Question about Vacuums
My power cord has been cut and need to replace. how do I take the greenworks51012 apart to do this
  • 163 Answers
How to replace cable cord
You will need to remove the screws where the cable enters the rear of the vacuum . You will notice the cable is retained with a small plastic clip , remove this clip, unscrew the cable cut out the damaged section and reconnect. Ensure retaining clip is replaced. Now put the screws back into the machine body,
Apr 26, 2014 | Miele S7210 Bagged Upright Vacuum
Switch on but no power
First thing to check is to see if the cord has a broken wire, either at the plug or where it enters the vac. Frequent flexing of the cord often causes one of the inside wires to break. If where the wire enters the vac you can take apart the handle, cut off the bad part and re-wire the cord.
Mar 14, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Euro Prox Model UV209-11 upright vacuum--
prise it apart I'm pretty sure it has clips much like a computer case.
Dec 13, 2012 | Euro-Pro UV209 Upright Vacuum
How do I get the u5290-900 apart far enough to remove old power cord and plug in a new one?
First you need to remove the Dirt Cup followed by the front cover / handle. Page 4 1-6 of the PDF Manual below shows how to do this.
This should then give you access to remove the internal cover and replace your cable.
Jun 26, 2011 | Hoover U5290-900 Upright Vacuum
How to put a switch in or do i need new one
By the question you asked I assume it wont power on. More than likely its not the switch . More likely its the power cord because it get most of the abuse. you will need a meter in any case to find out . If you don't have a meter you can pick one up for under $10 at any hardware section of most Dept store chains. A good investment. turn the meter to the omega symbol Looks like an upside down horseshoe with feet. touch the leads together meter should zero. place the probes across the end of the power cord plug. One on each tab. watch the meter and flip the switch while holding the plug and probes together. if the meter doesn't move the switch is probably ok. usually the cord plug or the strain relief going into the machine wares out but check the cord for cuts or unusual ware first. if you dont mind a few inches missing remove the bad area of cord and replace. to verify its the swich or not pull the unit apart and put the meter leads across the switch and toggle the switchthe meter should change from zero the some high number. Good luck have fun and learn !
Nov 22, 2010 | Bissell 6594 PowerForce Bagless Upright...
The power cord is split near the base unit
There are 2 screws on each side of the top cover of the Rainbow ‘E’ series vacuum cleaners located behind the decal windows. To get to the screws; use a non-scratching tool such as a plastic putty knife and pry out a corner of the plastic window, carefully pull out the plastic window and decal and remove the 2 screws. Repeat this process for both windows and then just lift up the top cover to expose the inside.
May 15, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Power cord broken inside reel
the reel doesn't come apart, its a replaceable item. the only place that you can get another one is through sears.
Jul 19, 2009 | Kenmore 23313 Whispertone Bagged Canister...
I was blowing snow with my Toro Power Curve 1800. I was distracted for a moment and tangled the cord in the blade. The cord is wraped around tight, how can I remove the cord?
unless you are able to turn the blade backward and pull on the cord at the same time no luck. it may be easier to just cut the cord and install a new one. solution one is best and both require taking the machine apart. start there and hope it works out for you.
Ps. dont forget to rate the solution. Thanks
Dec 28, 2008 | Vacuums
How to replace power cord on Hoover WindTunnel upright vacuum
The aforementioned solutions probably never even attempted this fix on this model. The handle does NOT need to come off. but the 5 screws on the front housing DO: 2 above the light and 3 below it. Then to get the colored housing off you need to access 2 screws on the underside that are beneath the agitator roller. To do that, obviously the 4 screws holding the bottom plate need to come off too. Here's a link to a schematic that might help as you attempt to do this, (assuming that you still do!)
Once you have the main body housing cover off, then you can access the 2 screws atop of each trunnion cover that holds the motor assembly cover halves together. If you've made it this far, then gently pry apart the motor halves keeping even as yo do. Now you can see all the wiring necessary to cut and splice. Happy cord replacing! As for me, I am headed for the store, as I am not so sure I can remember how to get the darn thing put back together. But it was fun taking it apart!
Apr 15, 2008 | Hoover U6616-900 WindTunnel Bagless...
Replacing a fraayed and twisted power cord on a Hoover windtunnel upright
ok so I took this vaccum apart completely except for the electrical and motor systems. It seems to me that without dismantling both of these systems on the vaccum you can't replace the power cord. And I wouldn't recommend taking them apart unless you know what you are doing since replacing the power cord seems to require cutting the old power cord and soldering the new one onto the old terminals. All in all its probably easier to get a new vaccum altogether.
Dec 13, 2007 | Hoover U6616-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
