Question about Sony Televison & Video
My Sony KDL 50w800c will not turn on.
I have tested the power source and it measures fine. I have also done a power flush. I am test the boards now to see if there is continuity.
quiero encontrar un driver de grafico para tarjeta madre phoenixbios
Posted on Oct 10, 2008
  • 157 Answers
SOURCE: sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Posted on Oct 07, 2009
  • 767 Answers
SOURCE: hobart handler 135 feed motor for wire doesn't
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill
point out what parts to check.and replace.
Posted on Dec 06, 2009
SOURCE: Dell Dimension 5100 will not power up. Was
Have you checked your monitor? Try your monitor on another PC and check it is OK. Once you change the MB battery you effectively "Kill" the PC, as all the settings in the BIOS are removed and must be reprogrammed. You must enter the BIOS, and select "Default" setup and then reboot, you must do this regardless of what else is done first.(A bit hard when you can't see anything" You say... "tried different power switch and ribbon cable connector" (sic) exactly what "Ribbon cable/Power switch"? Anyway as said check monitor, if it is OK, we will proceed from there, then, you must check your video card, test it in another machine, if possible, to see if thats OK, if it is OK, then it is now likely that you may have a Mother board problem. If you can, try another Video card to see if you get Video on screen. see we need to establish "Known Good" items, once we know whats what, we can then go on. Now if any of these things tested are faulty, Monitor, Video card, obviously replace them, however IF they are NOT faulty, as related it may be the Motherboard, Remove the RAM, and see if anything is on screen? If yes, replace RAM, If still NO, then take any cards out, and check, if then OK, replace cards one by one until you get to the one that stops it, there is your problem, replace it. All we are trying to do is get anything on the screen, if we do, then you must redo the BIOS, as related before. Now if you get it going it still may not boot through to windows desktop, if this is the case, after you boot press F8 and select safe mode, when you get asked if you want safe mode or system restore, choose system restore and choose a date before you had a problem that should get you back. You just have to logically work through, until you find the faulty "bit" and replace it.
Posted on Feb 22, 2010
Testimonial: "Thanks for the confirmation!"
SOURCE: Miller 130XP won't feed wire
need a replacement wire feed motor for a millermatic 130xp
Posted on Mar 21, 2010
Lcd tv repair
Start testing voltages on the power board for starters
Dec 12, 2017 | Sony Televison & Video
Hello Calvin,
I would suggest to change the input to a video with audio source to eliminate a main board failure.
If the back lights are not working, this could indicate that the inverter board is defective but there could also be a defective CCFL light failure.
You can find service parts in the link provided.
Let me know if you required further assistance. Search results for kdl 40bx450
Jun 08, 2017 | Sony Televison & Video
Phillips 52pfl5704d turns on screen blinks, no video
The replacement board could be defective. Your TV worked fine until there was a power loss so its time to troubleshoot to find out how the power loss affected the original board in theTV. There could have been a power surge.
Dec 12, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony KDL-40U2000 will not turn on. No lights at all, totally dead.
I think the 5 volts missing is your problem---it should come from the standby power supply and ought to be there all the time.
Look to the source for that voltage and check to see if a dead short to ground on that line.
Dec 20, 2012 | Sony KDL40U2000 40 in. HD-Ready LCD TV
Sony kdl-52s 4100 power supply ok but no sound and display
Well, if the power supply is in good working order, you will need to verify that the proper voltages are getting to the main board. If the main board is getting the proper voltages, I would bet you have a defective main board. The video and audio signals are generated on the main board. Expect to pay $100-$150 for a replacement main board.
Nov 24, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
No power 2 stanby blink light
It could be a power board problem. Why don't you please refer it to a qualified service technician?
Jul 30, 2012 | Son KDL-40EX600 40" LCD Edgelit LED HDTV
Hello, I've been given a Sony Bravia KDL-26ML130 LCD TV which is not working but I believe it may have a repair solution (hopefully!). The TV powers on fine but the display turns off just a second...
This tv problems are those long board call the LCD inverter boards,it is dead.TV should have 1 or 2 long boards that call the LCD inverter boards it it dead,these 1 or 2 long LCD inverter boards only job are to provide a backlight to the tv LCD screen panel to have screen light produce a picture.Tries websites like, to buy those refurbihes 1 or 2 long LCD inverter boards for the replacment.
Jun 18, 2011 | Sony BRAVIA KDL-46SL14098 LCD TV
Kdl-46v5100 tv now dos'nt recognize hdmi.says no
Try another HDMI cable. I have seen them become defective. If it is not the cable, then try another HDMI device to test the TV.
Without an HDMI cable tester, and a way to measure the output of the HDMI source device the only way to resolve this is with the process of elimination.
Jerry G.
Jan 19, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I turned the tv on and changed the channel. Now it says
What inputs have you tested.If your sure about the program sources and still no signal then replace the AU board.
Apr 21, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
