Question about Electrolux Dryers
I have a Electrolux EDV505 cloths dryer that when you pres start the drum moves slightly but dose not turn all you hear is a buzzing noise, have replaced control board as per suggestions on line.
I have a Electrolux EDV505 cloths dryer that when you pres start the drum moves slightly but dose not turn all you hear is a buzzing noise, have replaced control board as per suggestions on trouble shooting web pages but has not fixed, is this the capacitor or the motor at fault?
  • 1462 Answers
SOURCE: The Drum on my LG DLE2512W Dryer will not turn
no problem with motor or control board. fault is with the motor capacitor only. this is often attached to the motor or near it. the value of the capacitor will be printed on it (usually about 8uf) and you should be able to source from an electrical spares shop
Posted on May 23, 2007
  • 291 Answers
SOURCE: Dryer drum will not turn
Try pushing start button while turing drum clock wise and see if drum will start spinning, sounds like bad start winding or relay
Posted on Sep 17, 2007
  • 1462 Answers
SOURCE: Bosch tumble dryer - drum
belt is broken - bit of a pig to fit. take top off and you will see that there is no belt round drum
Posted on Sep 25, 2008
  • 3463 Answers
SOURCE: hotpoint vtd00p tumble dryer giving
I assume you fitted the right value capacitor and connected it up correctly,if you have then slip the belt of the motor, and make sure it is free to turn with no resistance.
Try it without the belt on, if it runs o/k then problem is elsewhere, if it still does not run , then you could have faulty motor, and or timer. That is as much as I can help you.
Plz rate my solution.
Posted on Dec 22, 2008
  • 749 Answers
SOURCE: Loud buzzing noise
seems the the motor is ****! avoid switching it more further to prevent its motor from burning!
motor could be stuck due to rust build-up.
or something might have jammed along the motor area or along the rotating part.
Posted on Jun 18, 2009
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
Electrolux front load dryer does not start
if it makes a humming noise for a short peiod then stops and after a while it does it again the drum maybe stuck and making the motror go off on overload try turning the drum by hand and see how it spins
Jan 08, 2013 | Dryers
When Itry to start my dry, it won't come on and I hear a noise(like an electrical relay when it stuck on)
the dryer drum belt is broken and there's a belt switch that shuts off the unit to prevent a fire from the drum not turning and the clothes overheating,the buzz is the motor start switch trying to start the dryer
Mar 08, 2011 | Frigidaire AEQ6700FS Dryer
When pushing dryer start button, a slight buzz is
the noise is coming from the motor,if you can spin the drum by hand and it moves freely you have a bad motor and need to change it out,next time send model number and the brand name of dryer,if it doesn't spin,the belt could be jammed up or something stuck in the blower wheel,let me know how you make out
May 13, 2010 | Dryers
When i turn for start i hear a buzzing sound and
Sounds like a potentially bad motor. When trying to start the dryer, it may have opened the thermal protector, which is why you are no longer getting the noise. Check that nothing is just stuck in the drum seal or blower wheel, seizing the motor. If all is clear, replace the motor.
Dec 30, 2009 | Electrolux Dryers
Kenmore Dryer won't turn on
This are the tipe on how to Troubleshot dryer follow the steps below
IF the dryer is noisy
Level the dryer
Check the drum belt
Check the drum support rollers
Check the idler pulley
Check the glides
Check drum bearings
Check the blower
Check the baffles
If the dryer tumbles, but there is no heat
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Good luck !!!!
Jul 03, 2009 | Kenmore 63942 Dryer
There are several things that can cause a dryer to be noisy. There are a lot of moving parts in a dryer that can cause noises to occur when they get worn. Several parts support the drum, and may make noise or vibrations when worn out. Many times a dryer will squeak just a little bit as it first starts. This should go away in just a few seconds. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks. The blower wheel is always moving and lint is constantly going by it. If it’s noisy, it may have gotten clogged with lint, or it may be worn and need to be replaced. Clean out the area around the blower. If it’s still noisy, replace it.
Many dryers use a center spindle to support the clothes drum. This spindle may be a ball-and-socket support, or it may be a shaft inside a sleeve. When these component bearings get worn out, they may make a squealing or rubbing sound. Replace this bearing when it gets worn out. Many dryers also use plastic glides in the front end of the clothes drum. When these glides are worn out, you may hear a lot of noise. If the glides are worn, replace them as a set.
Some dryers use rollers to support the clothes drum. If these rollers or wheels are worn out, they can be extremely noisy. You ought to replace the whole set at the same time. A belt that has been damaged or frayed may make a thumping or slapping sound as the drum turns.
The gas valve solenoid will make a buzz type of sound as it opens. The valve itself will give a little click as it starts the heat cycle, when ignition begins, and when the burner is turning off. The burner flame itself makes kind of a low-pitched roaring wind sound.
Thanks for using Fixya.
May 28, 2009 | Frigidaire Dryers
I have an LG TDC70080E condenser tumble dryer. It has worked perfectly for 2.5 years and now is playing up (suprising, considering it is just out of warranty!) There are two issues: 1. The drum is not...
My pump started making a loud noise and stopped pumping, I removed the pump and found that the impeller had moved down the shaft, so I put some locktite on shaft replaced impeller and its fine now
Oct 28, 2008 | Dryers
Dryer problem
You need to listen for the motor working ? Open the dryer door hold the door switch in and start the dryer . A buzzing sound may indicate a bad motor. If you hear a slight spinning noise ,it may just be the belt.
Sep 24, 2008 | Dryers
Sep 17, 2007 | Estate EED4300SQ Dryer
Dryers Logo
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
