SOURCE: I have a 2005 Mercury Grand Marquis and I can't turn the wipers.
this is a very common problem on these vehicles. the wiper motor has a park switch built into it that fails. replace the wiper motor and this will stop problem. hope this info helps you!
SOURCE: how to replace starter +1993 Mercury Grand Marquis
disconnect battery,,jack car up,,put jack stand on frame,,take starter bolts out,(may not be easy),,take wires off starter,,hoped it helped,,
SOURCE: 2005 MERCURY GRAND MARQUIS GS LCM headlights
you can oder a cheap lcm from silverstatefordparts.com or sometimes u can just tap the lcm box and lights should turn back on.
SOURCE: how do I change out the Headlight/ Lighting
u can do it your self the lcm is a stand alone unit just unscrew dissconnect and reconnect and screw
SOURCE: where is the neutral safety
the neutral safety switch is located on the side of the transmission where the shift lever connects to the transmission
