Question about Refrigerators
Kickback door stop won't hold it keep slipping I replaced the bottom part of the door stop but it doesnot stop it
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
go to instru.manual section troubleshooting and fix it. God bless you
if doesnot have it download from www.fitness.manualsonline.com
However try this.
Sep 28, 2012 | Hotpoint Ultima WF860 Front Load Washer
Where do I find the front hood release on the car?
Bottom left next to driver's door is the pull handle.
Reach under the hood (you may have to pry a bit to get your fingers in there, particularly if the hydraulic gas lifts are dead so the hood stays down), slightly down and right from center. There's a flat lever you'll push right to release the catch.
Have about a 4' stick handy to prop it up if the lifts are dead, and make sure it's someplace which won't slip, if you do that.
Lube the mechanism with light oil such as 3-in-1 while you're there, and replace the lifts if they won't hold the hood up, not a big deal to do or costly...
Apr 16, 2011 | 2000 Mercury Grand Marquis
94 Pathfinder, Manual transmission slipping a tiny bit. I want to add Lucas Stop Slip. How do I do this. Theres no Dipstick to check levels of TRANS FLUIDS
Adding Stop slip to a manual transmission with not keep your clutch from slipping. Replace or adjust the clutch.
Mar 13, 2010 | 1994 Nissan Pathfinder
BOTTOM OF DOOR LEAKS
leaks are tricky to answer with a yes or know answer. but here are things to check, check your door seal for any tears or hold. makesure unit is draining properly and not overflowing,check water valve make sure connection is tight,make sure the latch is locking the door. you can start there and post anoyher comment if this doesnot help .
Mar 03, 2010 | Whirlpool Dishwashers
Freezer door will not stay shut is their a replacement for the maginetic strip bottom freezer small
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 21, 2009 | GE Refrigerators
Kenmore 25360132993 - wasn't closing / sealing. While working on it, it stopped closing altogether, seemed to have dropped 1/4 inch or something. Is it a cam? Is it a hinge? Is it the gasket? Is it the...
Sep 02, 2009 | Refrigerators
Door won't stay shut Have to remove the bottom shelf on the door to get the door to stay closed
To replace
Aug 30, 2009 | Refrigerators
Bottom on the vaccum the spin brush will not spin at all
Double check for anything that might be holding it from spinning (shoe lace, string, hair, ribbon, etc)
If the brushes are free to move by hand, you most likely have either a broken belt or a belt that simply came off the motor. What you'll need to do in either case, is open up the vacuum cover. The screws are usually located at the bottom of the vacuum (where the brushes are) and remove all the visible screws you see.
Most of the time (being that I don't know what kind of vac you have, that is enough to remove the top cover off for you to inspect either the motor or the belt which attaches to the motor. I know on my hoover, the belt slips off very easily, so I always need to keep my screwdriver handy to perform this.
Hope this helps.
Apr 19, 2009 | Vacuums
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
