Question about Hardware & Accessories
Anybody have a manual for this Grasslin timer? No idea what model, pushed every button under the sun to make it work but no such luck!
  • 8 Answers
SOURCE: dryer wont start
I would check the door swith first.
Posted on Nov 29, 2008
SOURCE: I have a Grasslin talento 371 easy timer (digital)...
Try this link http://www.graesslin.de/cms/pdf/instruction_manuals/80.10.080 6.7_talento_371+372_(V97_1_2digixx)_ls1_xx.pdf
Posted on Sep 23, 2010
SOURCE: Instructions say to push timer button down to
d2874b9.jpg Many people ask the same question. Here a GE timer with segments pulled up.
New timers come with segments pushed down, and then the manual says push the segments down, so it's confusing.
Manuals should add a diagram or a few words to explain.
Up-vote if this helps.
Posted on Oct 14, 2010
SOURCE: instruction manual G1921 Grasslin Digital Timer
I don't have a manual for Grasslin G1921 timer.
You posted under photo of GE15079 which coincidentally has same buttons, but may or may not have same programming
Open following link to identify timer similarities.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
GE 15079 manual:
http://waterheatertimer.org/pdf/GE-15042-15079-15089.pdf
Add a comment and say if these timers are both programmable with same instructions.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 04, 2011
SOURCE: need an operation manual for
Talento 371 is single channel din-rail timer.
Following manual might work
http://waterheatertimer.org/pdf/Grasslin-Talento-371-372.pdf
They also make the mini-371
Posted on Aug 19, 2011
Need to know why the grasslin Fm/1 Digi 20-L timer won't let me program it. I push reprogram button And it went back to just blinking the days of the week on top but won't respond to anything I push
Likely solution: Current time of day was set without holding down the timer (or clock symbol) key.
Other possibilities: Maybe the back-up battery is depleted and you need to connect timer terminals to correct power source ... these models vary 24V, 120V, 208-240V... look for markings on timer
More possibilities: Troubleshoot following link: This is older version timer.
http://waterheatertimer.org/How-to-troubleshoot-timers.html#module
Manuals on following link:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
Gene
Water Heater Timers Save Money
Mar 11, 2015 | Hardware & Accessories
Grasslin qe7 water heater wont turn on
Read product manual and it shows no troubleshoot resources:
Turn circuit breaker fully off and fully back on.
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
http://waterheatertimer.org/How-to-set-timers.html
Gene
h
Jan 21, 2014 | Water Heaters
Instructions for programming stanley 31215
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#cycle
Timer max uses old Grasslin-design timer buttons, and the same configuration is still used on modern Tork and Grasslin timers... and the programming is probably same/ similar.
Gene
h
Sep 18, 2013 | Stanley 31215 TimerMax OutdoorPro Twin...
Grasslin timer
Which timer?
Grasslin is very old company with many timer models, once owned by GE and sold to Intermatic, and there is still a european branch of grasslin for the 50 cycle electric market in eurtope and asia, vrs 60 cycle in us.
Copy following link to help identify timer:
Add a comment and describe timer.
Jun 10, 2013 | Hardware & Accessories
My Grasslin Digi 20E-120 timer will not set time or timer. The 1-7 numbers blink. What does this mean?
Digi 20E-120 is 16Amp 120Volt flush mount digital timer with 20 or 140 programs per week.
Grasslin Digi (digi tal/ digital) can be reset using reset button.
Reset might restore functionality, but will delete all programming.
Check that circuit is delivering 120Volt and that circuit is clean without interference.
Also check electrical terminals fit tight on the timer.
Use needle nose pliers and pull terminals off and then push back.
The digi series has 5-day program back-up capacitor so programs should remain, but capacitors go bad.
Power surge can blow out timers. Use surge protection on all circuits.
There are a many Digi timers from years of manufacture by GE and now Intermatic, since Intermatic bought Grasslin from GE.
The digi can be replaced with simple-to--program FM1D digital timer.
Replacement crossover is FM1D20E-120
Open following link for FM1D manual and Digi manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#FM1D
Upvote the help.
And take advantage of fixya expert assistance live.
May 18, 2011 | Water Heaters
I have pressed reset on my grasslin qe1 timer and now nothing will work on it
Grasslin qe1 and qe2 manual does not show troubleshoot section.
http://www.grasslin-controls.co.uk/assets/graphics/static/QE1-QE2_GB%20instructions.pdf
1) Remove power to unit and see if it will reset.
2) Press reset and hold button longer
3) Manual says: SLIDE SWITCH MUST ALWAYS BE LEFT IN "RUN PRESET PROGRAMME" OR, "RUN OWN PROGRAMME" POSITION, OTHERWISE THE CLOCK WILL NOT RUN, AND NO SWITCHING WILL OCCUR.
4) Timer has stopped working. I test timers, and they all stop working one day.
Mar 04, 2011 | Hardware & Accessories
Instruction manual G1921 Grasslin Digital Timer
GE 15079 manual:
Mar 04, 2011 | Jasco 15079 SevenDay TwoOutlet Digital...
Grasslin timer instructions
Grasslin timers and manuals
Click timer-categories on left to see drop-down menus
http://www.intermatic.com/products/grasslin.aspx
Grasslin electronic time switch
Click on model number and drop-down menu shows manuals
http://www.intermatic.com/products/grasslin/electronic%20time%20controls/electronic%20time%20switches.aspx
Oct 11, 2010 | V, Inc. 12v Dc Timergeneratortransfer...
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
