Question about Home
Finding shower faucet parts for RV? - Home
  • 28 Answers
Hey Donna! I get many things from ebay. You may need a pay pal account which is one of the safest online transactions available. H49nc6dere is a link! 778results for rv shower faucet
Posted on Apr 26, 2017
How do I winterize my 2015 Jayco Jay Flight 32 RLs
Go to an RV parts store for a winterizing bypass kit for the water heater. Use POTABLE RV antifreeze and follow the instructions on the bottle. Drain all the water out of the water tank. Install the bypass kit on the water heater if it doesn't already have one. Put the water heater in the bypass mode. Add the antifreeze to the water tank. Open every water faucet including the shower head one at a time until antifreeze is present. Do this for hot and cold on every faucet. Once that is done, turn off the water pump and open all the faucets. That's all there is to it. Rember... DO NOT use automotive antifreeze. It will kill you.
Oct 24, 2016 | RVs
Where to buy handle adapter for glacier bay bathroom faucet
Glacier Bay is a generic faucet brand sold by Home Depot. Good luck finding any parts for it.
Jul 13, 2014 | Home
Hot water only runs for a few secons durning showers in rv
when you run out if hot water in the shower can you still get hot water in the othert fawcetts???
May 29, 2014 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a delta tub shower faucet with a pull-out diverter. The model is "Delex" by Delta as stamped on the cover plates. I have not had any luck finding a replacement diverter. Neither Delta U.S...
take the details to a plumber supply shop ( where the tradies get their parts ) and discuss the problem with them
it is very possible that there are other makes that will fit in the holes to replace the delta unit
Mar 25, 2017 | Delta & Single Handle Shower Faucet
Need an instruction sheet for cartridge replacement for Danze Sheridan tub and shower faucet
This link will get you to the Danze illustrated parts list for the Sheridan single control tub and shower valve.
http://www.danze.com/products/pdfs/D510055_ip.pdf
Aug 08, 2010 | Danze Sheridan Tub & Shower Faucet
Cold water runs through the faucet shower but no water at all through hot water side
If no hot water at any faucet, and your sure water in water heater is hot, check by-pass at back of tank for wrong positioning.
Jun 25, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Delta T13090 faucet shower head working at the same time.
The only possible explaination is that the water is finding it easier to go up than down. Water is lazy, just like me. ;)
Use an allen key to remove the tub spout. It's underneath and awkward. Once the allen key is loose, the spout just slides off. Try running the water. This may solve your problem and all you'll need is a new tub spout. If not.....
Turn the water off to the house.
Use an allen key to remove the handle.
Use a phillips to remove the trim plate (2 screws). Cut the silicone around the trim if it's there (which, in a proper installation it shouldn't be, but...)
Unscrew the nut (usually chrome) holding the cartridge into the brass body of the valve. The cartridge pulls straight out. Check for restriction in the ports of the cartridge itself. Check for restriction in the line going down to the tub spout. If you can't find anything, replace the cartridge.
Reassemble & Enjoy!
Aug 05, 2009 | Delta & Single Handle Shower Faucet
Water only comes out shower head, won't come back out faucet. The shower plunger only puts water out shower head, not out faucet.
sounds like the diverter is jamed. it may be in the spout or a button in the escheuchon. if spout try to unjam the pull up knob or the pull down ring. if in the escheuchon remove part and replace.
Jul 12, 2009 | Delta & Single Handle Shower Faucet
Parts for sterling shower faucet
http://www.sterlingplumbing.com/contact.strl
The above link is the contact info for Sterling Plumbing Company. You can contact them and they will either be able to mail the parts out to you directly or tell you where you will be able to find repair parts.
Apr 17, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Just installed shower and faucet in bath tub when you turn the water on the water comes out of the faucet and shower head. When you pull the lever for just the shower the water cuts off at faucet and comes...
Verify the height from the shower valve to the Shower head, the instructions specify the correct distance if it is too short the pressure could be getting up to the shower head.
Perhaps the water pressure it too high at the valve not allowing all the water down the faucet outlet, there are set screws on the sides of the shower valve to adjust the water allowed in the mixing chamber.
Something is restricting the water flow to the faucet, creating enough pressure to send some of the ater supply up to the shower.
I hope some of these ideas help
Mar 01, 2009 | Plumbing
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
