Question about Cameras
Systolic is working sometimes.......diastolic not working at all. Reads E!
What will fix the problem? new batteries are working great. just not reading right.
SOURCE: handset reads Invalid battery
remove battery from phone;
wipe the battery pin and the phone socket with wet cloth now insert again and try
Posted on Apr 15, 2010
  • 12 Answers
SOURCE: The systolic pressure reads high
After working in the healthcare field for a while, I never trust automatic blood pressure cuffs or machines. They usually always give a high reading, I usually check with a manual reading after getting a high reading from a automatic reading.
Posted on Jan 01, 2011
SOURCE: UA-787 - Numbers on display are only partially visable
I'd suggest you send it back to the manufacturer.
The address in on the silver label on the back of your monitor.
Posted on Jun 16, 2011
  • 4736 Answers
SOURCE: My Walgreens BA-616W Blood Pressure
Most of the Walgreen's Automatic BP Monitors are manufactured by HoMedics. I'm not sure yours is or isn't. Try to locate your Owner's Manual, as it will tell you who manufactured it. Most have a 5 year limited warranty, as long as you have your Proof of Purchase.
To contact HoMedics Customer Support, call 1-800-466-3342.
I hope this helps you and thanks for choosing FixYa.
Posted on Aug 08, 2011
  • 6468 Answers
SOURCE: put in new fuel pump and sending unit. but my gas gauge doesnt always work. sometimes is does and sometimes it doesnt
if it worked for a short period of time after doing the pump/sending unit the check the connections going to the pump/sending unit they would have been moved around doing the pump
Posted on Aug 11, 2012
What is the ideal blood pressure for a male at the age of 75
Any adult person should ideally have a B/P around 120/78. HOWEVER, it can be common for an older person to be as high as 100 plus their age. (ie: 175/x)
In EMS, high B/P begins about 140 Systolic. (Systolic is the upper number. Diastolic is the lower number.)
Most B/P medications work mostly to control the Systolic, but the
lower number is also more important than most realize. When the Diastolic B/P gets over 90, the body may not be getting "perfusion" efficiently. Perfusion is where the body exchanges wastes for
nutrients in the blood by means of the capillaries. In other words,
the body is just not doing a good job of 'feeding itself' and getting rid of the toxins in the blood.
Watch your blood pressure, and see a doctor if it is running high.
You should check with your doctor at least twice each year.
Apr 19, 2017 | The Health & Beauty
I am a woman of ag 74 what should my blood pressure be
The older we get, the more likely we will have high blood pressure, still the acceptable range remains the same for everyone. You are in the range of "pre-hypertension" if your systolic pressure is 120 to 139, or diastolic pressure is 80 to 89. You are considered to have "high blood pressure" if your systolic pressure is 140 or higher, or diastolic pressure is 90 or more.
If your blood pressure is in the neighborhood of 115/70, you are doing great. :)
Apr 11, 2017 | Health & Beauty
Causes high systolic blood pressure
Isolated systolic hypertension can be caused by underlying conditions such as artery stiffness, heart valve problems or an overactive thyroid (hyperthyroidism). For years, doctors focused primarily on diastolic blood pressure. The recommended goal for systolic pressure for younger people is less than 140 mm Hg.
Apr 05, 2017 | Health & Beauty
What does it mean when the blood pressure cuff reads E1
If your blood pressure mahine is like those fro Walgreen's:
Walgreen's Blood Pressure Error Readings.
Error Codes
Err 0 No pulse is detected
Err 1 Inflation rate is too low
Err 2 Systolic reading unattainable
Err 3 Cuff pressure is too high
Err 4 Diastolic pressure is outside of operation range
Err 5 Cuff deflated too fast
Err 6 Cuff deflated too slow
Err 7 Systolic pressure is outside of operation range
Err 8 Overall pressure is outside of operation range
Err 9 Cuff is unable to inflate to the necessary pressure level
Mar 31, 2017 | The Health & Beauty
Low diastolic pressure for what reason
That paper coined a new term, "isolated diastolic hypotension," which refers to a low diastolic blood pressure (less than 60 mm Hg) and a normal systolic pressure (above 100 mm Hg). Older adults who fit those conditions are at increased risk for developing new-onset heart failure, the researchers found.17 May 2015
UAB - The UAB Mix - Diastolic blood pressure: How low is too low?
https://www.uab.edu/mix/stories/diastolic-blood-pressure-how-low-is-too-low Low diastolic pressure for what reason Google Search
Dec 13, 2016 | Health & Beauty
My blood pressure is 110/95 and my heart rate is 124/bpm. I am pregnant what does that mean?
