAGE
a vcr carriage has at least one or maybe two little plugs going to it from the main circuit board, unplug whatever lines that are going to it. don't cut any wires.
Apr 27, 2008 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
