Question about Sewing Machines
Do you have a 158-10301 needle plate - Sewing Machines
  • Sewing Machines Master
  • 11,774 Answers
Contact Sears
Posted on Apr 25, 2017
Pfaff tiptronic 2020
It adjusts the needle plate position front to back.
Mar 25, 2016 | PfaFF Sewing Machines
Why does the fabric get stuck in the feed dog plate?
try changing the needle it could be blunt
also make sure the top thread has not come off the thread take up lever
clean under the needle plate and in the bobbin are for lint
Mar 24, 2016 | Brother Se425 Computerized Embroidery &...
Neddle hits the plate, how do i fix it ?
check that the needle is fitted correctly
check for bent needle
check for correct needle
May 23, 2015 | Sewing Machines
Bernina 1630 needle plate won't stay tight--when you put the plate on it moves around and is easy to take off
For heaven's sake Michael D. Hannan, do your home work, understand specific features of the machine and get your facts right before you mislead somebody with an incorrect answer: the Bernina 1630 needle plate is not fastened by screws but by spring clips.
To Anonymous,
If the needle plate was properly held down before, then you have either not replaced it correctly or you have removed it clumsily and bent the spring clips that retain it. Read the manual or follow my directions to remove and replace below.
First, examine the needle plate:
Pick up the needle plate and turn it over. Look at the two spring clips: they should be firmly fastened to the needle plate by the two small screws - if not, use a very small screwdriver to tighten them. Now look at the other end of the spring clips: the gap between the spring clips and the needle plate should be very close to 3mm. If significantly over that, the needle plate will not be held firmly. You cannot bend them back into place without removing them first.
25543442-pehiy0tulmvwe1t4xzm3pcfl-1-0.jpg Fix spring clips if damaged:
For each clip, you need to hold the end with the hole in a vice, right up to the first bend. Gently bend the rest of the clip bit by bit back to the correct position, testing each time you bend it. Refit the clip and repeat for the other. Don't use heat or you will destroy the elastic properties of the clip. If the clip is bent too far, it will break and you'll have to order replacements from your Bernina dealer.
How to remove the needle plate:
Open the bobbin cover. From the front of the machine and using your thumb, push up under the curved front edge of the needle plate just enough so the locating dowel comes out of the hole at the front left. Simultaneously slide the needle plate back a bit. Lift up slightly against so the curved front of the needle plate comes over the edge of the free arm casting. Slide the plate back a bit more to free it completely and you can then lift it out.
25543442-pehiy0tulmvwe1t4xzm3pcfl-1-2.jpg 25543442-pehiy0tulmvwe1t4xzm3pcfl-1-5.jpg 25543442-pehiy0tulmvwe1t4xzm3pcfl-1-9.jpg
How to refit the needle plate:
Place the needle plate in the gap with the curved edge about 20 mm behind where it will end up. Slide the needle plate forwards until the curved edge comes up against the locating dowel and lift it sightly over the dowel. By this time the spring clips will be partly engaged. Now push the needle plate forwards from the rear until it goes forwards and drops into place. 25543442-pehiy0tulmvwe1t4xzm3pcfl-1-14.jpg 25543442-pehiy0tulmvwe1t4xzm3pcfl-1-20.jpg 25543442-pehiy0tulmvwe1t4xzm3pcfl-1-27.jpg I hope this helps. Foot and needle removed for clarity. Pictures taken on a Bernina 1030 which is the same in this area.
Mar 09, 2015 | Bernina Sewing Machines
Needle breaks hits needle plate
Check to see if plate is damaged or needle is bent. Could be wrong needle style for the type of work you are doing.
Jan 27, 2012 | Singer Sewing Machines
My needle keeps hitting the throatplate, (I have broken 2). It was working fine. I don't know what I have done to cause this! e.
First, check the position of your needle.Machines with zigzag capability allow you to adjust the position of your needle left, right,or center. If your needle is not in the correct position, it may be hitting your needle plate. If that doesn't work,change your needle plate.
If you've been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
I hope this helps.
Mar 22, 2010 | Sewing Machines
Needle breaks because it hits the area around the bobbin.
Here are a few things to check. You may have checked some of these already but it may be worth checking again.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but check your manual), make sure that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot
Make sure it’s attached securely.
* Change your pressure foot
Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins
A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew
You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate
Make sure it's securely in position.
* Change your needle plate
If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics, switch to a needle plate with a wider hole.
* Check the position of your needle
Sewing machines with zigzag capability allow you to adjust the position of your needle – right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 30, 2009 | Sewing Machines
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric.
    If this doesn’t seem to be the problem
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Sewing Machines Logo
23 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