110/95 Blood Pressure
Is 110/95 Good Blood Pressure or High Blood Pressure?
There are two parts or two separate numbers referred to as blood pressure: Systolic/Diastolic. If the blood pressure is 110/95 (110 over 95), it means that the systolic pressure is 110 and the diastolic pressure is 95.
110/95 blood pressure can also be read as 110/95 mm Hg, or 110/95 millimeters of mercury. The 110 mm Hg Systolic refers to the pressure in the arteries when the heart beats, and the 95 mm Hg Diastolic is the pressure in the arteries between heartbeats.
When determining if 110/95 is a good blood pressure, we looked at the American Heart Association's blood pressure chart.
Blood Pressure Systolic Diastolic Normal Less than 120 Less than 80 Prehypertension 120 - 139 80 - 89 High Blood Pressure
(Hypertension) Stage 1 140 - 159 90 - 99 High Blood Pressure
(Hypertension) Stage 2 160 or higher 100 or higher Hypertensive Crisis
(Emergency care needed) Higher than 180 Higher than 110
For 110/95 to be good, both numbers must fit into the "normal" category above. Otherwise, it will fall into other categories of High Blood Pressure.
Systolic reading of 110 is in the Normal range.
Diastolic reading of 95 is in High Blood Pressure (Hypertension) Stage 1 range.
Therefore, 110/95 is High Blood Pressure (Hypertension Stage 1).
Aug 05, 2014 | Veridian Healthcare 01-539 SmartHeart Arm...
Manual for cvs model BP3MU1-1E
fakonobea, it means pulse / diastolic / systolic. Pulse is how many times your heart is beating per minute. Systolic is the pressure when your heart is contacting; it is the top number. Diastolic is the bottom number and it is the pressure when your heart is at rest. Normal pressure is 120 systolic and 80 diastolic, or 120/80.
If you have further questions, I suggest talking to your doctor or health care professional, they will be happy to tell you.
Aug 18, 2012 | Health & Beauty
My Walgreens Digital Blood Pressure Monitor pumps up to diastolic 118-122 then stops and deflates and the screen reads Err 2. Can you please tell me what the problem might be? Thank you.
Your Blood Pressure may be to high for the reading. Try to adjust the cuff and restart. Are you sure it is diastolic reading and not systolic?
Jan 13, 2011 | Health & Beauty
Digital wrist model # SR303S, shows error 3, has new batteries
Possible explanations and work-arounds based on various blood pressure monitors..net is if it has worked religiously like mine had and this error comes up, and the simple fixes below do not work, there is something internally wrong with the unit..there does not seem to be any customer reset or obvious fixes..contact the manufacturer for service..
Error Description Potential cause and remedy
«Err 3» No pressure in the cuff
An adequate pressure cannot be generated in the cuff. A leak
may have occurred. Replace the batteries if necessary. Repeat the
measurement.
Error Codes
Error No. Possible cause(s)
Err 1 No pulse has been detected. Cuff may be positioned incorrectly.
Err 2 The arm was moved during the measurement.
Err 3 Inflation of the cuff took too long. The cuff is not positioned correctly.
Jan 04, 2011 | Samsung Health & Beauty
Display is blank, batteries are new
Besides being pretty horribly inaccurate, the first THREE of these I bought failed in some manner. The Samsung I now have is still working but when compared during a office visit to manual and automatic BP meters, mine is reading ~ 20 mm LOW on both systolic and diastolic readings.
Oct 21, 2009 | Mabis Smartspeed Automatic Blood Pressure...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
